Question about Toshiba 32A33 32" TV
My tv controls itself - Toshiba 32A33 32" TV
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Posted on Apr 15, 2010
Suddenly turned off. Why won't it turn on again?
TV Appears To Turn Off By Itself
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMar 12, 2013 - There are four cases in which your TV either turns itself off or appears to turn itself off. These cases are listed in the following table by category.
HELP! My LG LCD TV suddenly turn off by itself and ... - AVS Forum ...
www.avsforum.com/.../1084538-help-my-lg-lcd-tv-suddenly-turn-off-its...
Nov 13, 2008 - 30 posts - ‎22 authors
This morning, I turned it on, its suddenly turn off and on by itself repeatly. I can't even control the tv using the remote again. Then I try the trick ... Samsung TV turns on and off repeatedly before staying ...
Jul 1, 2014
My HDTV Shuts itself OFF then it Turns On by itself ...
Sep 12, 2008
More results from www.avsforum.com
Samsung Smart TV turning off - Forums - CNET
Dec 29, 2015 | Televison & Video
SAMSUNG TV MUTING IT SELF
Hi, you may are having problems with your Remote Controller, try this for the fowlling order:
1?- remove the bateries from the remote controller
2?- turn on the tv with the power button on the tv
3?- wait a little bit, to see if it is mutting itself
4?- if not, your problem may be with the bateries, try new ones
5?- if the tv still mute itself you have a faulty remote controller, buy another one
Oct 16, 2013 | Samsung TV CS29Z40
I have a Philips 42" LED flat screen about 5 years old, all of a sudden when you turn it on I get the settings menu, when I try to click out it will bring up the picture and then within seconds it...
Tv have a shorted IC that control the manual control board side of the tv itself or the manual control board itself it is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish manual control board.Replace the manual tv control board first to test it out.If u still have the same result the IC that control the board itself is dead,now must take to the shop for repair.
Jun 09, 2011 | Philips Televison & Video
TV TURNS ITSELF BACK ON AFTER BEING TURNED OFF
The most common thing is malfunction in your remote control. Try moving the remote control to another closed room, and see if it still does it. If it does... well, I know how to setup a TV to turn itself off after a period of time you set, but how to turn it on? no.
Also something, might be stupid, but I'd tell it anyways, is that someone is fooling you by ór using the remote control, ór having another remote control, and turning it on all the time.
And another thing. By "off", do you mean standby? or actually turned off by pressing the button? Because this is only if it is turned off with the remote control. If it is explicitly turned off by the button, then it might be a malfunction on your tv, meaning you could call the support of the company that makes these tv's, and if it is actually a malfunction, you could get a new tv for free, if your warranty hasn't outdated yet.
That's all I can think of, I hope it helps.
May 04, 2010 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
No control and the picture is too dark
Not sure what you mean by no control?
Brightness settings on any TV made since the early to mid 90's (besides tiny cheap B&W TVs) will have the settings in an on-screen menu. Sometimes the menu is accessible through buttons on the TV itself, but always accessible through the remote control. If your TV does not have the ability to get to the settings menu from the TV controls itself, you will need the original (or compatible) remote control for the set, there is no other option.
It could also be that the set is just dying; it's an older set, and certainly would be a possibility.
Nov 14, 2009 | Sharp 25N-S100 25" TV
TV turns on and off by itself. Volume can't be controlled with remote control and if you push volume control on the TV itself it turns the TV off and on.
The font key switch panel is defective - (usually one of the switches has changed resistance) you can unplug the keypad and just use the remote. You can access the kepad thriough the back panel - but to remove the keypad you have to remove the chassis. Let me know if this helped.
Oct 02, 2009 | Proscan PS60690 60" Rear Projection...
Menus pops up
The menu button on the TV itself is bad and must be replaced ( or removed ). Alternatively the whole front button assembly can be disconnected. Just follow the wire back to the main chassis and unplug it.
Apr 09, 2009 | RCA P61927 61" Rear Projection Television
Sound level unstable
Hi there!
You may have a button stuck either on the remote or on the TV itself. If this does not solve the problem, you may have to refer to a service technician. The IF Amp or the sound stage may be at fault. Good Luck, Regards, JUS004
Mar 25, 2008 | GE 32GT740 32" TV
My TV turns itself off and on by itself.
You have a timer that has been accidently set by someone by the remote control.
If you have an instruction amnual for the tv, it will tell you how to turn off the tv's timer.
Feb 13, 2008 | RCA P52930BL 52" Rear Projection...
Toshiba 32A33 32" TV Logo
55 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
