Question about Kenmore 21.7 cu. ft. Side-by-Side Refrigerator with Thru-the-Door Ice & Water with Water Filtration 4659267
Ice maker not working
The ice maker was not getting water to it.Replaced ice maker unit and selnoid. Still no water getting to ice maker or movement of ice maker itself. Whirlpool Model # ED25PWAN00
The water supply for the drinking water works
no water to the ice maker,but I get water to door replaced water valve still not working ?
  • 16 more comments
  • kevinknk Dec 20, 2007
    I have a Kenmore icemaker.  I had the ref. discounted and re-counted it and now the icemaker does not work.  I checked the value and that works, I checked the water line to see if it was frozen and its not.  What is the next step?  Thanks.
    Kevin
    kjrentals@netzero.net
  • william sanders Dec 22, 2007
    I have a GE Mod. tfx25jryaww. Ice maker works great. I have no drinking water. Can't get the front cover off to evaluate what componet has failed. I miss the good cool drinking water.
    Thanks,
    blsanders@truvista.net
    Bill Sanders
    2964 Lakeshore Dr.
    Chester SC 29706
    803-789-3443
    I havae a GEtfx25jryaww fridg. The icemaker ect. works great. However, I do not get any drinking water out the exit spout.
  • Anonymous Feb 14, 2008
    Not getting water to ice maker. Water is getting to drinking supply in door. Ice maker cycles but no water is getting to it. Removed and reinstalled filter at bottom of fridge.
  • Wili Mar 22, 2008
    Ice maker not working. No water getting up to ice maker. Replaced filter,complete ice maker, and solenoid valves. Is there a reset or ???
  • Anonymous Apr 18, 2008
    replaced the water hose to ice maker, still no water comes in, could it be the filter?
  • b2bone May 07, 2008
    Kenmore model 363.9530783
    replaced water valve assembly and water supply line. water to door operative. gears on icemaker behind front plastic panel not broken nor any gear teeth missing. no water to ice maker
  • macberger Jun 01, 2008
    I have a Whirlpool Gold Conquest side by side - there is water coming out the spout but the ice maker is dry - it is not making ice...
  • Anonymous Jun 17, 2008
    ice cubes will not drop down
  • usmj Jul 21, 2008
    Same problem. Took apart and cleaned plastic pump, cleaned gaskets, hooked back up, no water for ice making unit. When I fill unit up with water, it works and dumps the ice but is not bringing water back up to fill in the tray. Line is clear. What should I replace?
  • Anonymous Aug 13, 2008
    kenmore model 106.53662300
    Ice maker does not work. I've tried emptying ice basin, turned on and off button, etc. that button has a red light blinking. thanks
  • Anonymous Oct 25, 2008
    ice maker will not produce ice
  • dfreels Dec 02, 2008
    Water works but ice maker not working
  • hengland Dec 26, 2008
    The ice maker is not getting water, but water is being dispensed from the door.
  • Anonymous Jan 05, 2009
    i am having same problem. if water is going to water dispenser on door does that mean it is also going to ice dispenser?
  • tiffkinn Jan 30, 2009
    Replaced fiter and there is no water going to ice maker
  • tdnf Mar 24, 2009
    Ice maker not working, replaced the unit, filter, and light sensor still not getting water to maker, but water in the door works.
  • Anonymous Mar 18, 2014
    How do I get lower door off unit to try and fix ice maker?
I recently had trouble with both my water dispenser and my ice maker. I determined that my filter was clogged, so I replaced it. That fixed the water dispenser but the ice maker still wasn't working. I investigated further and found that the water inlet tube was frozen solid. Aparently, when the filter was clogged the water came in so slowly that it froze before it got to the icetray. I tried pouring hot water over the inlet tube to melt it and it mostly worked, but there was still some ice in the tube further back where I couldn't reach. Finally I defrosted the freezer so all the ice could melt and turned it back on and now it works great! Hope this might help.
Posted on Mar 31, 2009
I have a Sears / Kenmore refrigerator, model 106.53662300. I purchased it new in 2003. In 2005, just after the warranty expired, the ice maker went out. I had to replace the whole unit. It is a Whirlpool ice maker, that I was able to pic up new for around $45. Right after that, the digital temperature control pad went out. About $220 for the part alone. I replaced that part myself also. Now, it is not cooling. I suspect the compressor starter relay. WHAT A PILE OF JUNK this refrigerator is! I WILL NEVER OWN ANOTHER KENMORE, which I think was built by Whirlpool.
Posted on Jun 21, 2010
I have a whilpool Model # ED5FHXC001A side by side Energy Saver refridgerator. It was purchased late in 2006. It's not making and dropping ice. Any ideas what the problem may be? Thanks
Posted on Jun 28, 2008
Look at the Infra Red ice level detector in the freezer compartment sides and see if it is blinking 2 times. If the blinks are present possibly failed IR units. There are troubleshooting proceedures on line. Eric B.
Posted on May 31, 2008
  • 833 Answers
The only thing you have not attacked here is the control unit which turns the unit on and off. The model numbers you've cited don't turn up any units...either Whirlpool or Kenmore. However, you'll find that there is a switch which turns the unit on and off somewhere. It is defective or off. Many of these units have a schematic printed on the back panel. Trace it down and find it.
