Question about Sony Ericsson Walkman W810i Cellular Phone
Setting ringtunes? i don't know how to set my songs on my walkman as my ringtunes. I've tried changing to file type to: mp3, m4a, m4r, mid, midi i don't know what to do i can't listen to that stupid default "greeting" ringtune anymore!!
    Brigadier General:
  • 7,752 Answers
When you load a song to your phone just go to settings,file manager, music then scroll to use as ringtone and that should work.
Posted on Dec 21, 2007
Downloaded ringtones are not syncing with my iPhone 4S. I've tried deleting all ringtones from iTunes and starting all over but deleting is not an option.
see the instructions in the link below:
Note: the iPhone ringtone must have an .m4r extension in order to be recognized, and it must be under 30 seconds long in order to work properly. This is what differentiates the iPhone ringtones from those on the Android, which can use a .m4a or .mp3 file without an additional conversion. Remember that an .m4r file is the same thing as an .m4a audio file, except the file extension has been changed to represent the ringtone.
Make Free iPhone Ringtones in iTunes downloaded-ringtones-not-syncing-idhgrcvb3gwnj1x0htsxmiux-2-0.jpg downloaded-ringtones-not-syncing-idhgrcvb3gwnj1x0htsxmiux-2-2.jpg
Nov 04, 2013 | 1,000,000 Ringtones LLC 1001 Ringtones...
How to create a ringtone for iphone
You'll need - Audio song, a song editor, iTunesFollowing are the steps needed to follow:
  1. Select any song
  2. open that song in the song editor and extract the part you want to create as ringtone
  3. Save the clip, export it as format - M4A (i.e. m4a format) - say myringtone.m4a
  4. goto the clip in your file system, change the extension to m4r, i.e. myringtone.m4r
  5. double click the file, it should automatically get added to ringtones under your iTunes installation.
  6. Enjoy!!
Restrictions: clip can be up to 40secs in length.
on Jun 18, 2010 | Apple iPhone Smartphone
How to Create MP3 Ringtones for iPhones with only iTunes and Previously...
  1. Start iTunes and find the song you want to convert. (It must be an MP3.)
  2. Right-click the song and choose Get Info.
  3. Click the Options tab.
  4. Check the Start Time and Stop Time boxes, then enter times for each (no more than 30 seconds apart, the maximum length for a ringtone). I used 0:00 and 0:30, respectively, as "Spit It Out" has a perfect ascending lead-in.
  5. Click OK, then right-click the song again and choose Create AAC Version. You should immediately see a new 30-second version of the song.
  6. Drag that version out of iTunes and into the folder of your choice.
  7. Delete the 30-second version from iTunes and undo the Start Time/Stop Time changes to the original.
  8. Open the folder containing the 30-second AAC file you dragged out of iTunes, then change the file extension from .m4a to .m4r. Double-click it and it immediately gets added to iTunes' ringtone library.
  9. Finally, sync your iPhone. When it's done, you can head into the settings and select your new ringtone.
on May 08, 2010 | Cell Phones
I tried making a ringtone for my iPod touch4 on iTunes but it did not work, how do I do it?
iPod Touches don't use ringtones; however, this is a guide to making ringtones for other purposes.
Prerequisites for ringtones:
  1. Has to be less than 30 seconds.
  2. Has to be not protected music. (otherwise you have to buy the ringtone through iTunes)
How to make ringtone:
  1. Open up your iTunes
  2. Right click the song under your library and select "create ACC version"
  3. Once the copy of the ACC version has been made, right click the ACC version.
  4. Click "Get Info", then, select "Options" from the selection tab.
  5. Check both the start time and end time.
  6. Change the start time and the end time so that it has a 30-second portion of your choosing to be used as your ringtone.
  7. After this, confirm by clicking "Ok".
  8. Then, drag this file to your desktop.
  9. Its name should be "NameOfSong.m4a"
  10. You need to change it to "NameOfSong.m4r"
  11. Right click the "NameOfSong.m4a" on the desktop and click "Get Info"
  12. Under the "Name & Extension" change the "NameOfSong.m4a" to "NameOfSong1.m4r" (NOTICE I CHANGED THE EXTENSION FROM ".m4a" to ".m4r" AND I ADDED A "1"
  13. Tap enter.
  14. Confirm that you want to change to ".m4r".
  15. Delete the ACC version in iTunes.
  16. Open the "NameOfSong.m4r" and it will import into iTunes into your ringtones.
  17. Sync your device and make sure "Ringtones" sync.
  18. There you go!
Mar 29, 2011 | iPhone Apps
How do i set my music as a ringtone on iphone 4
It's a very tricky method. Follow these step precisely, and you should have your own custom ringtone like I have.
