Question about Kenwood KDC-MP435U CD Player
I have 1986 Cryster Laser, radio harness
I have 1986 Cryster Laser, the radio harness was removed i would like to know what the Diagram is for i can hook up my Radio with out the factory harnes. My Brother and I cant seem to get this one?
  • 54 Answers
U need a constant hot a ground and an ignition on hot make sure the ignition on hot is only hot when ignition is on then hook up your speakers
igniotion is red
battery or hot is yellow
black is ground
white gray green and purple are speakers
Posted on Sep 27, 2009
Does a 1986 f-150 have a reset button for the rear fuel tank fuel pump
wouldn't have thought so, check your fuses. Pump will only run when cranking. have someone crank while you check the harness for a supply then you'll know if its the pump. Diagram likely on google images
Sep 24, 2016 | 1986 Ford F150 SuperCab
Remove radio
pull the knobs off there will b 2 nuts holding the radio in place 1 on the volume knob 1 on the channel selector remove them if the radio does not pull out loosen the back brace at rear of radio unplug wiring harness and antenna and its out
May 25, 2014 | 1986 Ford F 350
Does any radio work for a 1986 camry?
As in aftermarket like a Sony or Kenwood or..???? Yes.
The easiest way to install one is to get an installation kit. One that has a bracket/face that fills the hole in the dash and the new radio sits in and a wire harness. The harness makes things so simple. You don't need to know what wire color is what. The cars factory harness plugs right in and the new radio wires will be the same color on the harness.
Sep 06, 2011 | 1986 Toyota Camry
I need the wiring diagram for a dual stereo model xd1225 to hook it up to a 1986 ford f150
OK, for starters, get a wiring harness made for your vehicle. All aftermarket radios have standardized wiring colors. You wiring harness will have matching colors, so it will be easy to hook up. The harness will also have the diagram of colors on the package. However, you vehicle wire colors will not match this. That's why you have the harness. You will just plug into the stock vehcile harness. You will not have to match any wires because the harness is specifically made to match your vehicle. Trust me, it's easier this way. You can find them all over, try www.crutchfiedl.com to get one if you need. Hopd this helps.
Aug 23, 2011 | Car Audio & Video
Wiring harness diagrams
Need to know which part of the diagram you need? Engine, dash, radio, etc.
Mar 20, 2011 | 1986 Jeep CJ7
2002 kia speaker system diagram
It all depends on the Kia model but here is a diagram to get started with.
Radio Wiring Information:[B/]
Radio 12v red + radio harness
Radio Ground black - radio harness
Radio Ignition orange + radio harness
Radio Illumination red/orange + radio harness
Factory Amp Turn-on pink + radio harness
Power Antenna white + radio harness
LF Speaker +/- black - yellow +,- radio harness or amp under driv seat
RF Speaker +/- red - blue +,- radio harness or amp under driv seat
LR Speaker +/- orange - green +,- radio harness or amp under driv seat
RR Speaker +/- white - brown +,- radio harness or amp under driv seat
Mar 27, 2010 | Car Audio & Video
I need an elecrical wiring routing diagram for a
Radio 12v, blue/red, +, radio harness
Radio Ground, black/yellow, -, radio harness
Radio Ignition, orange, +, radio harness
Radio Illumination, lt. green/red, +, radio harness
Factory Amp Turn-on, blue/black, +, radio harness
Power Antenna, N/A,,,
LF Speaker +/-, red - white," +,-", radio harness or amp
RF Speaker +/-, blue - yellow," +,-", radio harness or amp
LR Speaker +/-, purple - pink," +,-", radio harness or amp
RR Speaker +/-, white/blue - black/blue," +,-", radio harness or amp thats for non bose 04
Sep 21, 2009 | House Brand Car Audio & Video
How do i install a sound system into a 1986 honda accord?
is there a factory radio already installed or just a cover plate, if there is a cover plate use a very small screwdriver to pop the plate out (it ha two clips) you can also use a small pry tool); if there is a factory radio installed you must go under dash behind radio with a 8mm 1/4 inch drive socket with extension and remove the two screws out of the radio ,rear part of radio; if there is a center console you must remove the 2- 4 side screws and two screws in the armrest section inside or on the rear side of the console, slide it back and remove console then the radio. sometimes you have to remove the ash tray pull out; and remove the three screws in the black metal area of the ash tray mount. to remove the radio push it out from behind and it will pop right out. if your putting in an aftermarket radio not a honda radio; you can buy an electrical adapter from pep boys or other automotive supply house to attach to your wiring harness so you do not have to cut any wires. usually honda places a speaker and wiring diagram on their radios . good luck
Sep 15, 2009 | 1986 Honda Accord
Identification of original wiring to car radio/stereo
no wiring diagram needed go cut a plug from a junk yard and wire it into the cut wires then buy the adapter kit for you car and wire that to the car plug and the radio plug.
Mar 19, 2009 | 1986 Honda Civic
Kenwood KDC-MP435U CD Player Logo
54 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