Posted on Dec 18, 2007
How to repair Refrigerator ice maker that not making ice
Any chance you may have the model number of that refrigerator that you're having problems with the ice maker?
Appliance 911 Sea Breeze there are some ice makers that you can repair but as far as cost is not worth it ice makers wear out after several years there's a lot of work involved in making ice just replacing the part that broke doesn't fix the rest of the Ice maker
Sep 01, 2016 | Frigidaire Refrigerators
My Amana bottom freezer refrigerator BB120TPW is 11 years old. The ice maker doen't make any ice. I can hear a noice coming from the unit, but no ice. I turned off the water and unpluged it. If it...
Ice maker stopped making ice. For this problem you have check few things. First thing, is the water filling in the ice maker chamber and then ice maker not making ice? Or, the water is not filling in the ice maker chamber so it's not making ice. If the water is not filling in the ice maker chamber then it's clear that ice is not getting made due to no water in the chamber. For no water filling, the problem is either water supply valve turned off so water is not filling. Turn on the water supply and it will fill. But if the water supply is turned on then the other possibility is ice blockage in the water fill tube. There is a tube from which the water runs and enters the ice maker chamber. If this tube is blocked then water will not enter the chamber. The tube needs to be defrosted, by using hair dryer. This procedure melts the ice collected in the tube and water starts running again. But if water fill tube is completely clear and no ice blockage or any other blockage. Then other possibility is water valve at the back of ice maker unit. This water valve is for letting the water in the ice maker. The water valve open only for 7 seconds and in this time the water fills in the ice maker chamber and then water valve closes and the same procedure runs again in the next water filling cycle.------- For your information I will mention that there are two valves. One is the main valve the back of the fridge section. This main valve lets the water enter the refrigerator and other valve is at the back of ice-maker section. This other valve lets the water to enter the ice maker. In most of the cases the fault is water valve at the back of ice maker section. ------------- The other above possibilities which I gave you is water not filling in ice-maker chamber so it's not making ice. But now consider that water is filling in ice maker chamber but it's still not making ice. Then the problem is ice maker unit itself. This unit is controlled by main board. But in most cases if water is filling the ice maker but it's not making ice then its faulty ice maker unit. So see if the problem is water not entering the ice maker then the water fill tube is frosted by ice or the water valve at the back of ice maker is faulty. Replace the valve. ------------
You can get required parts from sears part direct online site or from repairclinic.com site.
This will help. Thanks. Helpmech.
May 29, 2011 | Amana Refrigerators
I have a kitchenaid 23cd.Icemaker doesn't work has 40# water pressure 5 deg in freezer water works to fill glass no water in ice tray unpluged for 24 hours
If the water dispenser is working and fill glass function is working but the ice maker section there is no water in the tray then its faulty ice maker valve.This is a twin valve.The valve is one unit,but has two sections one for water and one for ice dispenser.This valve is got faulty and not working for both sections so water is not entering the ice maker tray.
There is a water valve at the back of the ice maker.This valve controls the flow of water in the ice maker chamber.If this valve is not functioning as required then water will not enter the ice maker.This valve is at the back of ice maker connected to the water fill tube.It has to be replaced to clear this problem.
Feb 01, 2011 | Refrigerators
Hello, my ice maker is not working.. the water is
Probably the solenoid (electric water valve that opens when the ice maker calls for water, located at the back of the unit in the bottom, behind the cover) is leaking and the fill tube to the ice maker gets clogh with ice , or the valve doesn't work, in both cases it needs to be replaced.
Aug 22, 2009 | Refrigerators
My ice maker will not work, Ge profile Arctica.
Here you go...my dad had the same issues...Good Luck!
http://www.youtube.com/watch?v=sW2yqQjEcLI&list=HL1329704348&feature=mh_lolz
Jun 23, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Ice maker won't work
If you are sure that power is getting to the ice maker unit inside the freezer and you're sure that water is available for the ice maker...
Try these next steps:
Follow the water line for the ice maker back to the ice maker water solenoid
Follow the wiring from the water valve to its source - either a timer or circuit board
Check the timer and/or circuit board for any bad connections, burned connections and power to the board or timer. This arrangement can vary by refrigerator model number...
Apr 11, 2009 | Refrigerators
Amana Side-by-Side Fridge Model SBD21VPSE Problem started when water stopped flowing from in-door dispenser and ice maker stopped making ice. I emptied fridge and freezer, left unit off for several...
If there is a reset button on your ice maker try pushing it. Many ice makers have two holes for reset. A general rule of thumb is if the ice maker fingers are stopped in a slightly vertical position then your ice maker unit is working. If the fingers are stopped anywhere else then it needs some sort of attention or replaced. Make sure there is water, or ice in the ice maker tray, if not then the problem is with water supply.
Nov 29, 2008 | Refrigerators
Ice maker not working, water not going in tray.
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
iuoiout
Mar 28, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
I replaced both silinoids and the ice maker. The ice maker will freeze water but not fill with water. My refridgeratoor is an a Amana
Dec 16, 2007 | Whirlpool ED2FHSS Side by Side...
Refrigerators Logo
1,926 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
