Question about Directv Plus DVR DTV Receiver / 100-Hours Video Recorder
My Direct TV receiver stops responding to the remote.
While watching recorded shows, my Direct TV receiver (Model R15) stops responding to the remote. I can operate the TV, but the DVR commands do not work. The green lights at the top of the remote flash from DTV to TV when I push any DVR buttons. The only solution I have seen for this issue is to reprogram the remote or reset the DVR. Obviously, if I am able to set the receiver to record, then get to the list and play the show I want to watch, the remote must already be properly programmed, so this solution does not make sense to me (also, I have performed these steps, yet the issue persists).
What is going on? And how can I keep it from happening again? It is frustrating to be in the middle of a baseball game and not be able to pause it or hit the replay button. (It kind of defeats the point of paying for a DVR service.)
Thanks in advance for any help!
4 Suggested Answers
  • 86 Answers
SOURCE: Direct TV DVR "skipping" like a dvd
You have an internal hard drive error. You will need a new box.
Posted on Jan 22, 2008
  • 5 Answers
SOURCE: Direct TV DVR Recording Problem
call tech support & ask them to hit your box to reset it, in the meanwhile unplug it for 15 seconds
Posted on Apr 25, 2008
  • 734 Answers
SOURCE: Watching either tv or pre-recorded show and screen
Your TV overheated probably due to condensation on the circuit. Keep the TV on as long as you can to drive off moisture. Or always leave it on standby to avoid condensation.
Posted on Dec 02, 2010
Why does my R15-100 DVR Plus not record 2 programs at same time. What can I do to fix it?
When we had the R15 (we have since upgraded) we could record two channels at once with no trouble. You have to have two satellite connections in the back (since it uses a separate tuner for each channel) and you cannot watch a third channel while recording two others - if you're going to watch, you have to watch one of the two shows you're recording.
May 16, 2014 | Directv Plus DVR DTV Receiver / 100-Hours...
DirecTV receiver R15 won't respond to remote RC23
Well, I took the DVR apart and found the power board completely intact, no bulging capacitors. However, the Mother Board had a 220uf/50volt cap that was bulging, so I replaced it. By the way, 'DigiKey' is the only place to go for electronic parts. They'll hook you up! The DVR still wouldn't respond to the remote. Darn it!
So I took both of my DVR's apart and swapped out the Front Board (the one with the Photoamplifier in it) and the DVR would now respond to the remote. OK, so now what do I do. I still have one DVR with a bad Front Board. I started to look on ebay for an old used R15 500 that I could swap parts from...remember, I own my eqipment and the goal is to preserve what I have recorded on the Hard Drive. R15's were going for around $50 -$80. Then I got to thinking. I still had an old non-DVR Direct TV Receiver in my closet I never planned to use again. My thought was: even though it wasen't the exact model receiver, it did use the same remote, so the frquency that the Photoamplifier worked at should be compatible.
So I took apart this receiver unsoldered the Photoaplifier. I then removed the Photoamplifier from my malfunctioning DVR and installed the part from my unused Receiver and it fixed it. So long story short(too late for that) the Photoamplifier was faulty. I tried doing some cross checking and a company in China called Raytron makes the part. The failed part did not have a part # and Raytron has several different Photoamplifiers that operate at different frequencies. This made it impossible to find the right part without schematics or knowing what the freqency is. So at least we now know what caused the non responce to the remote.
Jan 31, 2010 | Directv RC23 Remote Control
Prior to the recent installation of Direct TV I was with DISH. I switched to Direct when Dish attempted to charge me for a new full package cost because I wanted to re-activate a Dish receiver which I had...
After it is hooked up, it should have a white screen saying "searching for satellite signal." After fifteen or twenty minutes, it will go to a black screen saying the same thing in a blue box. Once you are there, you can prerss the LIST button on the remote and record and copy your selected shows. This is assuming you have a newer DVR. Model R15 or higher. thanks keep updated
Jun 16, 2009 | Philips Televison & Video
Direct receiver is not responding to remote
if you go to:
it has different remote codes. you would have to select "satellite setop box" also you need the model # of the receiver which can be found (normally) behind a door on the front panel of the receiver on a sticker (where the access card and reset button are) if its not a directv receiver, (hughes, etc) then it would probably be on the back of the receiver you would see a sticker with the model # of this receiver.
the first code should be 00001 follow the instructions on how to program on that website.
Apr 19, 2009 | Directv Plus DVR DTV Receiver / 100-Hours...
Apr 22, 2008 | Directv (R10) DTV Receiver / 70-Hours...
Direct TV DVR Receiver R15 Code
Try using the remote's "search" feature. If that doesn't work then it's probably not compatible.
Hope that helps...
Mar 29, 2008 | GE RM24940 Remote Control
Jan 22, 2008 | Directv Plus DVR DTV Receiver / 100-Hours...
Direct tv codes
Sep 22, 2007 | One For All URC-3021 Remote Control
DirectTv Recievers R15
Let me get this straight, your receivers, after no type of action in about 5-15min they go to sleep. And return when pressing a button, correct?
Sep 13, 2007 | Directv (DWO2-10007) DTV Receiver /...
Directv Plus DVR DTV Receiver / 100-Hours Video Recorder Logo
195 people viewed this question
Top Directv Televison & Video Experts
john milligan
Are you a Directv Televison and Video Expert? Answer questions, earn points and help others
