Question about Tappan TGF320 Gas Kitchen Range
We just bought a new Tappan gas range. We turned the oven on to use it and there is a strong, disgusting chemical odor, so strong I was nauseaous all day. Is this normal?
  • 1,531 Answers
No this is not normal. you need to check the gas lines and make sure there are no leaks. the insure that all the plastic and tape has been removed,if need be set it up for service
Posted on Sep 27, 2009
Self cleaning oven
After the self cleaning process you might see i wight powdery residue. This can be cleansed out with a damp cloth. No chemicals should be needed. If you use household cleaners you may have some odore when you use your oven so I would just use a damp cloth.
Apr 04, 2014 | Tappan TGF320 Gas Kitchen Range
I have a new verona gas range, tonight we lit the oven and it smoked for 20 minutes with a harsh chemical odor, is this normal? I had to turn it off.
sounds normal. most ranges have 2 hr (give or take) burnoff period when it is first used when it burns off any residual chemicals from factory. just make sure you've taken all plastic/packaging and wipe down the interior first.
Jan 16, 2011 | Frigidaire FGF378AC Gas Kitchen Range
My gas oven overheats and burns my baking. With one temperature test it was set at 300 and within thirty minutes the temperature was reaching 400 and leveling off. However, the next test with the oven at...
bad thermostat.....buy new at lowes .....its inside the oven.....usually at the top of oven..looks like copper rod with copper wire ....easy to change...buy at lowes or homedepot
Nov 16, 2009 | Tappan TGF320 Gas Kitchen Range
OVEN PILOT WENT OUT
hopefully the gas smell isn't too strong and posing a hazard to you. If it is, reach behind the range and turn the valve until it is across the gas line and not parallel to it. You should be able to raise the top of the range from the front and see all the workings underneath. There you will find the pilot light.
Feb 14, 2009 | Tappan 24 in. Freestanding Gas Range...
Oven gives off strong chemical smell when it is turned on.
Hi!!! yes ignitors can go bad again its like a light bulb..its located underneath your stove..Good luck..
Just remove the 2 screws which hold it from the burner and cut the wires that go into it the new one comes with the 2 wire cap and instruction easy fix..Good luckk..
Jan 04, 2009 | Maytag MGR5751AD Gas Kitchen Range
Strong Foul smell coming from oven only when I turn it on
do you have mice.they will tunnel in the insulation.you know what they do next,well then you heat that up and theres your smell
Dec 31, 2008 | Magic Chef 9122 Gas Single Oven
Constant Gas odor
Constant gas odors is nothing to let go. You should have a technician check it out right away and turn the gas off to the unit.
Oct 07, 2007 | Tappan TGF320 Gas Kitchen Range
Tappan gas oven
This is usually caused by the volume of gas expelled during the lighting process, ie bofore the flame has established, it should be nothing to worry about but check it ignights quickly to resolve problem. Regards Engineer
Jan 02, 2007 | Tappan TGF320 Gas Kitchen Range
Tappan TGF320 Gas Kitchen Range Logo
134 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Sal DeAngelo
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
