Question about Poulan Pro " Pro" Self Propelled Mower
Where is the oil drain plug for a poulan self propelled 22 inch 625 series mower
  • 546 Answers
Remove spark plug wire from plug,tip machine on its side.look under blade for a threaded plug with a square head where bottom of motor protrudes through deck.on most models you can simply tip machine over far enough to allow oil to drain out the dipstick[filler]tube.
Posted on Sep 27, 2009
Where is drain plug for oil on Troy bilt Tb230
It does not have a drain plug. You can remove the dip stick and tilt the mower to pour out the oil, or you can use one of those hand pump syphon units to pump it out.
Mar 23, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
I just inherited a Poulan Pro Electric 625 Series Self-Propelled Lawn Mower. I used it once...it started quickly but the self-propelled function doesn't seem to work very well. I have had other...
This sounds like a simple belt adjustment. Look in the area where the belt is . Look to see if there is an adjusting screw, or a movable pulley, or just something that will tighten the belt. Lift the mower and look underneath the mower deck. This may be where the adjustment may be. If you can't find the area of adjustment, then you may have to bring in to the repair guy. Either way it's cheaper than a new mower. GOOD LUCK>
Jun 28, 2011 | Poulan Pro 22" Self Propelled High Wheel...
Where is the oil drain plug? I have a Poulan 600 pro self-propelled lawn mower and cannot find the oil drain plug to change the oil.
It is on the bottom of the engine. Lift up the deck and look under it. Make sure there's no grass covering it up.
Apr 22, 2010 | Poulan Pro " Pro" Self Propelled Mower
My Poulan self propelled lawn mower model 961320048 is leaking oil from the bottom after use. I cannot find the oil drain plug to tighten it. Where is it located?
where is the oil on under there ??if it's on the shaft where the blade attaches the the oil seal is bad...that's caused by old oil, which is too thin and seeps out...try changing the oil first...
this will help...copy & paste...
http://www.youtube.com/watch?v=XXvsdWbW5D8
Apr 18, 2010 | Poulan Pro 22" Self Propelled High Wheel...
How to change oil in poulan pro 650 series model hp-22 mower
Drain plug is under the motor. tip the hole machine back, (handle lying on ground) put something heavy on handle to hold it down, the plug usually is a 1/2 size wrench. Put a pan under machine to catch the oil. Take the drain plug out, drain oil, put drain plug back in, tighten it, and put machine back on all four wheels. Add oil. Take about 3/4 quarters of a quart. SAE 30 or 10w-30.
Apr 14, 2010 | Poulan Pro 22" Self Propelled High Wheel...
How to change oil in poulan 22 self-propelled mower
there should be a drain plug under the mower near the shaft that the blade is connected to... good luck
Apr 07, 2010 | Poulan Pro 22" Self Propelled High Wheel...
How to change oil in poulan 500 lawn mower
First remove the spark plug wire from the spark plug. Then tilt the handles down to the ground. It helps to have something you can slide the handles under or otherwise hold them down. Underneath the mower deck there will be a drain plug. You are in front of the unit facing it the drain plug will be at about 7-o'clock a few inches from the cranckshaft. It will have a square hole in it. Use an extension on a 3/8ths drive ratchet in the square hole and remove the plug. Be careful not to cut yourself on the blade, I usually remove the blade first and sharpen it while the oil is draining. Loosening the dipstick from the tube on top will help it drain faster. When its done draining replace the plug and reinstall the blade if it was removed. Then refill from the dipstick tube. The unit will take approx. 22 ounces of oil. Do not overfill.
Jan 04, 2010 | Poulan Pro 22" Self Propelled High Wheel...
Can't locate the oil drain plug to change oil.
Around the base of the motor there should be small round cap about the size of a quarter with two small round quarter inch high posts on it - that is for finger leverage.. Unscrew it and tip the mower so all the oil comes out.. Replace oil and cap.
Sep 23, 2009 | Poulan Pro 22" Self Propelled High Wheel...
Changing oil
UNDER MOWER WHERE THE BLADE IS THERE IS A PLUG WITH A SQUARE HOLE THAT A 3/8 RACHET WILL FIT IN TURN IT COUNTER CLOCK WISE. THAT WILL DRAIN THE OIL.
Sep 16, 2008 | Poulan Pro 22" Self Propelled High Wheel...
Poulan Pro " Pro" Self Propelled Mower Logo
752 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
