Question about Frigidaire Affinity ATF7000E Front Load Washer
Fridgidare affinity washer will not spin, makes a growling noise
Washer will not spin, makes a small growling noise instead, leaves a about an inch of water in the bottom.
  • 1,531 Answers
Use a shop vac and attach it to the end of the drain hose remove all the water then you need to check the drain pump and see if there is anything blocking the pump.
Posted on Sep 27, 2009
Mywashermakesahummingnosieandwontspin
Good Afternoon Friend,
I understand that your Frigidaire Affinity washer, model# ATF6000F, is making a humming noise and will not spin. If your load is too small, this can cause your washer to not spin. Add a couple of similar items to help balance the load. On the other side, your washer could be overloaded. Try taking out some items and restarting the cycle. If neither of these is effective, try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. When power is restored, run any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 28, 2014 | Frigidaire Affinity ATF6000F Front Load...
Makes a loud noises when spinning
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Sep 25, 2011 | Frigidaire Affinity ATF7000E Front Load...
Having bad vibration issues on spin cycle.
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
heatman101
Jan 18, 2011 | Frigidaire Affinity ATF7000E Front Load...
Washer drum made a ratteling noise when on a spin cycle and looks like it fell off the mount. Does not spin freely when you try move it with your hand.
heatman101
Sep 15, 2010 | Frigidaire Affinity ATF7000E Front Load...
Washing machine makes a horrible noise in spin cycle and turns itself off. When we hold the Start and Cancel button together we get code E23.
heatman101
Sep 04, 2010 | Frigidaire Affinity ATF6000F Front Load...
Fridgidare Affinity washer door won't open after wash cycle
Try the following site for full information on unlocking Dryer -------
http://www.freepatentsonline.com/4908957.html
Sep 14, 2008 | Frigidaire Affinity ATF7000ES Front Load...
TERRIBLE NOISE ON SPIN CYCLE
That is normal, after a little while all washers make that horrible noise you should be able to put up with it
Hope this helps! - Josh
Feb 03, 2008 | Frigidaire GLWS1233A Top Load Washer
Slow to spin and making a loud noise.
Control boards don't growl, the fry out and die. Sounds like a drive train problem to me. If it's a front load machine, the spindle/bearing assy. has gone to washer heaven. If it's a top load machine... could be the transmission, brake/clutch assy. or the tub bearings. In either case, if it's less than 5 years old, the drive system will be warrantied through the manufacturer. If you could provide a make and model number, I could narrow this down to a fine point.
Dec 15, 2006 | Kenmore 43142 Front Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
458 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
