Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Fridge won't came back on
My electricity was turned off for a week, when i came back from vacation i turned it back on. Now its been 8 hours and the refrigerator is still warm. I hear the vent blowing inside and when i feel it, its warm air. Whats going on???
  • 358 Answers
Most Whirlpool refrigerators have problems with the compressor relay, you'll know because there's a clicking sound from the compressor trying to start , if this is the case replace the relay.
Posted on Sep 27, 2009
Mini fridge doesn't get cold anymore
Is the unit running? If so then,
by shutting the unit down for a long period may have exposed a pinhole leak of refrigerant at an external brazing point. or you may have caused an issue in cleaning it This is something that would require a licensed technician to resolve.
Oct 15, 2017 | Emerson Refrigerators
Hi I have pressed the vacation button on my side by side refrigerator/freezer as we are going away for 8 weeks. The display has lit up but there is no difference in the way the fridge is operating - same...
The settings will reset to a lower settting as the fridge/freezer will not be disturbed . So wait for the fridge to run and shut down and it will continue to run in this low mode to save power but to keep the food in prime condition. The fridge alone will not be shut down.
Aug 31, 2011 | Samsung SRS20DTD Side by Side Refrigerator
On this timer is the light color of time Day and the blue cover on time for night?
You posted under GE 7-day random vacation timer.
This timer shows 7 days of the week.
The nighttime hours are white with blue background.
Daytime hours are blue with white background.
Timer dial rotates clockwise, and make 1 revolution each week.
To set timer, manually rotate dial until current day and hour line up with 'time now' pointer.
Move slide switch to TIMER ON.
Timer randomly turns on-off at preset times.
To watch timer in action: turn lamp ON, plug lamp into timer, plug timer into outlet, and then manually rotate dial clockwise several rotations and watch lamp turn on-off.
http://waterheatertimer.org/images/GE%2050462%207-Day%20Random%20Vacation%20Timer.jpg
http://waterheatertimer.org/GE-timers-and-manuals.html#50462
Aug 13, 2011 | GE 50462 7Day Random Vacation Timer
The fridge gurgles and won't cool in a/c or gas.
If the fridge is "gurgling" then there is one of two problems. Either you have a bad thermistor, which is not allowing the fridge to cool down properly, or your cooling unit is becoming plugged. If you run the unit on gas and get no check light, remove the outer cover and place your hand on the cooling unit, if it is just too hot to keep your hand on, then move your hand up the back. Feel the unit to see if there is a spot where the cooling unit begins to cool off. If so, that is where your blockage is.
There is also the possibility of air bubbles in the system. There is a procedure known as "burping" the unit but it is quite extensive and time consuming.
1. Remove the fridge from the unit, paying attention to electrical connectors and being sure to shut off the gas line and remove it from the fridge.
2. Pull the fridge onto the floor in the unit (providing there is room) and lay it on it's right side. Let it set for 8 hours and then turn it on its top for 8 hours and the its left side for 8 finally standing it back up.
This procedure will burp the air bubbles out of the unit and allow it to work correctly.
Hope this helps,
Jeff
Jul 07, 2009 | Dometic RM2652 Refrigerator
WHIRLPOOL TOP FREEZER ET1WTKXKQ01. NOT COLD ENOUGH & KEEPS RUNNIN
remove the back wall leave the unit to run half hour open and see if coil have frost all the way from the top of the coil to the bottom if the coil is full you have adefrost problem could be your timer defrost thermostart or heater
Mar 31, 2009 | Whirlpool ET1WTKX Top Freezer Refrigerator
Vacation button keeps on activated(refrigerator Samsung SRS20NTC)
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Set to regular temp then lock functions.
Freezer temp + fridge temp for 3-8 sec to lock function
Dec 13, 2008 | Samsung SRS20DTD Side by Side Refrigerator
RCA d52w20 Power Problem
ore there ares some ribbon cables that need to be reseated going from the deflection board to the signal board
Nov 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Ice build-up in the freezer of a Kenmore 19 (Top Freezer) refrigerator, and only 60 degrees in the fridge.
there is supose to be a switch or were the ice is making just figure out which way to turn it off or on. then turn it off and see if the ice stop making. if that doesn't work get a new frige
Jan 29, 2008 | Refrigerators
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
87 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
