Air conditioner never shuts off and it does not cool to the temp that the thermasta is set at.
Low suction pressure, it needs to be charged, but check for leak first
Posted on Sep 27, 2009
Troubleshooting
If by "not shut off" you mean the blower keeps running, that is normal operation. The blower only shuts off when the system is turned off.
When in cool or heat mode the room temperature is sensed in the units return air which requires air movement by the blower.
Dec 11, 2013 | Mitsubishi MSH17TN Air Conditioner
I have Royal Sovereign ARP-1000ES Portable Air Conditioner. Last a few days, it shut off When running with cool mode.(no problem with dehumidify or fan mode) I checked water tank, but it's empty. Please...
It is supposed to shut off when the room meets the temperature you set it for. Are you saying it shuts off before the room cools to the temp you set it for?
What do you mean "..last a few days...?" Is it new only a few days and then break?
Be clearer if you need help.
Oct 18, 2013 | Heating & Cooling
Fan shuts off when weather cools down
Some units use an outside temp sensor to control the outdoor fan for cooling for better operation and will shut off the outdoor fan when it gets cool outside.
Jul 17, 2011 | Goodman CKL36AR36 Air Conditioner
I have an AEW10AN model and the air conditioner keeps running but no air is coming out. The temp keeps fluctuating up and down. I've tried regulating the temp to keep the room at 70 degrees, but after...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Aug 30, 2010 | Heating & Cooling
My ac will not stay on when its at a certain temperture or auto. only if its in on position
this is correct because if you set it to certin temp. when it reaches that temp. it will shut down to prevent over cooling when the temp in the room goes up a preset amount 2-5 deg.(preset by manafatuer) the unit should go back on to drop the temp. to your set temp. Auto works the same way, where just on will cool to the temp the system can cool efficently.
Jul 31, 2009 | Heating & Cooling
If you set the temp to 74 it will not cool down to that temp the compressor will kick off on eather the energy or regular mode lg model number lwhd1009r
compressor shuts down air is cool but unit does not stay long enough to cool lower the thermostat down little lower if the compressor starts up then bad thermostat
May 19, 2009 | LG Heat cool Window Air Conditioner
Furnace burner turns off and on
The furnace is likely over heating and the high temp. safety is shutting it down. It then cools and starts again. Things to check: Filter, Blower wheel and indoor A/C coil. If any or all are dirty you are limiting air flow and need to clean them.
Jan 17, 2009 | Carrier 38CKC042 Air Conditioner
Air conditioner won't shut off when temperature reached
suspect a stuck contactor on condenser unit or cooling relay stuck
Jun 14, 2008 | Kenmore 72055 Air Conditioner
Heating & Cooling Logo
76 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
