Question about Janome Memory Craft 5700
New Janome 6600 Erroring out
I've only had the machine a few weeks, probably have less than 4 hours sewing time and it errored out E5, I tourned it off for about 20 min came back and sewed a few stitches again E5. The manual advised to take in to the dealer which I did a few days ago no word yet any ideas?
  • Janome Master
  • 1,388 Answers
This is the official Janome reference to your E% error message:
Feed sensor error "E 5" appears when the machine is turned backwords slightly while the machine runs over tight spot. The above will happen when - the machine is locked by thread jammed in the machine. - sewing extreamly thick fabric. In case of the MC4900, it will happen when running without threading the thread take up lever. The thread take up lever should be threaded when the threading light lights up.
Hioe this helps
Bargain Box
Posted on Jan 02, 2010
I can't turn the handwheel on my Janome 6600 it's extremely tight and causing my machine to stop sewing
If it has been maintained regularly it will probably need service. If it has not been cleaned and oiled on a regular basis I would try to do that first.
Jun 03, 2018 | Janome Sewing Machines
My Janome sewing machine started jamming up the stitching and coming unthreaded, What is causug this to happen?I have a janome memory craft 6600.
a. needs cleaning.
b. needs some type of adjustment.
c. needs lubrication.
d. needs to go in for trained repairman attention and possible parts replacement. knowing the age and approximate number of hours operating time could be useful info to a repairman.
Feb 11, 2018 | Janome Sewing Machines
Janome mc 6600 manual was lost in a recent move, can I download one online? I found one for the 6600P but not the 6600 - would the manual be the same for both machines? Thanks much!
You can probably compare the features and pictures of the two machines. More than likely, the manual would be sufficient for you. Most of the time, the only difference is that one machine may have a couple of additional features or accessories.
Aug 10, 2017 | Janome Sewing Machines
My new Janome 6600 has Error 1. It maybe a blown fuse. I live in remote WA no sewing machine repairs here. Has anyone attempted this. Is this something I can do myself ?
Search for:
Make Model Error 1
also if you look in the manual's Troubleshooting Section, it will probably tell you what the problem is and how to fix it.
Jun 24, 2017 | Janome Sewing Machines
New home Janome 2039 sewing machine
if these suggestions don't help then the machine needs to be
checked for a timing problem
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Mar 29, 2013 | Janome Harmony 2039 Mechanical Sewing...
Janome memory craft 6600p
sounds like it needs to be checked by a technican
Feb 27, 2013 | Janome Memory Craft 9000 Computerized...
I have lost the instruction manual
check out this previous solution on your model Janome
http://www.fixya.com/support/t306170-new_home_janome_harmony_2039
I've looked in all the usual free manual places and on the Janome website and can't see it listed so probably best to go to the source, Janome themselves.
Nov 28, 2011 | Janome Harmony 2039 Mechanical Sewing...
Oiling a Jonome 6600
Remove the plate and bobbin case, beneath it will be a small round hole in the center. Inside the hole is a fluffy piece of absorbant material called the wick. DO NOT REMOVE IT! Place one drop of sewing machine oil on the wick. While you have the machine opened up, you should remove all the dust. I use the small brush that comes with the machine. Replace the bobbin case and make sure that it is clean too. Replace the plate. Lastly add a couple of drops of sewing machine oil to a q-tip and use it to apply oil to the needle bar above the needle clamp.
If your machine continues to squeek then bring it to a professional sewing machine repair technician and pay for the service to have it professionally cleaned and tune up. It is not worth damaging you machine over a few dollars well spent.
Oct 27, 2008 | Janome Memory Craft 5700
Sewing Machines Logo
968 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
