Question about Sony Televison & Video
Strs6707 and strs6706 are the same
Are strs6707 and strs6706 the same?
Sony tv strs6707 circuit dayagram.i want.
Send your email address to me. I'll send a copy to you. I tried to include it by this window, but this window do not allow me to do it.
Jun 13, 2012 | Sony KV-36XBR400 36" TV
Sony tv strs6707 is short circuit .H output line is ok?
If that is a chip in the power supply unsolder all pins and get a pin out of it to test it for a short--if shorted and no short to ground at HOT replace it.
Jun 13, 2012 | Sony KV-13VM30 13 in. Combo
No power on STR6707 was bad Replaced &checked nearby components but no result .Please Advise
Hi ehsan53,
If you're strs6707 got shorted it is accompanied with an open fusible resistor. If you've already replaced this IC, you must look also for this resistor and replaced with new one.
Let me know if you need further assistance...
Thanks for using Fixya.
Apr 16, 2011 | Televison & Video
I have a blown switching regulator, can't tell whether it is STRS6707 or STRS6307. Pls help!
Hi I would hazard a guess at STRS6707 as these are the most popular switching regualtors, not knowing the tv make & model number makes it difficult to be abolutely sure.
Hope this helps
Feb 11, 2011 | Televison & Video
Snoy model KV-21GMR1
check secondary voltage first and look for short.if you replace the regulator strs6707 you replace also c623 220uf/16volts
Sep 24, 2007 | Emerson TC0918 Television
STRS6707 problem
In the past, my experience with Sonys is that you need to use Sony parts to successfully repair them. Also you might have a cold solder joint which creates an arc when you turn it on. This arc will cause a "spike" which could possibly take out the regulator. Stargazer
Jan 15, 2007 | Sharp 32F540 32" TV
Televison & Video Logo
135 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
