Question about HP Pavilion dv6000z Notebook
Battery replaced, ac adapter replaced, still no
Hp pavillion dv6000 won't complete power up. Lights flash on then turn off in about 2 secs. No hdd, fans, screen raster at all. Already replaced battery and ac adapter, also removed memory simms, hdd, and applied pressure to various places on laptop... Need ideas!
  • 137 Answers
Could be the internal power supply unit... or in the worst case, the motherboard
Posted on Sep 27, 2009
How to replace a power supply in a hp pavillion dv6000
DV6000s are laptops and do not have internal power supplies. The power supply is actually on the AC adapter which plugs into your wall. However, if you need to replace something internally here is a link to a tear down video for the DV6000.
Feb 27, 2013 | Computers & Internet
HP Pavillion dv6700 - won't power up
Hi have you tried to power up without battery?
Feb 16, 2013 | HP Pavilion Computers & Internet
HP Pavillion DV6 won't turn on
if you left it in a dusty place try clearing the dust from the fan outlet to see if that helps
Jan 07, 2013 | HP Pavillion DV6985SE Notebook
3 weeks ago My Laptop HP Pavillion Entertainment system DV9500 shut off while I was using it and now it doesn't even power on. I purchased a new power supply thinking that was the problem but still can't...
unplug the ac adapter from the laptop and remove the battery
press the power button for about 5-10 secs
while the battery is out, plug in the ac and turn on the computer if still doesnt turn on
use a known good adapter and plug it in if it still doesnt work then motherboard needs to be replaced
hope this help
Sep 07, 2010 | HP Computers & Internet
HP Pavilion dv6000z 15.4" Notebook Laptop PC (AMD Turion 64 X2 Duo Core TL-50 1.60GHz, 1GB RAM, 100G... (d6000z) PC Notebook: My hp pavillion dv6000 dims while having the ac ad...
Go to Control Panel > Power Options
You will need to change the setting for when it is connected on battery and when it is connected on power.
May 14, 2010 | HP Pavilion dv6000z Notebook
Hp pavillion dv6000 push the start button, lights come on for ''split second'', and nothing. lights go off, no motor, no nothing. happens when plugged in or not
You have suffered a motherboard failure, just to be sure you need to check the voltage at the tip of your AC adapter and leave the system battery out of it, Just try to power it on with the adapter. If the same event happens, you will need to either service the motherboard or replace it. Ebay has several MOBO repair services for the HP products, specifically the DV6000 and the DV9000. These have been HP's problem child for a few years.
Jan 15, 2010 | HP Pavilion dv6000z Notebook
My laptop HP Pavillion ZV6000, battery started decreasing and wouldn't charge when the ac adapter was connected. I purchased another ac adapter thinking that was my problem. It didn't work. Now I have...
As others have said, the most common fault with the ZV series is the power socket. However, you mentioned the Lightning Bolt. This indicates that the battery is being charged and it should go out as soon as the battery is fully charged.
If the Lightning Bolt flashes on and off regularly, especially when the power cable is moved, then the socket is at fault and needs replacing.
You can check to see if the battery is receiving a charge by doing the following
1. Right Click the Desktop
2. Click Properties
3. Click the Screen Saver tab
4. Click the Power button
5. Click the Power Meter tab
This will tell you the computer's current power source and whether the battery is charging.
I have replaced several of these sockets on ZV5000s and I'm sure the 6000 will be similar. I would not recommend this job for anyone without technical knowledge, despite some of the websites that say you can do it yourself. You will need to strip the entire laptop down and all but remove the motherboard before the socket can be replaced.
Hope this helps
May 21, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Charging problems
Hopefully the battery is just confused and needs to be reset. Drain the battery down until the system shuts off automatically, then take the battery out of the laptop for two minutes and plug it back in, and connect the AC adapter, let it charge without turning the laptop on, then turn it on and hopefully it should work fine again. If not then you may need to buy another battery. Try again with another AC adapter just in case because you don't want to replace your battery (expensive!)
Please rate, thanks!
Mar 31, 2009 | HP Pavilion dv6000z Notebook
Faulty Connection
I have HP DV6000, I used it without the battery. it worked until I was able to purchase a new battery. It might work on the HP dv4000...
Jan 05, 2009 | HP Pavilion dv4000 Notebook
HP Pavilion dv6000z Notebook Logo
127 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
