Question about Dell A940 All-In-One InkJet Printer
The power on printer is flashing and cannot print documents from computer
    Problem Solver:
  • 13 Answers
Reset the printer by umpluging the printer from the wall autlet
Posted on Sep 27, 2009
Printer does not print computer documents
The queue is so choked with documents the printer gets confused and loses its sense of priority. Shut down the printer and disconnect power to clear its memory. Wait a few minutes and reconnect power. Start sending one document at a time to the printer and you should get results.
Mar 08, 2014 | Samsung Office Equipment & Supplies
Print document system responds document is printing system responds that document is printed but no document is printed. Used troubleshooting for alignment and that works with printer?
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 23, 2011 | Lexmark Z816 InkJet Printer
My printer will not print. When you check the status of the document it says printing. When you cancel that it doesn't cancel. DAYS later the document prints all by itself. What's that about?
It's because the print queue is saved on the printer's flash memory. This happens when you don't cancel the queues properly or terminated improperly. To get rid of the issue, always try to give the command slowly and don't over load. If you are printing photos, try to make the file size small so that it'll not take long to spool and prepare for printing.
When the problem occurs, so as follows:
Cancel the queues from the print status box ("Cancel all documents"), if they are not cancelled, then turn off the printer (directly unplug the power cord from the printer), it you still see the printing status, keep on cancelling until everything's gone.
If the problem persists, restart your computer. Definitely the problem will be fixed.
It's also important to press the cancel button while the printer powers On.
Good luck.
Thanks for using FixYa.
Aug 11, 2010 | HP Officejet 5510 All-In-One Thermal...
HP Photosmart. I have a document open in Word
o.k. I believe I can help you with this.
The mysterious printing document huh? many people run into this problem some point in the printing experiences.
This is what I think may be your problem.
You have backed up print jobs in your print cue. Things that you or someone using your computer told your computer to print but never printed out .. maybe your printer was out of paper? maybe you turned off your computer or it lost power before a print job was complete?
THIS IS WHAT YOU DO.
Look to the right bottom corner of your computer monitor. This is your system try. look of the printer icon. Click on it. now
this should pull open a printer task menu.
right click anywhere in the box and cancel all print jobs.
Now resume trying to print your document. It should print out for you.
If you still have problems turn off your printer and computer.
turn back on your printer and then power back on your computer and try printing again. This last step is just a way of refreshing everything in case changes did not take place.
good luck if this was of assistance pleas take the time to leave a kind testimonial. :)
Mar 29, 2010 | HP PSC 1315 All-In-One InkJet Printer
Printer wont go online - light continually flashing green to yellow...
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
May 24, 2009 | Office Equipment & Supplies
Stuck on "all photos option
Have you tried -- turn off machine PULL out power cord from printer  and USB connection wait 2 minutes then plug it back in Check your print dialogue box to make sure you have no pending documents from computer
Apr 23, 2009 | HP PhotoSmart P1000 InkJet Printer
Flashing on/off light on hp deskjet 3520 printer
Introduction The printer lights indicate the printer status. These lights can be on, off, or blinking (flashing), depending on the status of the printer. The sections below describe the most common combinations of blinking lights, how to fix the issue, and how the issue is caused. NOTE: The light patterns included in this document are described as blinking or flashing lights. For the purpose of this document, "flashing" means the same as "blinking." Blinking lights Printer lights can can blink for more than one reason, so the solution can vary. These solutions need not be performed in a specific order, but solutions for the most common issues are presented first. Blinking lights are often accompanied by an error message on the computer screen, which might help determine the solution. Issue: Power light is blinking
c00374282.gif Solution
Close the cover.
Cause
Printer cover is open. Solution
Insert appropriate media in the In tray.
Cause
The printer is out of paper. Solution
  • Change the printer's print mode setting.
  • Change the printer's paper type selection.
  • Use a different brand of label media.
Cause
The printer has difficulty picking up label media. Solution
Follow each of these steps until the problem is resolved:
  1. Remove the paper from both paper trays.
  2. Press the power button once. Wait a moment for the paper jam to clear.
  3. If printing labels, verify that a label did not become detached while passing through the printer. If the paper jam was not resolved, continue on to the next steps.
  4. Remove the rear access door.
  5. Remove the paper jam through the opening at the back of the printer.
  6. Replace the rear access door.
  7. Reload the paper into the paper In tray.
  8. Print the document.
Cause
There is a paper jam. Solution
  1. Remove and then reinsert the print cartridge(s) into the printer.
  2. Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
  3. Manually clean the print cartridges and print cartridge cradles:
    • Open the printer cover and wait until the carriage moves to the center.
    • Press the Power button to turn off the printer.
    • Disconnect power cord from the back of the printer.
    • Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
    • Lightly moisten a cotton swab with distilled water.
    • Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
    • Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
    • Reinsert the print cartridges.
    • Close the printer cover.
    • Connect the power cord to the back of the printer.
    • Press the Power button to turn on the printer.
  4. Calibrate the print cartridges.
  5. If the light is still flashing, replace the print cartridges.
Cause
There is a problem with a print cartridge. Solution
  1. Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
  2. Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
  3. Remove and then reinsert the print cartridge(s) into the printer.
  4. Print the document.
  5. If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
  6. Try printing again. If the problem continues, replace the print cartridges.
Cause
The print cartridge has partial loss of electrical interface with the carriage connections.
Mar 03, 2009 | HP DeskJet 3520 InkJet Printer
Document locked in que
Solution #1 Have you tried to power off the computer itself? The document is most likely locked in the PC not the printer. Unplug the printer's power, power down the computer, wait a minute or so then restart the computer. Once the machine has loaded check the print queue to verify the document is no longer there, if so you can plug the printer back in and the issue should be resolved.
Solution #2
From the Start menu, select Control Panel. Then follow this path:
Administrative Tools > Services > Print Spooler
Once at the Print Spooler, right click on it. Select Stop. Leave this window open. Turn off your printer.
At the open Print Spooler window, right click on the Print Spooler, and select Start.
Go to the Start menu, and select Printers & Faxes. Find the printer you are having problems with and double click on it. From the menu, select Printer, then select Cancel All Documents. The documents should clear.
Turn on your printer. You sould now be able to print.
Oct 15, 2008 | HP PSC 1350 All-In-One Thermal Printer
Dell A940 All-In-One InkJet Printer Logo
57 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
