Question about Samsung WEP460 Bluetooth Headset
I got a new phone and need passcode to pair my bluetooth.
  • rahatfaraz May 11, 2010
    Solution chack on this site www.solve.tk
In the user guide, it says the default passkey is 0000
Posted on Oct 03, 2009
Yes, the default pass code for Samsung WEP 460 is : 0000
Thanks.
Posted on Dec 16, 2010
What is the passcode for vh300 bluetooth sony ericsson?
Accessory instructions: VH300 Before you can use your Bluetooth
Aug 18, 2010 | Sony Ericsson VH300 Bluetooth Mono...
Bluetooth passcode
To find a bluetooth passcode click tis link bp
to change passcode click tis cp
to reset rp
  • Step 1 Look on the back of your headset or speakerphone for the Bluetooth passcode for the device. Typically the pairing code for headsets is printed on a sticker that is then placed on the underside of the accessory.
  • Step 2 Go into the Bluetooth menu on your cell phone to find the passcode for your cellphone. The Bluetooth menu for your phone is typically located under the "Settings" menu. In the Settings menu there should be an option to "Get code" or something comparable, which would allow you to find the code for your phone.
  • Step 3 Go into the Settings menu for your computer to find its Bluetooth passcode. Some laptops will randomly generate a new Bluetooth passcode for you each time you want to pair them with a new device. In that case the menu setting you're looking for is something like "Generate new pairing code."
  • Step 4 Look in the instruction book for your Bluetooth accessory if you cannot find the passcode attached to the device or in its menu. Many manufacturers will print the passcode for devices in their instruction book. If you still can't find the passcode, try using all zeros.
  • Read more: How to Find a Bluetooth Passcode | eHow.com http://www.ehow.com/how_5169210_bluetooth-passcode.html#ixzz0vcmCZd00
    Aug 04, 2010 | Apple iPhone Smartphone
    Hi i just bought a lg gw300 and i can't set up my bluetooth i don't know how to set up the "passcode".
    Your "Passcode" is setup when you "Pair" with another Bluetooth appliance.
    e.g If you want to connect to your friends phone via bluetooth to send a picture you would send via bluetooth and search for bluetooth device. When you select the one you wish to connect to it will attempt to "Pair" with it. At this point a "Passcode" maybe asked for if the bluetooth device you are pairing with has one set. If it does then you need to ask the person who owns the device for the "Passcode" before your picture can be sent/recieved.
    Normally if you wish to set a passcode for your device it will either be in your bluetooth settings. Possibly even in "Security" in the bluetooth settings or it may just be in your "Security" settings.
    Jul 10, 2010 | LG GW300 Cell Phone
    Pairing with a motorola bluetooth device
    Hello, Barb.
    Here are some instructions from the manual:
    To set up a Bluetooth connection, do the following:
    1. Select Menu > Settings >
    Connectivity > Bluetooth.
    2. To activate or deactivate the Bluetooth function, select
    Bluetooth > On or Off.
    Indicates an active Bluetooth connection.
    3. To search for compatible Bluetooth audio devices, select
    Search for audio enhancements and the device that you want to connect to the phone.
    To search for any Bluetooth device in range, select Paired
    devices. Select New to list any Bluetooth device in range.
    Scroll to a device, and select Pair.
    4. Enter the Bluetooth passcode of the device to associate (pair)
    the device to your phone. You must only give this passcode when you connect to the device for the first time. Your phone connects to the device, and you can start data transfer.
    Hope this helps.
    Apr 19, 2010 | Nokia 6085 Cellular Phone
    I need a passcode for my motorola bluetooth h505 to pair with new phone
    Hi,it seems you have problems pairing your bluetooth headset with your new phone in terms of the pass code,
    Here is the passcode;
    The default passcode for the motorola h505 is '0000'
    Take care of yourself and have a nice day
    Mar 11, 2010 | Motorola Mobility H500 Wireless Headset
    Ive lost my instructions for my headset device i need to know how to turn my phone to headset pairing mode
    Hello my friend,do these steps
    Pairing with another Bluetooth device
    By pairing your KU990 and another device,
    you can set up a passcode protected
    connection. This means your pairing is
    more secure.
    1 Check your Bluetooth is On and Visible.
    You can change your visibility in the
    Settings menu.
    2 Touch Paired Devices then New.
    3 Your KU990 will search for devices.
    When the search is completed Refresh
    and Add will appear on screen.
    4 Choose the device you want to pair with
    and enter the passcode then touch OK.
    5 Your phone will then connect to the other
    device, on which you should enter the
    same passcode.
    6 You passcode protected Bluetooth
    connection is now ready.
    Using a Bluetooth headset
    2 Follow the instructions that came with your
    headset to place your headset in pairing
    mode and pair your devices.
    3 Touch Yes to Connect now. Your KU990
    will automatically switch to Headset profile.
    If you have any questions you can try reading the manual here
    http://www.in.lge.com/Product/Manual/KU990.pdf
    Jan 11, 2010 | LG KU990 Viewty
    Need to repair my plantronic 230 to new phone
    you should be able to pair it to at least three devices passcode is 0000
    May 01, 2009 | Plantronics Explorer 220 Bluetooth Headset...
    How do I pair plantronics explorer 233 to a new phone after its been paired to another phone
    to pair your bluetooth first, turn the bluetooth feature on your phone to on.
    Next, hold the call button on your bluetooth until the light begins flashing blue and red, this means it it in paring mode.
    Third, find the 2XXplantronics device in your bluetooth options. Select this divice and enter the passcode (0000).
    You are now finished and the bluetooth is paired.
    Mar 05, 2009 | Plantronics Explorer 220 Bluetooth Headset...
    Bluetooth passcode
    When pairing two phones, you need to set up the connection on both phones. One will ask you to enter the password when you are creating the new connection, which you will then need to enter on the second phone to complete the connection. This ensures that only people you allow to connect (people you gave the code to) can connect to your device.
    As for pairing your headset, try this link:
    http://www.phonedog.com/cell-phone-research/blog/how-do-i-pair-my-bluetooth-headset-to-my-phone.aspx
    Jun 11, 2008 | LG VX9400 Cellular Phone
    LG Bluetooth HBM -500 Passcode for pairing
    I HAVE LOST MY Bluetooth H500 Manual, can you assist with passcode.
    Dec 11, 2007 | Motorola Mobility HS850 Consumer Headset
    Samsung WEP460 Bluetooth Headset Logo
    395 people viewed this question
    Top Samsung Radio Communications Experts
    JP Services
    JP Services
    Jerry Greenberg
    Jerry Greenberg
    Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
