Question about Frigidaire GLEQ2152ES Electric Dryer
All the lights on the right side are flashing and it keeps shutting off...
  • burly2tigger Sep 27, 2009
    WOW...that sounds bad...is this something I can do...or do I have to call a repairman?
  • 1,531 Answers
Most likely you need to replace the main control board.but first i would check the door switch. or possible a faulty thermostat
Posted on Sep 27, 2009
  • seth adams Sep 27, 2009
    it can be done yourself.not real hard but if it is under warranty call for service.the control boards can be costly.part number 134523200.they can retail for 180 dollars. i hope this is helpful
Will not reset blue light keeps flashing
Instead of pressing the shut down button (on the top right) and then the shut down and ok; press the button and hold it till it goes black then reboots. I don't know if it will help but it's worth a try. :-)
Feb 03, 2014 | Samsung Galaxy Cell Phones
I have a code that show on CARMD about the srs light (airbag) on my dash , how do I reset or shut it off without changing an airbag
Hi there:The Restraints Control Module (RCM / located behind right side of the instrument panel) monitors the resistance of the driver side air bag circuit loop and the air bag module igniter at RCM, if the resistance is greater than 3.6 ohms, the RCM will store diagnostic trouble code B1994 and flash lamp fault code.
About the possible causes, pay attention that a high resistance on the driver side air bag circuit can be caused by:
  • - damaged wiring on circuit 1257 (WH/LB).
  • - damaged wiring on circuit 1258 (BN/LB)
  • - damaged driver side air bag module.
  • - damaged RCM.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Aug 23, 2012 | 1999 Ford Explorer
On operating my remote the garage door opens but when l try to shut the door it shuts then opens straight away the only way l can stop it is to press the remote again .There is a green light that keeps...
It sounds like the door is traveling too far, hitting the floor and then reversing to the open position. If this is the case you need to locate the 'down limit' control on the side of the motor unit and turn it a bit in the opposite direction of the arrow printed on the cover. Some tweaking may be necessary to get it just right.
It is normal for that small green light to flash randomly. It can also assist in diagnosing some problems by flashing a code. It will flash a number of times and then pause and then repeat. If this is the case, post the number of flashes.
Jul 12, 2010 | Sears Craftsman LiftMaster Chamberlain...
Keeps shutting off, flashing S3-Magcurr
replace 20 amp fuse and test oven with amp probe around brown wire on the right side of oven. should have +-14amps.
Apr 15, 2010 | TurboChef C3 Single Oven
Water is coming out of the freezer part, just from under the section the eyes and water are dispensed, the temperature light keeps flashing on and of at -22 degrees and everything inside is melting. What...
  1. Check that the doors shut correctly. Hold each door about halfway open, then let go. If the doors don't shut completely, adjust the screw legs on the front of the refrigerator so the unit tilts back a bit. With adjustable pliers, turn each leg one revolution clockwise. Recheck the doors and, if necessary, repeat the process until they shut securely.
  2. Step 2 Inspect the door gaskets. Look for debris that may keep the doors from shutting. Also check for cracks or gaps in the gaskets that could allow the cold air to seep out. If you find debris, clean the gaskets with warm, soapy water. If you find cracks or gaps, you'll need to replace the gaskets
  3. Step 3 If your refrigerator is equipped with a door-frame heater that evaporates condensation, make sure the heater is turned on. The switch should be located with your other refrigerator controls.
Apr 10, 2010 | Samsung RS2556 Side by Side Refrigerator
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
My samsung split system a/c keeps shutting down, with the mode light flashing on the indoor unit. This unit is installed 30' up the side of the house - is it not getting enough freon and there shuts down?
I have a MH050FX A2 that is two head unit and they run only one at a time, when I turn both on, one will shut down. I get an error code of E2 01 with a, I beleive correction code of U C8. Can you help me with a diagnosis??
Kelly Sheehan
Jun 17, 2009 | Samsung AS18A6RB Air Conditioner
Blackberry pearl wont stay on and red LED light keeps flashing
my phone wont stay on and when it does come back on it shuts right back off. the LED light on the front keeps flashing red. ive taken the battery out and everything and nothing seems to work. help please!
Apr 07, 2009 | RIM BlackBerry Pearl 8100
MY COPIER KEEP FLASHING A LIGHT OF PAPER YAM BUT THERE IS NOT ONE I THOUGHT IT WAS OUT OF INK SO I GOT A NEW BUT IT'S STILL FLASHING LIGHT
the copier have a paper jam on the left side on fixing unit or on right side .
or the copier have a paper sensor that does not move.
Dec 27, 2008 | Canon PC-940 Black and White Copier
Frigidaire GLEQ2152ES Electric Dryer Logo
584 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
