Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
Badger 1 1/3 HP Garbage disposal is stuck. I have hit the reset button took out what was jamming it and it still hums but won't turn. Please help!
  • 308 Answers
Can you turn the motor by hand? (with the wrench in the bottom of the disposal) If not then you either still have a restriction/jam or the motor is seized. If you can spin the motor somewhat freely with the wrench then you most likely have a bad motor and will have to replace it. Hope this helps
Posted on Oct 02, 2009
Where is the reset button on the InSinkErator Badger 5, 1/2 HP Garbage Disposal Problems & Solutions?
Here is a tip that I wrote that will help you to figure out what is going on with your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed
heatman101
Jan 23, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My insinkerator hums but does not turn.....what's up? there is no obstruction and pressing the reset button does nothing......
heatman101
Dec 15, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
The disposal only hums. I can turn the blades inside so there is no food stuck. I know there is a reset button but cant locate it.
I had the same problem, it was just humming, then after a few second the on board circuit breaker would cut out. After a little while I could hit the reset button and it would just hum again.
It turns out that the base of the disposal was jammed. There are 2 blades on the top that should spin freely, but the base plate that the blades are attached to also spins. In fact, that's what the motor drives. The two blades on top are not powered, they just flip back and forth as the base spins. So get a broom handle or a strong wooden spoon, stick it down in there, and try to pry the base plate free so it spins. That should do it.
Oct 28, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I have a Badger 5 1/2 HP and it makes a humming sound when I turn the on switch. I've tried the reset button and it doesn't help. It doesn't appear anything is stuck. Any advice? Thanks!
Hi, Sounds like the motor just died
Here is a tip that I wrote that will help you to figure out what is going onwith your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed heatman101
Sep 30, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Badger insinkerator 1(1/3 HP) is humming but not operating
Here is a tip the I wrote that may help you to figure out what is going on withyour garbage disposal and why it is not working.
Aug 07, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
InSinkErator Badger 5, 1/2 HP Garbage Disposal: I have a Badger InSinkErator, it suddenly just sto...
May 18, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
InSinkErator Badger 5, 1/2 HP Garbage Disposal: Just hums and won't run, even after assuring that ...
May 17, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Badger 1 1/3 insinkerator not grinding
Hi, Sounds like motor went bad..
May 15, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
BADGER GARBAGE DISPOSAL NO POWER
Have you checked the circuit breaker on the disposal itself? In the bottom there's a little button that resets the circuit breaker. press it in and see if that works. If the disposal is still jammed you should hear a hum.
Dec 28, 2008 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
1,399 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Craig Butler
Craig Butler
Mike
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
