Question about Price Pfister 548E0BK Catalina Double-Handle Centerset Lavatory Faucet with
My water supply has little pieces of grit that clog up the strainer in the Price Pfister 548E0BK faucet. I periodically clean out the grit. Recently the water flow rate decreased, and cleaning the strainer only partially fixed the problem. I disassembled the cold water valve and remove some particles from the valve and that fixed the issue with the cold, but the hot still flowed a little slow. I disassembled the hot found a "Do Not Remove" which I ignored found and removed some particles from the valve; this solved the slow flow, but now the hot water will not stop driping. What is special about the hot water valve on this faucet and how do I stop the drip?
    President:
  • 3,433 Answers
'DO NOT REMOVE"! lol JUST KIDDING. >You may need to remove again to find out why the valve seat is not sealing In fact, expect that you will. The grit is white in color? did you see any special washers or seals in the DNR zone? wHEN REINSTALLING THE VALE BODY, YHE STEM SHOULD BE ALL THE WAY OPEN . cLOSE THE VALVE ONLY AFTER ALL IS IN PLACE. AND YOU NEED An INLINE STRAINER IN YOUR WATER SYSTEM.. gOOD lUCK _nED_
Posted on Sep 27, 2009
About a week ago it suddenly dropped water pressure by half, what do you think is causing this problem? We have had the faucet since 2013 with no problems
there may be garbage in the strainer. unscrew the strainer where the water comes out and check the screen inside there. it could have a partial blockage
Aug 16, 2015 | Price Pfister Marielle Kitchen Faucet with...
Water shoots out of my faucet, now can I plug it?
water is supposed to come out of your faucet...in a controlled fashion....if its at the handle....remove the handle and locate the source....tighten the packing gland or replace a seal. if it sprays all crazy at the spout...try unscrewing the little piece on the tip of the spout (aerator)....flush your faucet by running the water with it off...then flush out the screen on the aerator and re-attach it...hope I was some help....good luck and always know where and how to turn your house water supply off before working on any pressure points on your water supply system.
Oct 19, 2014 | Price Pfister Marielle Kitchen Faucet with...
Price Pfister hot water runs slow
Check the supply line and valve to see if any dirt or foreign.matter got into the line or valve when you changed out your faucet. if this is not the problem you may have a faulty faucet. You may be able to back flush the faucet with a garden hose by leaving the hot side open, but you will get wet. If you used Teflon tape on the supply line and it is a compression fitting, some of the tape could be blocking the water. for more info go to waterheaterflush.com
Oct 16, 2012 | Price Pfister Plumbing
Re: single handle lav. Ashfield: cold water flow is fine; hot water flow severly restricted. Have disconnected supply tube and flow is fine into a bucket so it is not a problem with valve or supply...
I have the same problem with my Ashfield faucet.
I am going to contact Price Pfister and try to get a new 'cartridge'.
On another note, my Ashfield towel rings are also broken. The connection where the two pieces meet is so weak it cannot handle daily use. I am going to bring this up with Pfister as well.
It doesn't seem like Price Pfister has very good products.
Dec 31, 2010 | Price Pfister Ashfield Single Control...
I have a kitchen faucet with a white pull out handle for dishes and sprays. The water flow keeps slowing down. When I take off the aireater screen there are whit pieces of white flat pieces in it. I can...
white pieces are calcium chips coming from your hot wtr htr..thru the hot water tubing..shouldnt have to take faucet apart as calcium chips get caught up in angle stops or supply hoses
Nov 21, 2010 | Price Pfister Plumbing
I installed a Price Pfister kitchen faucet model low water pressu
yes it should have a flow restrictor in the end of the spout. You might need to clean it out
Mar 08, 2010 | Plumbing
Faucet losing water pressure
The FIRST thing is to remove and flush the aereator strainer on the spout.
Check by unscrewing the strainer and run the water. If it is STILL slow, then divertor valve may be clogged.
The divertor is USUALLY in the tower that the spigot pivots in. They are sometimes a little pintle type valve on the side once you remove the pivoting spigot. Handle has to be removed and then a ring that holds the spigot on removed.
When re-assembling use a bit of plumber's grease on the O rings.
Sep 15, 2009 | Plumbing
No water out of kitchen faucet or sprayer
sounds like the little device on end of spout is clogged remove and clean or replace
May 06, 2009 | Price Pfister Marielle Kitchen Faucet with...
New Pfister Avalon Install: Spray Hose Works, Faucet doesn't
sounds like your diverter is stuck or improperly installed ,try tapping at diverter location to free up diverter the other thing to try is remove the little device on the end of spout make sure its not clogged with debri
May 04, 2009 | Price Pfister Marielle Kitchen Faucet with...
Need manual for Price Pfister Catalina 548-EOBK. Where Do I find
Just kept checking other websites until I found the manual I needed.
Nov 22, 2008 | Price Pfister 548E0BK Catalina...
Price Pfister 548E0BK Catalina Double-Handle Centerset Lavatory Faucet with Logo
287 people viewed this question
Top Price Pfister Plumbing Experts
john h
Mike
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
