Question about Samsung LE32R41BD 32 in. HD-Ready LCD Television
Samsung 32" LCD HD TV Problem
I have this tele and occasionally the picture goes green but when you tap the little panel on the back where the cables go into it goes off but sometimes returns?
I would first try replacing the cable if the problem remains the same it will almost certainly be a bad connection on the socket or panel in the back of the TV.
Simple to solve if you have any soldering/TV repair experience.
If not take to the repair shop, it shouldn't cost a lot to put it right.
Posted on Dec 31, 2007
Describe your sylvania lc225ssx green screen Problem Screen goes green occasionally. Switching to an HD channel then back usually corrects for a while. Sometimes power-cycle also temp fix.
Whenever I hear "green screen" it is a loose or faulty HD cable(s).
Check your HD connections to make sure they are inserted fully and if there is no change, try an alternate cable.
Jun 17, 2010 | Sylvania LC225SSX LCD TV
When you turn on the television when it is on stand by the television remote it clicks rather than once when I first bought the tele it is now 7 - 10 times. Once on and warmed up then it goes off and on...
When you buy a samsung, you buy a LED TV with a panel manufactured
by the company "S - LCD" which belongs to 50/50 % sony and samsung.
The S - LCD company is fully driven under samsung engineering.
Today, sony seems to buy their panels from "sharp corp" and trying to
seperate from samsung due to the cold war (high competition ) between
Just go for the samsung UN32C6500 32" 1080p LED HDTV.
Theres no better picture quality you can buy for 32".
Good luck...
Jun 14, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Samsung 650 lcd 40" tv picture blacks out for a few seconds.
Dude, better check your cable and also your TV's power management settings. This might also happen due a issue with the HDMI output of the satellite box.
Jan 07, 2010 | Samsung LE40B650T2 40 in. Full HD Crystal...
How do i activate teletext on my samsung lcd tv
if you will go into the menu and go to closed captioning you will find the tele text there
Nov 20, 2009 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Trying to connect laptop to Samsung HD LCD TV using VGA cable.
I had the same problem with my Samsung series 6 32" Lcd. After many hours of trying different settings and banging my head on the wall I found the solution. What the problem is your VGA cable not supporting the high resilotion of your Samsung TV. The simple solution is to buy a new VGA cable that supports HD. Take a look at this site you need something like this one! Hope this helps.....C
Sep 19, 2009 | Philips 32PF7421D 32 in. LCD HDTV
Blinking red and green squares with blue fuzzy bars in the back
Before thinking of TV problem, you should play a DVD first and see how it goes. TV problem only happens when all sources were affected. If you have the same problem for all sources, open the cover, disconnect LVDS cable and re-connect it; then try to tap or shake gently the LVDS cable and see if the picture changes. If yes, replace LVDS cable. If not, then measure the power on supplies from main board to power supply board, see this 5 VDC is stable or not. If it works fine, the problem may come from T-con board or some case from defective panel.
Aug 17, 2009 | Samsung LN-R328W 32 in. HD-Ready LCD...
Samsung lcd tv
I'm having the same issue. I'll be watching the television an all the sudden the screen goes black/turns off. I turn it off and back on again and picture comes back on. It doesnt seem to have any consistency..
May 26, 2008 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Samsung lcd tv 32"
could be a loose LVDS cable, if not it is the lcd panel
Feb 24, 2008 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Color problem with Samsung 40 in LCD HDTV
Check your component cables. You have 3 colors coming in. Red,Green and Blue. Make sure the Red cable is good. You can do this by substituting the red cable only, or just change all 3 cables
Best regards
Nov 25, 2007 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Samsung LE32R41BD 32 in. HD-Ready LCD Television Logo
59 people viewed this question
Jerry Greenberg
Jerry Greenberg
