Question about Pantech Slate Cell Phone
My phone turns on to the st&t screen...then shuts back off.
It repeats that over and over and never gets past that screen.
My phone keeps shutting down and turning back on
Sounds like a battery issue - does it charge correctly when plugged in?
Aug 05, 2014 | Apple iPhone 3G
I turn on my pc and its blank screen on it but before i turned it on i removed fan to change it but all so removed the proccer to get to it and no its blank with no bios please help its all i have...
Try unplugging the cord & resetting the bios by moving jp1 for 15 secs. Them to be sure, remove the bios battery for another 10 secs. Put the battery back, plug it in & see if you get a screen. If you do, press delete to enter BIOS. Rest the time & date & anything else you messed with. If it shuts down again, you're overheating the cpu. Meaning, the fan/heatasink isn't seated all the way or you need to apply new grease/thermal paste. If the latter is required, get artic silver or better. Remove all old grease/paste with a rag. Then re assemble. It takes about 30-60 secs for the cpu to shut down with in adequate cooling.
Apr 07, 2011 | Dell Dimension C521 PC Desktop
I need help to reprogram this remote. The
Hello, I am sorry i did not get back to you sooner!
I found the manual on the internet, you can just copy and paste into your browser to download a copy for yourself if you like.
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=rca&dv=universalremote&md=rcr4258rcr4358&kw=RCR-4258&st=&ar=&dt=&so=&pg=1&file=others/rca/rcr4358-manual.zip
Here is the simple way of doing it:
0) Turn on TV.
1) Press and hold the TV button, light lights up, continue to hold.
2) Press and hold the power button, light turns off, keep holding both buttons down until light comes back on, release both buttons, light stays on.
3) Point remote towards TV the entire time you are programming.
4) Press and release play button, wait 5 seconds, if TV did not turn off press and release play button again wait 5 seconds. Repeat until TV turns off. (When your TV turns off, it was in the last 10 codes sent).
5) Press and release Reverse button, wait 2 seconds, repeat until TV turns back on.
6) Once the TV turns back on press and release Stop button.
7) Your Remote is now programed! Test it by pressing the power button, volume, mute etc..
Cheers!
Apr 27, 2010 | RCA RCR-4258 Remote Control
Vostro 200 PC freezes on Dell Start up page & won't turn on
If you have windows 7 installed, then see if you can boot to the DVD and run a repair on the OS. You also may want to run a diagnostics on the system if you can get to the F12 menu
Feb 27, 2010 | Dell Vostro 200 PC Desktop
Does not get past the Verizon screen when turning the phone on.
I hate to be the bearer of bad news but the only thing i would say try is taking the battery out for about 30 seconds. putting it back in and trying again. if it does not turn on then i'm afraid the phone will not come back. It's a somewhat rare problem but does happen.
Unfortunately all information is gone unless you had downloaded backup assistant.
Apr 13, 2009 | Samsung SCH-a870 Cellular Phone
Screen is not working; previous water damage. Phone not been same
For the symptoms your are giving, probably the best solution is to get a new phone. Sorry about that
Apr 09, 2009 | T-Mobile Motorola Razor V3 Custom Cell...
Pantech Slate  Cell Phone Logo
Top Pantech Cell Phones Experts
Computer Repairing
Computer Repairing
Abdul Mannan
Abdul Mannan
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
