Question about LG Xenon GR500 Cell Phone
When I plug in my xenon to charge it vibrates or makes noise(when its on ring mode). It did not do this when I first got it. It appears not to charge when it does this.
I have no ringing sound on phone, i have gone to settings, ringtones & sounds, the ringer is on, vibrate is on, when i get a call it vibrates but those not ring. is there a ringing volume somewhere?
Welcome to FixYa!
Volume up your phone using the Volume Key on the left side of your phone.
  • A volume bar will appear on the screen.
  • Press the Volume Key until you reach the desired volume level.
  • Tap the ICON on the right to switch between VIBRATE and RING.
  • Make sure that it is in the RING mode.
Thank you for using FixYa.
Have a great day.
Jas247
Jun 04, 2011 | HTC 7 Mozart Cell Phone
I have 3g apple phone i can received calla but so sounds just vibrate
if you mean the phone doesnt make noise when it rings, check the ring/vibrate switch on the left side, and make sure that the volume is turned up all the way when it is set to ring. you can tell when you flip the ring/vibrate switch because onscreen appears either a bell, or a bell with a line through it. if that doesn't do it, you may want to see if your speakerphone works when on a phone call, because i'd say it doesn't and you have a hardware problem that requires contacting apple either at the apple store, or at 1800aplcare
Apr 02, 2011 | Apple iPhone Smartphone
How to unmute or restore ringer sound on our spectralink e340 wireless phone
User options
Press FCN while on hook to change settings
(* shows current, follow display instructions to set):
Ring Type-select:
Normal (for an audible ring)
Vib/Norm (vibrates for five seconds, then rings)
Vibrate (vibrates until answered)
High Noise Mode-select:
Normal (for most office environments)
High (for moderate background noise)
Severe (for extremely noisy conditions)
Current IP address: may not be edited.
Extension number: may not be present for some protocols.
Additional options may be present
Mar 24, 2011 | Spectralink NetLink e340 Wireless...
How to remove virbrate and keep ring tone?
Choose Settings----->Sound---->Ringtones---->Alert Type:
Supports 3 ring alert types.
Ring, Ring & Vibrate and Ring after
Vibration.
Mar 04, 2011 | LG Xenon GR500 Cell Phone
How do you adjust the volume on the Samsung T255 StraightTalk phone?
Sound Settings
You can customize various sound settings.
Incoming call
Note: When downloading MegaTones® or HiFi RingersTM, charges may apply.
Ringtone.
This menu allows you to select a ring melody. Highlight Ringtone and press . Use the Up or Down key to highlight a ring tone or press the Left or Right key to select a file from either the Default Melodies, Voice list, or Sounds folders. Press the Select soft key.
Volume
This menu allows you to adjust the ring volume to one of 7 levels plus Silent mode and Vibration mode.
  • Use the Right or Left key to increase or decrease the volume.
Alert type
This menu allows you to specify how inform you of incoming calls. Use the Right or Left key to select an Alert type.
The following options are available:
- Melody: the phone rings using the ring melody selected in the Ringtone menu.
- Vibration: the phone vibrates but does not ring.
- Melody and vibration: the phone rings and vibrates simultaneously.
- Vibration then melody: the phone vibrates three times and then starts ringing.
- Melody then vibration: the phone rings using the ring melody selected in the Ringtone menu and then vibrates.
Message tone
This menu allows you to set up the ringer for incoming messages. You can set the Tone, Alert type, and Repetition.
  • Use the Up or Down Navigation keys to make your selections.
Keypad tone
This menu allows you to select a Beep or a Xylophone for your Keytone and to select the Volume (0-7) that the
phone sounds when you press a key.
Jan 25, 2011 | Samsung T239 Cell Phone
Is there any way to mute the ring tone or put the ringtone on vibrate? While in meetings, etc. I want to leave my phone on but the ring silent. I can't seem to find how to do that on the lg xenon.
on the left side of the lg xenon you will see two buttons with two arrows pointing up and down press that and keep pressing it down or it will appear and you can touch and put it on silent
Aug 09, 2009 | Xenon XEN 1510T 15.1" Flat Panel LCD...
How do i turn my phone to silent mode?
To place the handset in Silent / Vibrate Mode
Step 1
To place the handset in Silent / Vibrate Only Mode, hold down the pound key (#) for about 2 seconds. To exit Silent / Vibrate Mode, perform the same action while in Silent / Vibrate Only Mode. You will see a confirmation message for Silent / Vibrate Only Mode, each time you enter or exit Silent / Vibrate Mode.
The SCH-U470 (Juke) handset will vibrate rather than ring when you receive a phone call, message or alert while in Silent Vibrate Only Mode.
Step 2
While in standby mode, press the volume key, located on the left side of the handset, then select either “Vibrate Only", “Alarm Only” or “All Sounds Off”. To disable perform the same action while in Silent / Vibrate Mode.
The SCH-U470 (Juke) handset will vibrate rather than ring when you receive a phone call, message or alert while in Silent / Vibrate Only Mode.
Jun 08, 2009 | Samsung SCH-U470 Juke Cellular Phone
Ring tone problem
there r three modes. 1)ring mode. 2)vibration mode. 3)silence mode. so it would be on silence mode.just make it ring mode from silence mode. which can be done by going into settings then in to ringer and volume option.in that you can select. thanks.
Jan 08, 2009 | Cell Phones
Ring vs vibrate
This phone allows you to independently set ring and vibrate modes. When you access "Call Vibrate" to set the mode, also visit the "Call Ringtone" menu to turn off the ringer.
You may want to leave the vibrate mode OFF and your ring tone ON and use the quick keys to switch between ring and vibrate. Two ways to do this, push and hold the # key to switch between normal mode (the settings you chose in "Call Ringtone" and "Call Vibrate") or use the side volume button to access the "Master Volume" and select "All Off", "Vibrate" or a ring tone volume.
If this helps you, please leave me a good rating.
Aug 17, 2008 | Samsung SCH-u340 Cellular Phone
Vibration wont work
All I did was wait for it to come back. I think it might have had something to do with the battery being low. However, that's never happened to me when the battery was low. When I plugged my charger in, I got a text message. I had the ring on high and vibrate. It vibrated for a second, then it just continued to ring. Once my phone was fully charged, the vibration came back. I think it was just a glitch in the phone. Razr's suck.
Mar 02, 2008 | Motorola Mobility RAZR V3m Cellular Phone
LG Xenon GR500 Cell Phone Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
