Need to get my Numark Total Control working
Hey i'm running windows XP and I plugged in my Numark Total Control device into my computer. It began to unpack the files and the process stayed still and would not continue (it was at the finishing end). i unplugged the device and now it won't recognize the device at all. how can i re install the device, or wipe it clean? HELP MEEE :(
Please give me numark 4.1 serial key...i need it.....
Posted on Sep 18, 2011
    Problem Solver:
  • 10 Answers
Try to reinstall the software, if doesn´t work...
1- unistall the installed software
2- install the software again
Posted on Sep 29, 2009
Is my simple tech 60GB compatable with windows 7 the disk said for windows 2000 and xp
Most portable hard drives work with any operating system
Plug and Play is a simple Windows controller that enables your Windows computer to recognize and adjust to hardware changes and devices plugged on your computer such as hard drives, memory cards and USB and Firewire-powered devices with little or no input from a user. If your system is not recognizing plugged-in hardware, the plug-and-play device may be disabled and may cause instability on your system. Enabling this feature is simple.
Click "Start" on your computer screen and then click "Run." Type in services.msc on the run window and hit "Enter." Scroll down the services window and right-click "Plug and Play." Click "Properties" on the pop-up menu. Select "Automatic" under start-up type if it is disabled. Click "OK" to save the changes. Click "Start" on your screen and click "Control Panel." Double-click "System" and click the "Hardware" tab. Click the "Device Manager" button and then right-click the plug-and-play device you want to enable, then click "Enable." Close the device manager. Hope this helps.
Dec 23, 2012 | SimpleTech SP-U25/60S 60 GB USB 2.0 Hard...
When i plug Numark DJ/iO Sound Card in pop up message says "USB Device Not Recognized - One of the USB devices attached to this computer has malfunctioned, and Windows does not recognize it. For...
there are drivers needed for this item you may need to download them also re install your usb drivers an attach to a different usb port not thru a hub.
Mar 15, 2011 | Numark DJ/iO Sound Card
I have a g4 desktop and I recently purchased the total control from numark. I came home plugged it in using the USB wire and nothing happened. Is there a step I'm missing? Help
I was just looking at a Total Control...
The unit will not do anything until it sees the host application running on your machine which is Trakor LE or Pro.
Install and launch Trakor then see if it works for you.
You may need to plug the unit into another USB port depending on what else you have plugged in.
Newmark Total Control site: http://www.numark.com/totalcontrol
Minimum System Requirements (MAC):
  • Mac OSX 10.4 or higher
  • G4 1.5 GHz or Intel Core Duo 1.6GHz
  • 512MB RAM
Jan 21, 2011 | Apple Computers & Internet
I purchased a numark tt usb running under windows xp. i want it to run under windows 7 64 bits. what to do ?
The software works for both Windows 7 and Windows XP. You should just need to install it and follow the instructions. If you do not have it anymore, you can download the software and manuals at
http://www.numark.com/ttusb
Jan 17, 2011 | Numark ttUSB Turntable
Numark Omni control-iMac Problems
Did you try this turn table on another PC? It is the best way to check for I never seen a NuMark act like yours. A secondary PC is always great to have if you constantly need this turntable
Mar 28, 2010 | Numark ttUSB Turntable
When I go to Record there is no sound and the control panels do not move
Make sure the correct source is selected for sound in audio properties (Right click the volume icon near the clock). The device must be the turntable driver.
Make sure you have installed the Numark software BEFORE you plugged in the turntable to your computer for the first time.
If you have done the faux pas above, all the installs in the world will not fix it. You MUST remove the USB driver. Use Device Manager. In XP, this is found by right clicking my computer and selecting properties. In properties select the hardware tab and choose 'Device Manager'.
Stop here. If you have no idea what I wrote, review 'Device Manager' on the Windows Website or ask a KNOWLEDGABLE friend for help. See http://support.microsoft.com/kb/310123.
Now, select the USB device, while it is plugged in to the USB port, and right click. Select 'Uninstall'. Remove your USB device when device manager is done.
Close Device manager and all the other windows. Start your USB install from scratch, without the USB plugged in until the install asks or completes.
I have ALWAYS had successful installs with this method.
Mar 21, 2010 | Numark ttUSB Turntable
Problems with installing my Numark Total Control
best used with virtual dj..... go into configuration-sound settings... the controller will not activate until the music software is running.. on the sound set up its straight forward.....
Feb 23, 2009 | Computers & Internet
Nec 17'' multisync lcd monitor not working properly
What is the problem? Did you try plugging it into another working computer?
Mar 03, 2017 | NEC AccuSync LCD71VM 17" LCD Monitor
I cannot access the turntable thru my USB hub.
I received an updated driver from Numark but that still did not solve my problem. It turned out to be some sort of incompatability with my USB 2 card. When I plugged the turntable into my old USB 1 slot, my computer recognized it immediately. The new Audacity and MixMeister programs that were sent as a fix from Numark are just burning programs and not drivers for the device. I can now convert my old vinyl with ease.
Mar 10, 2008 | Numark ttUSB Turntable
Computers & Internet Logo
453 people viewed this question
David Payne
David Payne
