Question about Whirlpool 24 in. GU3200XTP Built-in Dishwasher
Water is not draining
My dishwasher leaves water on the bottom of the dishwasher. We pulled it out and it works fine but everytime we put it back in place under the counter it doesn't drain correctly. We have followed the installation instructions
  • Anonymous Dec 23, 2008
    Worked fine for about a year, now won't totally drain
    Sniper:
  • 68 Answers
It sounds like your dishwasher does not have an air gap, and the water is draining back down the drain, back into the dishwasher. A quick fix for this is to:
Check the drain line under the kitchen sink. The drain line is supposed to run from the bottom of the cabinet, and run as high in the cabinet as you can get, (up to the bottom of the counter top) then connect the drain. This is called an air gap, and helps keep a little water in the drain line, which will prevent sewer gases from entering your dishwasher, and garbage disposal.
Please rate this solution.
Posted on Sep 02, 2008
  • 14 Answers
Your drain pump might be bad/disconnected. Check the underside of your machine for disconnected wires.
Posted on Dec 29, 2007
Diplomat dishwasher ADP 8322 - previously not draining but neither was the sink and I've unblocked that which is now working fine. When I put it on it bleeps continuously after about 5 minutes
Hello Simon,
No water in the tub would indicate the drain is clear (unless it never filled at all...have you confirmed? Do you hear water leaving the unit?).
Those bleeps and flashing lights are of course the machines desperate effort to tell you it's problems and the code may be in the owners manual or a call to the manufacturer.
I'm a big one for checking grunge accumulation and would ensure the discharge hose is clear. This gets back to hearing water leaving the machine. You may need to pull the unit to check the hose, although a common blockage is right at the connection to your disposal.
Also, check for debris under the filter screen in the bottom of the tub, another place detritus accumulates.
All the best.
Nov 22, 2014 | Dishwashers
The door on my dishwasher everytime you open it is making a loud creaking sound and there is water at the bottom of the dishwasher always. what to do?
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Mar 03, 2010 | KitchenAid Dishwashers
Dishwasher drain pump flapper (inlet side)
My Quiet Series does the same thing and I wondered if the orange flapper has gone bad and lets the dirty water drain back from the hose sloping up to the garbage disposal. Did you get an answer to this question? The dishwasher seemed to work fine and then it suddenly started leaving food particles on the glasses.
Jan 15, 2010 | Dishwashers
Dishwasher isn't draining all the water when used.
It will leave some water for the motor prime but check your drain hose make it is up at the correct angle so water does not come back in when it drains
Oct 21, 2009 | Whirlpool Dishwashers
Bosch dishwasher is not draining all the water at end of cycle. In the bottom of the dishwasher under the mesh trap there is about a cup of water remaining after each cycle.
This is normal with a Bosch. They don't really vent out when they heat, and use a type of evaporation technology to dry the dishes. Best bet is to make sure first that the filter in the bottom is clean, (the little circle thingy on the bottom, turn it a quarter turn and pull it out, run it under cool water till it's clear, then put it back in the same way.) If the water is bothering you or is beginning to make a bit of a smell in there, leave the door cracked a little after you empty the dishes out. unfortunately though, it'll always leave water in the bottom. European technology.
Sep 06, 2009 | Bosch Dishwashers
Dishwasher drains but leaves behind about 1/2" of standing water
Water standing in the bottom of the tub is normal.
A small amount of clean water around the outlet on the tub bottom at the back of the tub keeps the water seal lubricated.
Jun 22, 2009 | GE Nautilus 24" Built-in Dishwasher
Washer does not drain, and leaves water in the
hi..The drain is clogged.check the strainer at the
bottom of your unit.Always rinse your dishes of food
before putting them in the washer.
check this out..
thank u..
kindly rate my response..
Jun 09, 2009 | GE 24 in. Profile PDW7800 Built-in...
Brada dishwasher EF2401 - water in bottom
I just moved in to a new house with brada dishwasher, everytime I used the water leeks from the bottom, can somebody help me to fix it, or do you think I should throw it away and get a new one.
Sep 05, 2008 | Dishwashers
E4 message
take of the btwo black panels at the bottom of the dishwasher and put in a towel to soak up thje excess water this works for me everytime
Jul 31, 2008 | Baumatic 23 in. BDW13 Built-in Dishwasher
DISHWASHER WONT DRAIN
Have you checked the drain hose??? It may be clogged to some degree or where it meets either the garbage disposal or t-tailpiece, whichever you have, or where it comes out of the water pump. Also, the impeller inside the water pump might look good but may be worn, and check for broken glass which is hard to see in the bottom drain area at the grate. Hope this helps.
Jan 28, 2008 | Frigidaire 24 in. PLD2850 Built-in...
Whirlpool 24 in. GU3200XTP Built-in Dishwasher Logo
319 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
