Question about MTX Thunder Elite TE1501D Car Amp
Just put an MTX TE1501D amp in my truck but it isnt getting power?
    President:
  • 846 Answers
First check all the fuses to make sure none of them are blown. If they are that is the cause.
Second, make sure your amp is properly grounded. 9 out of 10 times power problems are caused by not being grounded. Make sure your ground wire is connected to a bare spot in your car meaning it touches metal.
Post back if you need further assistance. Thank you for choosing Fixya!
Posted on Sep 27, 2009
My amp cuts out after twenty min and then comes on again pisses me off help
There could be two things wrong. make shore ur ground is same size an ur power or ur amp isnt pushing the right watts for ur speakers
Jun 14, 2011 | MTX Thunder 81000D Car Audio Amplifier
How can i bridge a mtx 9500 using a mono amp?
You cant bridge it to the MONO AMP . You can only bridge subs & speakers to 2 CH & 4 CH AMPS that are bridgeable. Because if it appears that there is 2 channels on a Mono amp its so its convenient for you to hook up 2 4ohm subs to it easily But both channels are actually connect internally together in parallel inside the amp unlike a 2 channel they are separate.
So just connect your mtx 9500 to a plus and a minus and doesnt matter which since all the + terminals of are connected together and - are connected together already.
Whats important is on the side of the sub/box it reads 2 ohms. The lower the ohms the more power the Mono amp will put out. Mono amps are designed to handle 2ohm loads.
If it reads 4ohms The MONO amp is the wrong amp to use cause the power will be weaker. So if you have a 1000 Watt Mono amp at 4ohms the sub will only get 500 WATTS Max while a 2 ohm will get the full 1000 Watts.
If it reads 4 ohms connect it to a 2CHANNEL AMP and BRIDGE IT (connect + of the sub to 1st channels positive of the amp then connect - of the sub to 2nd channels negative of the amp) . The power will be doubled when you bridge it on a 2 channel amp. NOW if it was a 2 ohm sub and you bridged it to the 2 channel amp it will fry the subs and ruin the amp. 2 CHANNELS CANT TAKE A 2OHM LOAD BRIDGED OK.
Apr 08, 2010 | MTX (SLH-T7512X2-A) Car Speaker
2 MTX Thunder Problem.. Bridging?
Is there a option on the chanels that say ''Bridged''? If so, you can hook the subs up in parellel or series to get different ohm loads. Usually the lower ohms, the more power amp puts out. Those subs can handle 225 watts RMS whitch means the power it can handle constantly. If the amp gives more than 225 watts RMs, you could be at risk of blowing the sub. If you could give me the model # of the amp, I can be of more help.
Feb 11, 2010 | MTX Thunder 4500 T4510-04 Car Subwoofer
My (TC4004) mtx amp wont turn on. My fuses isnt blown.I think my amp is fried. Any suggestions?. I was told by a friend that i may have to relace the the two yellow connectors that are on my amp..is this...
If your talking about the speaker connections on the amp than no,make sure the amp is grounded to the vehicle,and make sure your power and rca are connected,if so check all fuses again,your amp may have a fuse,if its not blown your amp is probably fried.
Oct 12, 2009 | MTX (TC4004) Car Audio Amplifier
Kicker L712 and rockford fosgate800a2 amp.weak prfmce
Is the box sealed air tight, leaking around speaker? plumbers putty works great. Amp may be good enough for the mtx but underpowered for the kicker. When kicker says 1000 watts that what it is (at a 14.4 volt input). Mtx is ok but may not tell the true watts. Check to see if the speakers are the same ohms also!
Jan 05, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Wiring
Run a Jumper from coil 1 + to coil 2 + and a jumper from coil 1 - to coil 2 - and then run + from coil 1 to amp and - from coil 2 to amp. This will put your load to 3 Ohm and that will give you the most power. You could get more by going to 1 ohm but I don't think the mtx amps are stable at 1 ohm.
Sep 30, 2008 | Jl Audio 12W3 Car Subwoofer
Mtx TC-6001 Amps Problem
I had same problem with a TC6001 and get solution from MTX, not send to MTX instead MTX kindly sent a quotation for parts to be replaced, I can tell you what parts need to be replaced if you still need a solution.
Jul 12, 2008 | MTX 6001 Car Audio Amplifier
Clueless..!
You either are suffering from phase problems with the way you have your subs wired or you fried them and just don't realize it. I sell the TE1501D and these amps are not poorly made, they are however too powerful (1500+ @ 1ohm) for most subs on the market to handle continiously.
May 08, 2008 | MTX Thunder 81000D Car Audio Amplifier
MTX Thunder Elite TE1501D Car Amp Logo
74 people viewed this question
Top MTX Car Audio & Video Experts
Professor_V
Professor_V
Matthew Spark
Matthew Spark
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
