Question about Maytag Dryers
How do you repalce a door latch on a Maytag Model 512 Dryer?
  • 304 Answers
You should be able to pry out both the male and female piece with a thin blade screwdriver or putty knife. Don't worry if you break either piece. You should end up with two holes. one in door and one in front panel. Buy kit and pop in both new pieces.
You may want to buy the kit first (part number 306436)...it will show you the construction of the two pieces before you begin prying.
Good Luck
Posted on Sep 27, 2009
Maytag dryer 3000 fault code f22
Replace the door latch. Fault code F22 is for the door latch.
Oct 12, 2015 | Maytag Dryers
Dryer wont start
You need to have someone check it.
It could be anything from the switch on the door latch to a bad timer...
Feb 23, 2014 | Maytag Dryers
Electric dryer not get heat
Inspect the front door lock if "F22" is displayed. Press the "Pause/Cancel" button two times. Close the washer door firmly to latch the door. Remove clothing preventing the door from closing and latching. Press the "Power" button, followed by the "Start" button.
May 12, 2012 | Maytag Epic 7.0 Cu. Ft. SuperSize Capacity...
I have a Maytag dryer (Model MDE2600)and the buzzer will not go off unless the door is opened. Buzzer begins when door is closed.
Hi
Buzzer comes on because the control senses that the door is not closed and won't start the cycle. This issue is caused by door switch-latch assembly (part#6 and part#9 in this diagram) that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jan 17, 2011 | Maytag Dryers
MAytag dryer will not run. Has Power but will not start. No sensing light.
Was your dryer taking a long time to dry clothes? If so you should first check your vent and then suspect your dryer thermal cutoff.
Or,
this problem could be your door latch switch. Is your door more difficult to open, OR, sometimes pops open / or opens really easy? Then your door latch switch could be bad.
Jul 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer stops in the middle of cycle
The door latch has failed, that's why your dryer stops. When the door opens it stops the drum and turns off. Fix the latch.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 01, 2009 | Maytag PYE2300AY Electric Dryer
I have a maytag ensignia, the dryer does not work on sensor dry
im not just sure about what your saying.but if the door latch is broken on the door or in the body of the dryer you need a door latch kit
Jan 01, 2009 | Dryers
Dryers Logo
90 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
