Question about Sewing Machines
I have a Viking sewing machine model #6370. I was adjusting the thread tension and the bobbin winder started running whenever I try and stitch. I've checked everything and can't find out what's going on. I'm on a project deadline and need help fast! Thanks so much for your prompt reply.
    Problem Solver:
  • 33 Answers
Retighten the wheel where you losened it to fill the bobin :)
Posted on Sep 28, 2009
How do I turn off thread portioning on Husqvarna Ruby De Luxe. I don't want to adjust the settings but need to turn this off. Thank you
FWIW, I was unable to find any information for turning off the thread portioning function. Unfortunately, this appears to be the thread tensioning system, so disabling the thread portioning would be disabling the thread tensioning--something that is critical to sewing. It appears this model may have some issues and perhaps this one is particular to your machine. It may be best to take it for service.
Perhaps this will help:
Husqvarna Viking Designer Ruby 25 Tension Thread Portioning Deluxe Stitch...
Husqvarna Viking Designer Ruby 22 Bobbin Thread Sensor
Husqvarna Viking Designer Ruby Review Sewing Insight
Jul 01, 2016 | Husqvarna Sewing Machines
Need to know how to thread bobbin
manuals can be purchased @ janome. com. your machine should have a bobbin winder. Set empty bobbin on the bobbin winder pin. Thread spool of thread though guide(or tension wheel on the top of the machine;NOT the stitching tension.) wrap thread around bobbin to start, and push bobbin toward the flywheel. slowly press foot pedal and bobbin should begin to turn. apply more pressure to foot pedal to increase speed.When full, bobbin winder should kick back to stop.
May 29, 2010 | Janome 2049LX Mechanical Sewing Machine
Need new bobbins as the ones I have are not for
Hi Karen. First, you really do need a manual for your machine. I found one at http://www.sew4less.com/browse.php?CategoryID=5&filter_brand_id=83&filter_model_id=6040&go_filter.x=27&go_filter.y=9. Sewing Parts online also has your manual: http://www.sewingpartsonline.com/viking-sewing-machine-instruction-manuals.aspx
If the bobbins fit your machine and it makes a stitch, then the bobbins you have are fine--what you have is an adjustment problem, to get the stitch balanced. (I have a little tip/hint on adjusting the balance that might help you.) Here are a couple of things to remember when you're adjusting the tension:
1. Use different color threads in the bobbin and on top to make it easier to see
2. Thread your machine with the pressure foot UP. (Otherwise, the thread may not slip into the tension disks like it should.)
3. Adjust the tension with the pressure foot DOWN. (This engages the tension disks.)
4. Move the tension dial only a little bit at a time.
Hope this helps!
Robbie
Apr 08, 2010 | Husqvarna Freesia 415
Shirring fabric?
Drop the bobbin with the elastic in the holder without feeding it through the holder, and enlarge the stitch length,
Mar 29, 2009 | Brother XR7700
I need an instruction manual for the Babylock Pro II Model B15
hi!there similar bobbins winder in any brand of sewing machine uses mostly in domestic particularly in industrial manufacturing in this fig.check it out if similar to your bobbins any how itmay be he86acf3a.jpglpfull onethe bobbins winder that was a thread and shoul be clockwise rotation when coming out to bobbins case,if you to wound the thread on your bobbins winder, pull threads on spool then wind this in several times 4 to 6 rotation clockwise loop thread on top machine there is bobbins winder disc for tension put winder bobbins on shaft winder near hand wheel push the latch against bobbins winder to fit thead run machine to wind the thread.After hread wound in bobbins winder cut thread and insert winder to bobbin case as shown.
insert bobbins to shuttle hook case under needle foot holder
lift the cover plate you can see under this is the shuttle hooke415486.jpgafter set up was made on bobbins thread,set also the upper loop thead beginning at top of machine start on spool, pull thread and loop to upper disc tension then to the slot portion as in figure
insert on lever dial goes to the needle adjust tension to #8 range to #12 for cotton fabrics two layer sewing.
