Question about Maytag Dryers
Maytag MDE3000AYW drum wont turn. The belt is broken but the the drum wont spin when turned on. Where does the power come to the drum to spin? Is the belt the only problem area?
    President:
  • 1,304 Answers
Yes you need the belt to spin the tumbler
Posted on Oct 03, 2009
Why dryer won't tumble?
The belt could be worn and stretched.
Jul 20, 2014 | Maytag MDG2706A Gas Dryer
Drum wont spin
if dryer start but drum wont spin the you may have a motor pulley broken or a belt or idler broken. you have to open dryer to find out. some Maytags recently had problem with the motor pulleys but at factory they are making the changes to it on the new ones.
Feb 14, 2011 | Maytag SDG3606A Gas Dryer
Maytag Neptune MDE3000AYW. The start button on my dryer went out. It tried to start and then died and smelled burnt. I am guessing the switch burned up. Any thoughts on how to fix it? Thanks
sounds like motor is in a bind see if you can rotate drum by hand if you cant then your belt is hung up,or a belt pully is bad,if drum turns freely,sound like motor is going bad
Jan 23, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Samsung dryer drum wont turn
most likely a broken belt. There is a micro switch on the tension pully that opens when the belt breaks preventing the motor from spinning when the belt breaks.
Jul 26, 2010 | Samsung DV218AEW Electric Dryer
Maytag dryer wont spin It makes heat,but the dryer wont spin
Sounds like the drum belt is broken or off the pulley of the motor
Sep 25, 2009 | Maytag Dryers
Dryer stopped spinning,timer still ticking,cannot get to restart.
Can you still hear the motor turning? If the motor is running but the drum is not then it is probably a broken belt or there may be something blocking the drum from spinning. The first thing to check is if the drum will turn by hand. If so, the next thing to check is if the belt has broken or slipped off. Although it is a bit cumbersome to replace, it is easy to diagnose. Unscrew the screws holding the back of the dryer on and pull the cover off. Look at the pulleys on the motor and see if the belt is intact. If those solutions don't do the trick, let me know and I will try to give you other options.
Jun 03, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Power on but it won't spin.
You have a broken drive belt. To access the belt you have to remove the back metal cover.
The no heat problem could be a heating element or safety thermostat. These are also located under the back metal cover.
Jun 02, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag mah4000aww drum wont spin
No - it is likely the key for the pulley that has broken.
You'll need to remove the pulley to see if the keyway is damaged. If so - you'll need to change the motor.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 31, 2009 | Washing Machines
Maytag coin-op top load wont spin, motor runs, belt burns.
it not a belt, there is a $20 plastic and rubber coupling between the motor and the transmission that has broken.  It needs replacing.
Dec 25, 2008 | Maytag MAT12CS Top Load Washer
Dryer Drum Won't Spin
Reach inside and grab ahold of the baffle. Try to spin the drum, it should have resistance. If it spins freely you have a broken belt. Hope that helps. Dave ww.washermd.com
Dec 16, 2008 | Maytag Dryers
Dryers Logo
206 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
