Question about Whirlpool Duet GHW9150P Front Load Washer
I have the same problem w/holes in clothing from "Duet" system
Repair service could find nothing wrong w/equipment. I have a basket full of ruined clothes.
  • 26 Answers
Whirlpool duet washer is putting holes in clothes. The gap between the stainless drum and rubber bellows is about 1/2 inch. Do I need to replace the bellows or the drum?
Tearing or holes if tearing pull the bellow forward and inspect the lip of the front tub for rough spots place your hand in the basket and see if you can push upward looking for play should not have any if so tub bearing worn of holes take a flashlight and inspect the SS basket looking for raised dimples.
Sep 04, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet is about one and half years old and starts making a loud metal to metal noise while trying to start after the water had run in. Clank, Clank, Clank Loyd
Hi Loyd.
If the metal noise is like rattling, as first thing check the object trap located behind the trim at the base of the washer. Check also through the basket holes and inside the tub if there is any foreign object stuck that may be causing the noise.
From the description the noise looks more like that of a broken spin basket support, which is a common fault on Duet. This fault will result on a rithmical loud clank that occurrs more or less when the basket is passing through the same position.The basket supports are located at the back side of the basket.To reach the part an almost complete disassembly of the appliance is required. The spin basket and its support is covered by long term warranty (ten years or lifetime).
Call Whirpool at the number listed on the manual, tell them the symptoms and eventually mention that a technician suggested the problem being the basket support, and check conditions for repair. The repair will be probably covered by manufacturer.
Regards.
Ginko.
Dec 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Clothes are getting torn in the washer. How do
check the fins in the washer,and run your hand in the washer make sure there is nothing caught in the basket
Feb 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Thumping noise when drum is rotated with out cloths
The supports for the basket assembly are broken. The basket needs to be replaced. Rather expensive repair. Basket lists for about $200. Plus labor
Jan 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet ht, motor running but nothing happening, says 48 mins to go, cancel does not work. Have unplugged but will not reset. Left over night unplugged, stiil not reset. Cannot open door to even get...
Our Duet washer (5 years old) would not pump the water out, and would not spin. It displayed no error codes. Tried reset, would cancel but still not work. I started disassembly (found the Whirlpool maintenance/ repair manual on line to refer to); everything seemed to check OK. Cleaned filter, fortunately the washer sits on a pedestal drawer as the washer had at least 3 gallons of water in it I had to drain into a bucket. As I went through the diagnostic test sequence found in the repair manual it was apparent that although the pump had power and made noise, no water pumped out. I removed the pump assembly and found the remains of a small plastic baggy fouling the pump impeller. It was left in a clothes pocket and run through the washer. No idea why the filter basket didn't stop it. Pulled baggy out with needle-nosed pliers and presented it to my wife (her baggy). Reassembled and all works great. No cost, actually made 1 cent on the penny found in the filter basket. You need a Torx screwdriver to access most of the panels. Reason for not spinning was the massive weight of wet towels and water sitting in basket.
May 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have been getting brown stains in the shape of a line on items of clothing washed in my Whirlpool duet washer. I can not get these stains out with anything and they are ruining numerous items of...
I have been getting brown stains in the shape of a line on items of clothing washed in my Whirlpool duet washer. I can not get these stains out with anything and they are ruining numerous items of clothing. I have no idea what is causing them - I have manually cleaned the inside of the washer. same thing here. I have been having this problem for a few weeks, cant wash anything white without ruining it.
Apr 23, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Washer is ripping my clothes
yep, I have that problem too. My son's winter coat got wripped to shreds.
Apr 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Something caught between the Tub and asket. How do I get access?
iots only 1 trick i know..taking that this is a piece of clothes..take the bottom front panel off..ane remove the tub to pump sump hose,,that will give you a 4 to 5 inch hole to work form..try and push what ever it is towards hole...onthejob
Feb 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Banging while spinning and disintegrating gasket
Most likely not the drum bearing on this one.
I believe that your inner basket support has failed. It's a common problem on 4+ year old duet washers. This is by far the most labor intensive repair that can be done on the duet washer. You will need to tear down the machine for this repair. Expect it to be a four to eight hour job depending on your level of skill.
The basket is under lifetime warranty. The new basket will come w/the basket support already attached to it. Stupid as it sounds, You can't buy the bolt-on basket support alone, You need the entire basket! wtf?
The front section of the outer tub is supposed to have a 10yr warranty. Being that the tub was damaged by the basket, They may or may not warranty the parts.
Do a search on fixya. There is a guy from MA that has a complete set of pictures and info on the rotted/broken basket support.
Jan 02, 2009 | Whirlpool GHW9100L Front Load Washer
My washing machine is "eating" my clothes!
ck the plastic fins in basket for broken/sharp areas
May 28, 2008 | GE WBVH6240F Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
570 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