Mar 17, 2009 | Baby Lock Sewing Machines
Can't pull thread from spool
The sequence of setting up of thread from spool to needle is not complied to actual setting is one factor to be consider it affect the sequence timing of sewing.Particularly some machine are common in starting up threading.fig. shown a basic flow of thread on red color.It maybe a helpful oneb1934dc.jpg
In addition to this the set up of thread to bobbins winder is also need in right place the thread should be in clockwise rotation when coming out to bobbins casing as shown in fig.76e4431.jpg as you can see when thread was pulled out from bobbins winder is moving counter clockwise.If you try to sew, try cotton fabric and set dial to # 3 to 4 and stitch set range to 8 up to 12 depend on layers and thickness,After setting try to sew manually ,turn hand wheel by your hand first,let upper tension catch the lower bobbins tension and arranged thread and insert fabric use hand turning hand wheel several time until stich appear on fabric observed loop thread on lower bobbins on fabric.if accumulation of loop thread on lower adjust upper tension also dial tension gradually until it has a smooth stich appear.
Mar 15, 2009 | White Sewing Mighty Mender WW100...
I have a designer 1 that won't release the bobbin.
Winding too tight;
Whenever your bobbin won’t come off any Viking, Designer 1 included, it’s because it wound too tight. This is how you know. It went on easy! To get it off, don’t pry, slowly unwind all thread, it will change shapes and let go of the bobbin winder. My favorite way to wind a bobbin on a Viking is to thread the machine through the needle and go under the foot then up to the bobbin winder (it has to be under the foot or it winds too tight. If it still winds too tight, lay your thread down instead of standing it up, the weight of the thread can increase tension on the winding process also check that you use a spool cap as large as or slightly larger than your spool. If it still winds tight. I’ll explain what bad thread can do.
Test your thread quality to start, thread your machine and LIFT the presser foot (this opens the tension disks). Pull your top thread straight back. If you feel no tension no mater how much thread you pull, your thread is good. If that your machine passes that test (tip: always check your thread this way when you thread your machine)
Mar 12, 2009 | Husqvarna Designer I
Kenmore sewing machine older model 1345381
hi! there wind thread on bobbins winder 4 times by your hand rotate clockwise,insert in shaft bobiins winder on top of your machine near hand wheel push latch to engage loop thread on disc winder tension start your machine on pedal foot automatically winder disengage if already filled up of thead pull this winder and insert to bobbins casing insert thread to slot and pull out winder 6411c87.jpgshould rotate clockwise as shown.insert on shuttle hook casing and close cover needle plate.next thread your upper
97b52e8.jpgthreading tension as shown on red threading from spool pull threading and loop to dial tension threading and insert thread to lever needle and to needle hole tip. pull tread under the needle foot and feeder tooth.rotate hand wheel counter clockwise to hook up thread bobbibs and appear at top of needle plate,teo thread shoul appear,set dial tension to # 3 and stich to # 8 range to # 12 depend on fabric and layer of fabrics and set on straight stich sewing,let needle on upper position insert fabric for trial sewiing.put down foot needle lever. manually by hand rotate for assurance needle is free to sew if obtruction on loop bobbins thread occurs adjust all tension gradually then try again until free from sewing w/o problem star sewing.
Aug 08, 2008 | Kenmore Drop-In Bobbin 505S-21BH...
Bobbin on a Viking #1+ sewing machine
Could be the bobbin case tension is too tight--are you using a thicker thread than usual? Also, check to make sure that it is the correct bobbin for your machine--several are very similar but if not exact, will not sew properly. Also, if the thread is not evenly wound on the bobbin, there would be problems. Check to make sure the bobbin thread is threaded through the bobbin tension. It may help to tighten the top tension, but if the bobbin case tension is too tight, adjusting the top tension will not completely resolve the problem. The tension is correct when the top and bobbin threads meet in the middle of the fabric--this means that whenever you start a different project, you may need to re-adjust the tension.
Understanding Thread Tension Threads
Learn the Ins and Outs of Troubleshooting Sewing Machine Tension
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Jun 19, 2017 | Husqvarna Viking 1
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
