Question about Motorola Mobility RAZR V3i Cellular Phone
Display screen is not coming on but the phone is working well otherwise
I have one Nokia e51. the problem is, when i turn on, the phone start but on the display i can't see nothing. i change the display with no result So the light from the display is working but the image...
does the phone still function normally otherwise? It sounds like what we call "the white screen of death." Basically, the wiring for the screen is shot but otherwise the phone is pefrectly fine. Very common on flip and slider phones.
Oct 06, 2010 | Cell Phones
My cell c510 have display problem i mean the display is doubled in the screen and sometimes distribution of various colous takes place on the screen pls help me out for this .......its only two months...
The problem is with display... go to sony centre.. as ur phone must be in warranty period... get it fixed... otherwise... display will come for around 1300-1400 Rs..!!!
Aug 19, 2010 | Sony Ericsson Reusable Screen Protector...
Iphone dim display , phone works fine otherwise
Hi, did the phone fall on the flow or hit something? If yes, that might have been the cause of the dim display. Cause the screen has been affected and you will need to replace the screen.
After dim display, if the phone blinks or show some funny moving display, that means is the flex that connects the front screen board to the main board of the phone that is faulty and it will need to be replaced.
Take care.
Jun 08, 2010 | Apple iPhone 3G Black Smartphone
Nokia N70 is display prb, white screen
The problem is inside the printer. Turn off the printer and open the replacement ink compartment- move the inks holder far to the left- use a torch to check where the inks holder home and you'll see that there is a sponge a tiny rectangular shape come loose -use the twiter and put back in place (holder).
http://www.fixyourownprinter.com/forums/inkjet/39177
Apr 28, 2010 | Nokia N70 Cellular Phone
6280 screen light not working
there is a problem in your hardware of mobile.your phones Display IC is having a problem. Consult a nearby vendor and change your phones display IC
Apr 19, 2010 | Nokia 6280 Cellular Phone
C905 reversed upside down screen
I have a Sony Ericsson c905 phone and the screen is perfect, but upside down on all applications. Otherwise the phone operates normally. How can I fix this?
Mar 06, 2010 | Sony Ericsson Cyber-shot C905 Cell Phone
Display screen went black---otherwise, phone still works
display flap strip problem change it . it is also called as display flap PATTA
Aug 26, 2009 | Motorola Mobility RAZR V3
Hello -need help with phone
Hi Nick,
There are no intensity adjustments I know of, and from my experience if the backlight is still working, but you get no display, it is either a bad display, or many times corrosion or a broken solder joint/component. I wish I could help you correct the problem with a few pushes of a button but not in this case. We do fix those models, you can check us out at www.cordlessrepair.com Thanks, CG
Nov 06, 2008 | Panasonic KX-TG2357 Cordless Phone
Display gone
go with warranty card! or otherwise change display screen!
it comes near to thousands rupees!
Jul 01, 2008 | Motorola Mobility L6 Cellular Phone
Display problem
i also have the same problem...white screen display
May 26, 2008 | Nokia N70 Cellular Phone
Motorola Mobility RAZR V3i Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
