Question about Euro-Pro UV209 Upright Vacuum
What belt do I need for this? - Euro-Pro UV209 Upright Vacuum
  • 42 Answers
I'm unsure of the part number, but they are available for about $5 US after shipping here:
http://www.totalvac.com/accessory/parts/sharkbelt.html
Posted on Feb 23, 2010
After a few minutes, vaccum emits a burnt rubber smell. Checked the V-belt and it seems fine.
It might seem fine but the burnt rubber smell means that the belt is slipping. This causes friction between the belt and the motor spindle causing the spindle to get extremely hot which melts the inner surface of the drive belt.
Take the belt off and examine the inner side that loops over the brushbar and the motor spindle. You will find that there are sections where the belt has partially melted - they are usually smoother than the rest of the belt.
Belts don't need to break before they need replacing. They just need to lose some tension. This is what seems to have happened in your case and you should replace your belt.
Regards,
BElectric
Dec 17, 2010 | Vacuums
Brush not moving, suction working
This machine is made for Sears by Panasonic. The power head, depending on model has a "gear" / cog belt or a standard flat rubber belt. First turn the power head over and see if the brush roller turns easily, if so you do need a new belt. To access the belt you will have to remove the hood from the power head. There are 4 screws, one at each of the corners to take out. Once the hood is off you will see where the belt goes and find "teeth" in the motor shaft for the motor / brush roller if you need a gear belt. If both of these are flat you need a rubber belt.
You can go to sears.com and find the belt you need with the vacuums model number.
Apr 27, 2010 | Kenmore 22812 Bagged Canister Vacuum
Beater bar does not turn. Belt is not broken but is so slack that it won't turn the bar. Do I need a new belt or is there a way to adjust the tension?
No, once the belt is stretched and worn there is nothing you can do, you have to replace them. Here is the belts you need for your model:
Hoover U6476-900 Belts
Apr 08, 2010 | Hoover U6476-900 WindTunnel Vacuum
Beater? bar doesn't spin
That means that the belt is broken, stretched or worn. You need to change the belt. You can get replacements here:
Replacement Vacuum Belts
Dec 08, 2009 | Vacuums
Self propulsion doesn't work on my upright. Vacuum works fine otherwise
You will need to look @ your owners manual to see where the self propell belt is located i am sure yours is broke and need to replace,- it will not be hard to replace-Lance
Oct 21, 2009 | Hoover Vacuums
Cleaned out hair,etc., but brush still doesn't rotate...makes a ratcheting noise.
You probably need to change the belt. Even though the belt my look okay it can be stretched and therefore not turning the brush. You can find the DC07 belt on www.vacbelts.com. If you have the DC07 with the clutch system you need these belts:
http://vacbelts.xps.convina.com/dyson-clutch-system-belt.htm
If it doesn't have a clutch then you need this belt:
http://vacbelts.xps.convina.com/dyson-flat-belt.htm
Oct 16, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Need to check , belt , donot where to check,on
If you click on this link, it will take you to a website that has instructions with illustrations to show you how to change belt.
Hope this helps.
http://www.info-vacuum-cleaner.com/hoover-vac-belt.php
Aug 21, 2009 | Vacuums
Hoover mach 4 burning smell
There are two reason you could be smelling a burning smell-
1. The belt is too stretched out and needs to be replaced. This causes it to slip when the vacuum is on and will create that type smell. You can avoid stretching and having to replace the belt to often by releasing the belt after each vacuum.
2. There may be hair or other debris stuck around the rod that the belt is attached to. Can be avoided by checking after vacuuming.
Hope this helps
Nov 12, 2008 | Hoover Vacuums
Need to change a belt on my Hoover Concept One Power drive
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=766023
Generic problem for all Vacuums
Posted by gentilly on Jul 10, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. On the Hoover Concept One Power Drive Upright vacuum there are 2 belts, a drive belt and a power drive belt, always use the Hoover genuine belts and for the best cleaning always change you vacuum belts every 4 to 6 months for the best cleaning. !st, remove the bottom plate and cut off the old belts – then you need to lift up the one side of the brushroll that has the pulley side for the longer of the 2 belts and slide it on. Replace the brushroll, B4 you go to far remember which went on 1st, the power drive belt (smaller belt) or the brushroll belt, in either case hook the belt(s) onto the pulley 1st and then use a belt puller or a screwdriver with a hook or bend on the end and stretch the belt(s) onto the motor pulley and then track the belts in a straight line – do this on both belts. Once you have done this then replace the bottom plate. Check your owner’s manual in the trouble shooting guide to see if they also have suggestions or check with your local vacuum cleaner dealer in your area or contact the Hoover website or the Hoover factory cust serv phone # listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 10, 2008 | Vacuums
Euro-Pro UV209 Upright Vacuum Logo
96 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Greg Cann
Greg Cann
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