Please rate this solution if it helps you.
1 Open iTunes.
2 Find the song that you want to make into a ringtone.
3 Listen to the song and find the part of it you want to use. The chorus may be a good place to start.
4 Write down the start and stop times of the clip.
5 Right-click the song and select "Get Info."
6 Click the "Options" tab.
7 Type in the start time of your ringtone in the text box next to "Start Time" in the minutes:seconds (i.e., x:xx) format.
8 Type in the end time of your ringtone in the text box next to "Stop Time." Make sure the ringtone is no more than 40 seconds long.
9 Click "OK."
10 Right-click your song again and select "Convert Selection to AAC." Wait for iTunes to convert your song. It will create a duplicate version.
11 Right-click the ringtone and select "Delete."
12 Click on the "Keep Files" button.
13 Find the file. It's usually in your User folder under "Music > iTunes > iTunes Music" and under the band's name. It will have an extension of m4a.
14 Replace the m4a extension of your ringtone with m4r. You can either double-click slowly to rename your file, or right-click and select "Get Info" on a Mac or "Rename" on a Windows PC.
15 Click "Use .m4r" or the PC equivalent when the system warns you that the change may affect the use of your file.
16 Double-click the ringtone file. ITunes will automatically add it to your ringtones folder in your iTunes Music Library.
17 Connect your iPhone and sync your ringtones.
Oct 27, 2010 | Apple iPhone (16 GB) Smartphone
How to make custom ringtone for iPhone, convert MP3 to M4R?
Want to Convert MP3 to M4R? Recently I bought the Iphone 3Gs and was really excited, however, I was extremely disappointed with the selection of ringtones. I wanted to use a mp3 as a ringtone, so i searched on the internet and tried, Iringer and changing the name of the track converted from m4a to m4r and neither work. So is there an easy way to convert mp3 to m4r for my iPhone Ringtone?
How to make free unique M4R iPhone Ringtone from MP3, convert mp3 to M4R? This is a quick tutorial about how to convert mp3 files to iPhone M4R Ringtone with iPhone Ringtone Maker, it works easy and awesome, and it adds sepcial effect on ringtone that can make your iphone m4r ringtone more unique and customizable.
Now let's start:
What we need is:
Your own MP3 Music files
Step 1:Free Download Wondershare iPhone Ringtone Maker Step 2: Import Media files Import MP3 songs from the specified folders on your computer.
After you choose the mp3 file you want to make as iPhone Ringtone, click "Import Content" to import your source file to editing area. Or double click the file.
Step 3. Edit, Specialize your iPhone Ringtone After you import the file, you can see a waveform displays in the editing area.
1. Drag the cursor to select the segment you want.
2. Wondershare iPhone Ringtone Maker lets you perform simple editing operation, zoom in, zoom out, trim, delete, undo and redo, so you can make iPhone Ringtone easy and convenient.
3. You can also apply special effects to your iPhone ringtone, like amplify, fade in, fade out, echo, delay, phaser, chorus and normalize.
Step 4.Creat iPhone M4R Ringtone from MP3, Convert MP3 to M4R After finishing all the necessary steps, you can click "Start" to start creating your own iPhone ringtone from MP3.
Note:Check the item "Export to iPhone" to transfer the m4r ringtone to your iphone automatically; check "Export to iTunes" to transfer it to iTunes library.
And click "Ringtone Manager", you can remove, delete, clear ringtone from your iphone or load more files from the local folder with this ringtone manager.
on Dec 28, 2009 | Computers & Internet
Setting ringtone
you can not use mp3 songs that are on your iphone you have to convert then?
Aug 17, 2008 | Apple iPhone 3G
What format are they? I don't think the Walkman will play M4a (iPod) files. You're best-off with Mp3 files at a bit-rate of 128mbps or 192mbps. I'm not sure if it can handle "lossless" quality music files.
Jan 02, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Sony Ericsson Walkman W810i Cellular Phone Logo
52 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
