Question about Philips HTS-6500/37 System
Clicking noise on Multitech/Dolby setting
I get a clicking noise every 30 secs or so on the above setting when running the tv sound through the system and also off dvds. Its really annoying as this is by far the best sound setting especially for music. I have a Philips plasma bought at the same time and a HDMI cable linking them. I have tried the speakers in every possible position so its definitely not interference due to the speakers being too close to the TV. Please has any one any ideas or is it just a fault ?
  • 3 more comments
  • oldvinny Dec 26, 2007
    Yeh I had it from the beginning but just never got round to taking it back but busy life an all that ... I know I should. I have tried it on scart and 2 brand new HDMI cables and still the same. There are loads of wires though at the back so I'll try separating them out but seems a long shot to jsut be that ?
    I'm on vs 36 does this make any difference to the upgrade you have given me the link to or does this have all previous upgrades contained in it ?
    Sorry in advance being totally dim here .... I have downloaded the file so now have a "bin" file on my pc which I cannot read ... I have Media player so can burn cds but do I have to go and download Nero (148 meg worth) or Easyvdcreator just to open the thing up as the instructions make no reference to Win Media
    I have moved all cables so that the HDMI from TV to DVD does not touch anything else. I'm struggling to get the version upgrade from Philips working though .... its a bin file which I don't recognise do I have to have Nero or Easy to be able to do something with it ?
    The clicking noise is just on this one particular setting Mulitech/Dolby .... all other sound settings are crystal clear
  • 790 Answers
Hi ,
Will u hear that clicking noise every 30 sec exactly or it depends on the sound ??? reply
Posted on Dec 26, 2007
  • Kanth raj
    Kanth raj Dec 27, 2007
    Just try to hear the sound from where exactly its coming .. I guess its just woofer black paper has a small damage which create noise for the particular dolby setting ..
    President:
  • 1,944 Answers
Did you experience this from the start (since the first time you used it) or did it started just recently? Check that the HDMI cable is connected properly at both ends and it's not near/touching any other cable or power supply. After checking this and if it is still there then it could be a fault with the cable. If you have another cable to try, that would be great.
  • Damen Wong
    Damen Wong Dec 26, 2007
    Did you try unplugging the unit for a few hours? Also, did you try a firmware update? If not you can get the update here.
  • Damen Wong
    You can use Nero to burn the bin file
There is a noise coming from my dashboard over the glove compartment of my lexus is 250
if it sound like clicking noise,most likely is the a/c servo motor. you need to inspect which one is it, because there is like 3 of them
Oct 09, 2014 | 2008 Lexus IS 250
Philips TV making a strange clicking noise
A model number would be helpful to answer this but:
This clicking sounds (no pun) like either a mechanical relay in the set's power supply or possible arcing somewhere in the set.
These sets also have a shutdown feature that if engaged may sound like a tic-tic sound.
Let me know model number which is not indicated on this question here.
Jun 03, 2012 | Televison & Video
I got a 52" zenith
No,the tv message said replace lamp wright?Yes,mean the tv projection lamp is the causes and the problems.The tv projection lamp life span have ended that why the tv it is not holding a stable tv projection lamp picture.All throught these causes,does the tv make alot of clicking noises too,when the tv projection lamp is it on for 30 sec.and shut it self off?Yes,than the board that call the Ballast board it is also dead too.This Ballast board only job are to ignite the tv projection lamp only.Tries websites like Partstore.com,Ebay.com to buy a new tv projection lamp and a new Ballast board too for the replament too,if this tv causes have alot of clicking noises,when the tv is trying to ignite the tv projection lamp.
Aug 09, 2011 | Zenith D52WLCD 52" Rear Projection...
Sound works everywhere except the games
I had this exact problem when I first got my Dolby Digital 5.1 Surround Sound. Disregard what others have said, though it would make sense to check all formats, that is not the case here. De-select all formats except Dolby digital 5.1. There should also be 2 formats that you cant make unchecked, but don't worry about those. Now go into your game, if you begin to hear a loud static/clicking noise, cycle between optical and another setting on your receiver until the sound from the game is clear. For some reason, the PS3 cannot decode sound through optics correctly.
Aug 24, 2010 | Sony Playstation 3 (PS3) Console
My Magnavox plasma screen tv, model number: 42MF237S/37 makes a clicking sound when I try to turn it on. No sounds, no picture, just the clicking noise. Things I have tried so far: 1) Turning the TV off...
You either have a cold solder joint in your horizontal deflection circuits or your or in your horizontal output circuit. please be careful due to the fly-back transformer still holds power even unplugged until you discharge it.( ground it out). Hope this helps.
Jan 03, 2010 | Philips Magnavox 27MS343S 27" TV
TV and Sky hd to samsung HT-Z310
connect 1. cable/satellite box to TV with HDMI. 2. cable/sat box to sound system using optical cable. 3.change box sound setting to optical/dolby.
Jan 22, 2009 | Samsung HT-Z310T Theater System
Onkyo digital reciever has poping noise when in dolby sound
I have the same reciever, and had the same problem.  Contact Onkyo, this is a known issue where defective DSP chips were used and manifest problems with a popping / clicking sound when using surround settings.  These receivers also have a Dolby Digital input issue that can cause audio dropouts when watching cable or SAT broadcasts that encode DD using a 'newer' broadcast encoding methods.  Onkyo is covering the cost of that repair for me now, even though the receiver is 5 years old now....
Jan 02, 2009 | Onkyo TX-DS797 Receiver
When playing a dolby true hd soundtrack my Onkyo 875 makes a clicking sound every so often like it has run out of buffer memery for the sound. Any help you could give me would be great Thanks
What you are hearing is digital noise that can have many sources. One thing that would help to narrow this down is to try and see a pattern of when the clicking occurs. Is is all the time, or just after the unit has been on for a while? Does the clicking vary with the type of sound? Soft/loud/vocal/music etc?
Thanks,
Dan
Oct 10, 2008 | Onkyo Audio Players & Recorders
LG 47" LCD TV - 47LC7DF Clicking Noise
I was told that these clicking noises (which happen on my Magnavox LCD too) were due to the "power required" at the internal switch. Seems that the power required to immediately turn on the TV is too much for a standalone household outlet, so it "surges" power in a series to get enough there. Hence, the clicking sounds are actually mini power surges to send more power to the internal circuits to turn the TV on.
If your set is like mine, these noises generally stop after a minute or two, correct?
Dec 13, 2007 | LG 47LC7DF 47 in. LCD HDTV
TV will not turn on
Hi, If the clicking noise is metallic, could be a relay switching on/off. What's curious is that once powered on by remote, apparently the clicking doesn't affect the TV, meaning it continuously work. The relay is suppose to turn on or off a function of the TV and apparently it is trying to but there is not such effect since the TV, as I understand from your post, works. The relay can be for the degaussing coil, power supply, over voltage protection. Since this involve a little diagnosis of the electronics, soldering and probably a minor component replacement, an on-site service/repair man would be your best bet. Even if it were a nuisance/minor repair, you can at least get the clicking noise out. Other than you get to get a checkup of the TV and diagnosis of what caused/started the clicking sound in the first place. Hope this be of help/idea. Post back how things are or should you need further information. Good luck and kind regards.
Aug 27, 2007 | Zenith C30W46 30" TV
Philips HTS-6500/37 System Logo
97 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
