Question about Sunbeam 4192 Work Top Blender
Uhh....... the blender mafuntioned when i plug in it blens even when i dont turn it on
    President:
  • 3,433 Answers
Sounds to be a switch is stuck or button . Tap each button vigorously and turn each one on and off. Pressing another speed should cancel what ever button is stuck. Good Luck, Ned
Posted on Sep 27, 2009
Where is located the fuse on kitchenaid blender motor?
dont normally have a fuse
self insulated plugs for safety
fault is either the plug, motor or switch
with a continuity test light or meter
you need to check there is a constant circuit at the two plug prongs
May 27, 2016 | KitchenAid Blenders
Tip
The best way to clean your blender
I used to hate using my blender. I could make great smoothies or hearty soups but after I was done, I hated to clean it. The blender would be covered in small seeds or other small pieces of food that were stuck on. Plus, I'd be terrified of the cutting myself on the sharp blade (even when the blender was unplugged.)
So here is what you do:
1. Boil enough water to fill the blender.
2. Put a few drops of soap in the blender and plug it in.
3. Pour the boiling water over the soap in the blender, cover it and turn on.
You can let the blender run for two minutes, until it is clean or until all the little pieces are removed from the sides.
4. Rinse out with water and repeat if necessary.
And there you have it, using a blender just became a little easier.. since the cleanup is no longer a hassle.
on Dec 26, 2013 | Blenders
The pulse light is blinking, but the blender will not work
This worked for me - only took about 5 minutes (the amount of time it took for me to google Black & Decker and search through their FAQ)
Q. My blender stopped in the middle of blending. What happened?
A. Your blender has a motor overheat protection system that will automatically shut off the blender when it has been running too long with a heavy load. If this happens, unplug the blender and wait 10-15 minutes to allow the motor to cool down. Plug in the blender and resume blending.
May 28, 2010 | Black & Decker BL1900R Blender
Blender died ...... motor won't turn on
Have you tried the fuse first....
If it is the motor (quite rare), these people may be able to order you one:
http://kitchenaidblenders.co.uk/Home/tabid/36/c/KitchenAid-Blender-Spares/CategoryID/6/Default.aspx
Aug 10, 2009 | KitchenAid KSB3 Classic Work Top Blender
Wont turn on. its plugged in and the switch on the plug socket is turned on
have you fix the container? most blender today has a switch to verify if the blender container is fixed to the motor.
May 31, 2009 | Blenders
Breville blender bbl550 stopps after 5 seconds any setting
Mine does this as well... 5 seconds of operation and then OFF.
My guess is this is a fail safe where the blender is turning itself off to avoid overheating and what could potentially cause this overheating is the blender is struggling to turn the blades. What could cause this struggling of turning the blades I am guessing is a lack of oil in the blades rotating parts.
If you hold the circular blade part and turn it, you'll probably find that its hard to turn? Mine is... and I oiled it up a bit and found I got a bit more usage out of it... although only temporarily.
Ideally I need to pull it apart and oil it properly.
Jan 29, 2009 | Breville BBL550XL 5-Speed Blender
Motor won't turn on
Hi , Try to check with multi tester the power cord ,test the two tips of male outlet switch on tested read the continuity /if not reading ,pulout if push type /if permanent open cover below test the test the cord inside to the male plug if does not response cord is problem,check also fuse test both end of fuse not reading fuse buste then replace thats all goodluck.
Nov 12, 2007 | KitchenAid KSB5 Professional Stainless...
Sunbeam 4192 Work Top Blender Logo
77 people viewed this question
Top Sunbeam Blenders Experts
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Sunbeam Blender Expert? Answer questions, earn points and help others
