Question about Whirlpool Refrigerators
It appears the I have water leaking from under the freezer. The freezer is on top, under the freezer is a styrophom area that appears to leak. Ideas?
    Top Expert:
  • Whirlpool Master
  • 12,650 Answers
In the area of the Styrofoam should be a plastic tube this is drain for freezer during defrost cycle drain might be clogged and leaking down thru unit
Posted on Sep 27, 2009
I have a Kenmore Coldspot Model 106.70182000 that is leaking water from the freezer into the refrigerator. Any ideas? Thanks!
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain, then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Good luck
I hope this helps you to stop that leak,
Gene
Aug 08, 2011 | Refrigerators
Water is leeking below the refrigerator. I cannot see where the leeking is coming from. Any ideas where to look?
There could several reasons for the water under refrigerator. Leaking water connection to water control valves. leaking defrost condensate pan or blocked condensate drain beginning inside freezer rear wall cause by ice or other gunk caught in the defrost drain line. Because leaks always happen differently on every model I will give you a page to look over and watch a small clip about fixing a refrigerator leak. One moment as I retrieve the information and links. Sea Breeze
Dec 22, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Kitchen Aid KTRC22EK leak inside refridgerator
It sounds like the drain for the defrost water is pluged. You can remove the back panel inside the freezer(ice maker will have to coe out first) and access the drain in the rear center of the freezer. Check the drain. It can be defrsted with a hair dryer(shut off the referigerator first) good luck, snugglepants
Nov 03, 2009 | KitchenAid KTRS22EL Top Freezer...
Water is leaking into top shelf of Refrigerator - Whirlpool Gold
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freeze.
Sep 10, 2009 | Whirlpool ET1FTKXK Top Freezer...
Smelly Ice and water leaking into top shelf
Does water in door dispenser taste bad? If not, Try arm and hammer fridge deoderizer. It will help to absorb fridge odors which may be clinging to water molecules in ice maker tray. Ice maker tray is open to freezer area.Water is very medium to infiltrate with odors. Try this first
Jul 22, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water leaks inside fridge from top freezer
check your gasket on the refridge door see if it has any rips or you have a blocked drain in freezer
May 02, 2009 | Refrigerators
Water leaking from bottom of unit
check to see if if drip pan leaking may be water line
Apr 07, 2009 | Magic Chef CTF1826AR Top Freezer...
FRIGIDAIRE SIDE BY SIDE WATER LEAKING FROM BOTTOM OF FREEZER DOOR
Normal 0 false false false MicrosoftInternetExplorer4 st1:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 st1:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
First lets decide where your leak actually is.
Areas to consider:
This is mostlikely a stopped up drain pan. A cold area that is not suppose to be cold likewhen you have a freezer coil that is suppose to be defrosting and is not... Seebelow for a more complete ideas list of things to check under Possibility.
The drain pan drain line is themost common. Inspect it and repair as needed, maybe its just a wrapper over the exit hole of the pan.
Some more Possibility's:
1 There is a drain that carries away the water under the cooling coils. Thesecoils are in the freezer section. Its most likely clogged or froze up.
2 The ice maker could be letting water leak all the way down look for an icy trail from the ice maker area.
3 Door gaskets are not sealing especially on the bottom of the door. Thisallows warmer air into the fridge section and it is condensation on floor underthe crisper.
If you check all of these items and still cant find it please post back andtell me what you did find. So I can help you more. Please rate me as much aspossible as Im trying to keep my average up and do the things that willactually educate and help people.
THANK you for using fixya and good luck..
Mar 13, 2009 | Frigidaire FRS26R4A Side by Side...
Accumulation of water in bottom of fridge
You probably need a new door deal for the freezer. When you cet too much condensation in the freezer, it drains down the back of the refrigerator section during the defrost cycle. Check under the produce bins for a drain. If you don't have one, you're not alone. I used to have have to wipe mine out every other day until I finally replaced the seal.
Feb 02, 2009 | Frigidaire FRT21G4B Top Freezer...
Kitchenaid Superba 42 Refrigerator Leak under Freezer when Water Used from Door
Either the water filter isn't seated properly or there is a crack in the tubing or the water line isn't seated properly in the coupling behind the grill at the freezer door. Also, inspect for breakage in the line in this area as well (coupling area).
Dec 26, 2007 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
107 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
