Question about HP LaserJet 3100 All-In-One Printer
HP Laserjet 3100 all in one USB driver / cable
My trusty HP 3100 will not connect to new XP systems via a USB to Parallel Bi-Directional Cable. I have loaded the latest BIOS / drivers etc via an old PC.
When connecting via USB XP does start the hardware wizard and recognise the HP 3100. However no priniting is possible, I have tried every combination of printer ports e.g. USB, LPT2 etc with no joy
  • 1 more comment
  • Anonymous Apr 14, 2008
    Having the same problem. I'm wondering if it is the print driver not working w/ XP.......has anyone solved this yet?
  • panacal Nov 18, 2008
    Has anyone found a solution for printing on an HP 3100 printer using a computer that only has USB ports?
  • Anonymous Jan 05, 2009
    Same issue trying to connect HP 3100 to new computer with only USB ports.
  • 112 Answers
Follow the link and get the correct driver and get installed
Also try with another USB cable, If you are using a long cable, just try with a short one.
Posted on Jan 19, 2010
Hp 5500 printer
The HP Color LaserJet 5500 and the DesignJet 5500 are older printers with a parallel port on the basic model. A network card was added or available as an after-market add-on; this would connect to a router or network switch. Assuming you have the basic model and your laptop is new enough to only have USB ports, you need a USB to parallel port adapter. is one model. (Note: the parallel port on the printer is a bi-directional port; you will need an adapter with bi-directional communication.)
I hope this helps.
(According to the HP site, the driver for the LaserJet 5500 should be available from the Windows 7 Windows Update feature. For Windows 8, you will need to download and install the Dot4 program before the printer will work. See for the file If you have a different OS, see the HP site for your printer driver information.)
Jun 30, 2013 | Computers & Internet
My computer cannot detect my scanner. Error Code: 0x0070800
The FB320P is a parallel port scanner and is having problems communicating with the computer. Are you connecting it directly to the parallel port on the computer? In that case, you may not have bi-directional communication enabled. Turn off the scanner and the computer and disconnect the data cable from the computer. Turn on the computer and enter the BIOS. (Press Esc, F1, F10, or Del repeatedly after you turn the computer. You should see a screen with the correct key to press; it varies depending on your BIOS and motherboard. If you miss the timing, shut down the computer and try again.) In the BIOS, search for the parallel port settings and see if you can enable bi-directional communication.
Not all parallel ports support bi-directional communication. If you can't enable the feature, you need a different parallel port. Try a PCI slot add-on card; just check the features and check the manual for enabling bi-directional communication.
If you are using a USB to parallel port adapter, get a different one that supports the bi-directional communication.
What OS are you using? There are a few that had ASPI driver issues; a third party app, ForceASPI, may help. See for information.
I hope this helps. Please add more information about the configuration (cable, OS, etc) for extra ideas to solve the problem.
Sep 16, 2012 | Canon CanoScan FB320P Flatbed Scanner
Product scans but then I can't find the result
The first thing I recommend you try is a new data cable. Scanners require bi-directional communication and will fail even when the printer works. Similarly go for a direct connection instead of using a print server or USB hub. (I have a scanner that had the same problem - the preview scan started but no image saved due to a bad cable.) If you are using a parallel port connection, make sure that bi-directional communication is set for the port (in the BIOS). If you use a USB to parallel port adapter, make sure it is a bi-directional (for scanner) adapter.
I hope this helps.
Jul 24, 2010 | Brother DCP 115C All-In-One InkJet Printer
I have a BJC80 printern with a scanner head. My pc is an xp opertins system. It is connect to parallel port but when i try to scan, it sends me back an error message saying there is no communication.
One of two issues may be involved. 1) Make sure you have a bi-directional IEEE-1284 parallel printer cable, 6 feet or less long. 2) Make sure that the parallel port is set to ECP mode (the BIOS is accessed by hitting F1 or F2 during boot on many computer, check your manual.) Try a new cable (just in case the cable has just enough damage to prevent the scanner from getting the full bi-directional communication).
I hope this helps.
(the lack of bi-directional communication only disables the scanner, the printer will still work)
May 08, 2010 | Canon BJC 80 InkJet Printer
Lexmark X4550 not printing in Vista can't enable bi-directional
"Bi Directional Printing" is a statement of Parallel Port printing. Are you connected from your PC to the Printer via the parallel port?\
Did you disconnect the USB cable form the PC and then delete the current driver prior to installing the Win 7 driver?
Nov 18, 2009 | Lexmark X4550 Multifunction Wireless Color...
Can i connect hp laserjet 4p via usb ??
I have a similar situation. Trying to print from a HP LaserJet 4 using a parallel cable to USB. It will not recognize the printer. What is the installation setup or what is the trick to get it to print?
Jan 13, 2009 | HP LaserJet 4 plus Printer
Hp laserjet 4001n
The cable you need to connect to your pc is a regular parallel cable. It is called, IEEE 1284 Bi-directional Parallel Cable.
If you intend to use the a USB port this is what you need; USB to DB-25. The printer connection of the cable is the same the only diffrence here is the USB female adapter for the pc.
Nov 14, 2008 | HP LaserJet 4100n Printer
LaserJet 6L with Vista using Parallel to USB Cable
It can be done tested by Thoo personally 6L printer prints well on vista too
The printer end should be connected to 25 pin parallel cable, converted to the USB on the notebook end of the wiring
To solve your printing problems locate vista driver, since i have tested vista works fine on HP 6L printers
make sure you select the correct O/S and assign in to the USB virtual port 05
After installing my vista can print perfectly well on test printout
Advise from
Technical support specialist: Thoo Wai Kiat
Nov 05, 2008 | HP LaserJet 6L Printer
My HP LaserJet 6L Won't Print on new HP/Vista PC
Use any printer parallel 25pin convertor to USB cable and connect it to pc or notebook
Connect both ends from pc to 6L printer
Go to website to choose the correct O/S driver for installation
Use virtual USB port005 for printer 6L
Bi-directional option can be ticked
Click apply and ok
Unplug and replug the USB cable
Try printing a test page,
I have tried it, the vista download drivers works on vista, no problems in printing at all, advise from
Jan 20, 2008 | HP LaserJet 6L Printer
Printer will not come online with P3 computer running XP = Will not print.
Please check the model # - I can find no matches. Problem lies in the printer. Online light should come come on whether you are connected or not. Can you make a copy or print and internal report? I'm sorry but I need more information. Ed
Jul 02, 2007 | Panasonic Workio DP-150PA Copier
HP LaserJet 3100 All-In-One Printer Logo
807 people viewed this question
Ben Johnson
