Question about Apple iPhone Smartphone
The lower band of my screen stopped working
My 1G ipod touch was connected in the car. A static in the connector happened while I was activating the music app at the bottom. After that there is a band at the bottom of my screen that became insensitive.
How can I restored it? I implemented to firmware 3.1.1 and restored my ipod two times saving settings or not.
I read about changing general.plist, but I but understand how.
Altec lansing connect
IM600 Compatibility: iPod mini; iPod classic 3G, 4G, 5G, 5.5G, 6G; iPod nano 1G, 2G, 3G, 4G; iPod touch 1G, 2G; auxiliary input connects to any CD, DVD, or MP3 player using a stereo mini-plug. If you have a mini-plug port on the IPhone which I believe you have; then attach a male to male plug in between the two devices. Take to Radio Shack for correct line plug.
Feb 09, 2014 | Altec Lansing Technologies Audio Players &...
My ipod touch 4th generations says ipod disabled connect to itunes, but screen is locked
Like all electronic devices, iPods sometimes freeze and become unresponsive. Sometimes iPods lock up when they're dropped on the ground or come in contact with water, but less destructive accidents may also cause them to stop working. All versions of the iPod have a way to reset their hardware should they stop playing music or refuse to turn off.
Check the "Hold" switch on the top case of your iPod to be sure it isn't activated. An iPod will appear frozen and unresponsive if this feature is activated. A lock symbol will appear on your iPod's screen if it is in Hold mode. Switch the "Hold" button on and off once. Place one finger on the "Menu" button and another on the center button. Press both buttons at the same time and hold them for up to 8 seconds. Release the "Menu" and center buttons once the Apple logo appears on your iPod's screen. Try releasing the buttons and pressing and holding them a second time if the logo does not appear, as it can sometimes take several tries to reset a severely frozen iPod. Press and hold the top button and the center "Home" button on a frozen and unresponsive iPod touch to reset it. Hold the buttons for at least 10 seconds and wait for the Apple logo to appear on the screen, then release the buttons. Connect your iPod to its powerblock or a computer if it is still frozen. Wait 5 minutes and then try to reset it. Sometimes an iPod can appear frozen when its battery runs out and just needs a few minutes of power to start working again. Hope this helps.
Jan 19, 2013 | Apple iPod touch 4th Generation MP3 Player
What do i do to enable my ipod touch
To activate your iPod touch, follow these steps:
1. Download iTunes from http://www.apple.com/itunes. 2. Install iTunes. 3. Open iTunes, and connect your iPod touch to the computer using the included Dock Connector to USB cable. 4. iTunes will recognize the iPod and walk you through setting it up.
Hope this helps.
Mar 11, 2011 | Apple iPod touch
I went to use my ipod touch this morning and the touch screen just wont work. The home and hold button work but it doesn't help because it won't let me slide to unlock. I tried holding down the home and...
hELLO THERE:
Many people think that it's a pressure problem, and the fact that the iPod is not picking up the pressure you apply when you touch the screen to perform a task. However, the screen on the iPod Touch is not pressure-activated but rather, heat-activated. This means that when you touch the iPod screen, the sensors inside the Touch pick up on the heat from your finger and follow it to wherever it goes. If it can't pick up the heat, it won't be able to do much for you. Luckily, because it's the heat sensor, the problem can sometimes be very easily corrected.
Oftentimes, this problem occurs when people are outside on a very warm day and are trying to use their iPod Touch. Because the surrounding air is just as warm, or hotter, than the temperature from the tip of the finger, the sensors can't differentiate and so, they don't respond when you touch the screen. So, just move to a cooler place and you should be able to operate your iPod Touch again. Some also suggest turning your iPod off and on and waiting a few minutes before trying again to see if it will work.
Unfortunately, if those solutions don't work for you, you might be out of luck and might just have a defective screen. If this happens, the only solution sadly is to return your iPod Touch to Apple and hopefully, you're still under warranty to get a new one.
Nov 13, 2010 | Apple iPhone Smartphone
Will the apple ipod nano 5th gen. work with this system. Sony AIRSA20PK S-AIR iPod Dock and Digital Wireless speakers
  • Compatibility: iPod mini; iPod nano 1G, 2G, 3G, 4G; iPod classic 4G, 5G, 5.5G, 6G; iPod touch 1G, 2G; iPhone, iPhone 3G, iPhone 3Gs
  • Wireless audio system includes iPod Dock/Transmitter and two wireless speaker systems with LCD display and alarm clock function
  • AM/FM tuner provides alternative to iPod content; multi-zone function means iPod can play in one room while radio plays in another
  • Expandable system is easy to set up, and is compatible with up to ten speakers with the compatible audio receiver
  • Connect to your home AV system with composite audio and video cables for enjoying iPod content
  • May 07, 2010 | Apple iPod nano 5th Generation
    When I plug in my Ipod to the inMotion im310 portable speaker the Ipod screen says it is not supported, and it worked this morning.
    Check the pins on the speaker and on the plugin on the iPod, that's the problem usually. Also, check if the iPod is truly compatible, even if it worked before it may not be. I have seen car chargers for say a 2G iPhone work for a bit then say incompatible, it happens. Here are the compatible iPods for the iM310:
    Plays and charges
    iPod mini;
    iPod touch 1G, 2G
    EJ
    Apr 10, 2010 | Altec Lansing inMotion iM310 Portable...
    Whinning noise when car is on and AUX is connected to ipod
    ENGINE NOISE PLUG ALL YOUR RCA DIRECT TO AMP BYPASS EQ AND SEE WHAT HAPPEN IF THIS STILL HAPPEN CHECK ALL YOUR GROUND AND RCA MAKE SURE YOU HAVE GOOD CONNECTION
    Mar 30, 2009 | Boss AVA-1215 5-Band Car Equalizer
    Apple iPhone Smartphone Logo
    229 people viewed this question
    Top Apple Cell Phones Experts
    David
    Martin Murray
    Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
