Question about Toshiba Satellite 1805-S274 Notebook
Laptop will boot up and then shut off after five to ten minutes
  • Ryan  Ruch
    Ryan Ruch May 11, 2010
    Is this when plugged in or on battery power. If both, does one last longer then the other
    President:
  • 2,600 Answers
If you are making it at least minutes then I would suspect an overheating problem with the processor. Check that your cooling fans stay running, then blow compressed air in all the vents to clear out dust and debris, Since that has happened, it be in your best interest to access the heatsink and processor, take the heatsink out and clean the top of the processor and re-apply a thin layer of thermal grease, re-install the heatsink.
Posted on Sep 27, 2009
It will run good for a while on hot heat and then shuts off for abut 5 mins but it doent shut off on cold cyc
why does my roper electric dryer shut off after five or ten minutes of running fine. then wait five or ten minutes, restart and it runs fine for another five or ten minutes, and so on....
Dec 29, 2012 | Roper REX4634KQ Electric Dryer
2002 vue v6...starts and runs well however when I stop , shut off the engine, then try to start after half hour , it wont start
Lookfor a light on the dash that says SECURITY or ANTITHEFT. If you see this light, that is a sign of a failed or failing antitheft system, which will disable your vehicle. This link explains
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Nov 06, 2011 | 2002 Saturn VUE
Zzy6913@yahoo.com i havwe a new compaq presario laptop 1800 model number a18xl390 and its locked up !!!! how do you unlock this model of laptop ?? can a nyone help thanks the wiz
Locked up screen?? Shut down with button, pull the battery. After five or ten minutes reinstall the battery, Push start button. Screen will say window shut down unexpectedly and ask for start command. Start in safe mode and prompts should come up about your problem and ask you to send a report to microsoft. Do that and follow the prompts. I hope that helps.
Jul 14, 2011 | Computers & Internet
My laptop turned off but it has 35% remaining battery
Laptop turns off suddenly? Computers may not be smarter than people, but if they’re designed properly, they will shut themselves down before overheating to the extent that they do themselves damage.
If the smart person keeps turning the notebook back on and figures out a way to foil the protection, the laptop is probably doomed.
Once a laptop shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot.
The over-temperature protection is generally a BIOS rather than an operating system function, so one sign of an overheated laptop is one that shuts itself down while you’re using it and then refuses to boot as far as the operating system unless you leave it alone for an hour or so to cool down.
Unless you’ve been working in a very unfriendly environment, high temperatures, direct sunlight, etc, you should take even a single overheating shutdown as a warning to back up your data at the first opportunity and to give the cooling system a serious cleaning.
May 29, 2010 | Computers & Internet
Overheating and turning off
Laptop shuts down? Computers may not be smarter than people, but if they’re designed properly, they will shut themselves down before overheating to the extent that they do themselves damage. If the smart person keeps turning the notebook back on and figures out a way to foil the protection, the laptop is probably doomed. Once a laptop shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot. The over-temperature protection is generally a BIOS rather than an operating system function, so one sign of an overheated laptop is one that shuts itself down while you’re using it and then refuses to boot as far as the operating system unless you leave it alone for an hour or so to cool down. Unless you’ve been working in a very unfriendly environment, high temperatures, direct sunlight, etc, you should take even a single overheating shutdown as a warning to back up your data at the first opportunity and to give the cooling system a serious cleaning.
Mar 30, 2010 | Acer Aspire 5315-2153 Notebook
Turns off suddenly
Mar 27, 2010 | Toshiba Satellite M55-S331 Notebook
Laptop keeps shutting off by itself
When you encounter about this issue this is overheating problem maybe the CPU fan is not spinning and faulty already, you need to check the CPU fan and replace a new one.
Oct 08, 2009 | Gateway (60.44K08.001) Laptop Heatsink
My laptop keeps shutting down at random times. I
Good luck
Oct 03, 2009 | Toshiba Satellite A100-S8111TD Notebook
Shuts down
Hi..
If the laptop shutdown maybe it cause overheating.
Good luck !!!
Regards
PCmania
Jul 15, 2009 | HP Compaq Presario V6000T Notebook
Boot up menu restart; will not power
Boot up to the safe mode screen & select last known good configuration.
Jan 15, 2009 | Gateway 4026GZ Notebook
Toshiba Satellite 1805-S274 Notebook Logo
104 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
