Question about Sony FD Trinitron WEGA KV-36HS420 36" TV
Just started flickering and then black screens - still hear audio, just not picture. Turning it off for awhile lets it come back up..for awhile.
  • Ted Bascomb Sep 27, 2009
    Thanks Chu for the response. I want to try it asap. Does anyone have a good place for ordering parts for this model? Thanks, h
  • Sony Master
  • 8,457 Answers
Ur high voltage is dying,it the FBT,the flyback transformer is cold solder or dying.The big black block of plastic with a red wire with a cap that hook to the CRT(tv tube).That the cause.
Posted on Sep 27, 2009
  • Chi Chu Sep 28, 2009
    Tries Servicemanuals, vstore.ca, Tv Repair.com,Sopjimmy.com,Partstore.com or Ebay.com webesites.Should have the part.
4 Suggested Answers
  • 4 Answers
SOURCE: jvc av-27730 27"
IN THIS SET THE FAILURE IS A COLD SOLDER IN THE VERTICAL OUTPUT HAVE THE SET TO RESOLDER THE VERTICAL OUTPUT WITH A TECHNICIAN.
Posted on Nov 01, 2006
rey jr
  • 149 Answers
SOURCE: Shrinking screen.
hi there, you do have a vertical section problem and at the power supply section problem. do some test, check for some cold solder at the power supply section, test some electrolytic capacitor at the vertical section. ty
Posted on Jan 01, 2008
  • 1694 Answers
SOURCE: The tv works however the picture dissapears/ flickers off but comes right back immediately...happens constantly
Picture tube ( CRT ) is defective = re-juvenation may help for
a temporary fix...................................T.
Posted on Mar 28, 2008
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
Samsung HLM507 FLICKERING PROBLEM
how extended is that warranty, and what does it cover? Sounds to me like a classic video controller board about to fail.
Mar 24, 2008 | Samsung DLP HL-P5663W 56" TV
Toshiba will not boot
It needs those things to start up. If you reinstalled them in the machine and it won't start up you need to check some things:
Does the screen flicker when you power it on or does it stay completely black? If it stays completely black, then the connection from the screen to the computer itself is lost. Normally it is caused by a broken cable.
If the screen flickers and then goes black, then check the following:
Does it beep at you? If it does, then the amount of beeps is important. It will state in the users manual what that numbers mean.
If it doesn't beep, then my best guess would be that there is something wrong with the power distribution in the machine.
Sep 07, 2014 | Computers & Internet
TH-42PX75U horizontal lines (flickering black and white)
The controller board for the screen is going bad. check shopjimmy.com for replacement parts. It's not a difficult job to do. Once the back of the TV is removed, you'll see it near the center of the screen.
Feb 21, 2014 | Panasonic VIERA Televison & Video
Black Screen
If audio is present, the picture should also be there. If not, check the video output section circuit for fault. Check all the solder terminals for any loose soldering to this board. Audio output board can be located at the neck of the picture tube, will directly plugged on to its back. Re-solder all the suspected solder terminals; by applying a little more solder.
google.com/+GopakumarGopalan
Nov 07, 2013 | Ktv Televison & Video
I have a 32" RCA LCD tv , rlc3210 power input says
Is it hooked up with HDMI cable?
If so try unplugging the HDMI cable and re plugging the cable in, sometimes those cables work loose and if they are not tight, it will cause your screen to flicker. Happens to my TV once in awhile.
Aug 23, 2013 | Televison & Video
Samsung 226bw visible flickers just after it is turned on
You may have a faulty inverter or loose power inverter connection. OR
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Aug 31, 2009 | Samsung 226BW Monitor
Shrinking screen.
Jan 01, 2008 | Televison & Video
Picture Brightness Flickers
could be one or more of three things.
1.could be the crt itself.(sony had a bad bunch of crts for this model)
2.could be the vertical ic on crt board.
3.could be the focus block
in my experience solutions 2 and 3 are more common....
Oct 19, 2007 | Sony KP-51WS500 51" Rear Projection...
Sony FD Trinitron WEGA KV-36HS420 36" TV Logo
157 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
