Question about Technics SL-1210 Turntable
Technic SL - 1210M5G problem.
Sounds like most  records are slightly warpped, but when I took them back, they played fine on all other tables.  It is the MOST annoying presence of sound I've ever encountered.  My best description is that it sounds like phasing issues but I don't think that is possible. My tables are new.  I've tried changing the angle on my needles from 0 degrees alll the way up to 20 degrees, with no audible betterment.  Please give me a sloution or multible troubleshoots to help!      Thank you for your assistance!
  • jhouston79 Feb 02, 2008
    If you knew anything about turntables, you would probably know that 1210's are direct drive.  Next ???  Does anyone know what I'm talking about??????
  • 515 Answers
Check to make sure that your voltage setting is set correctly. Look under the turntable platter. YOu'll see a voltage selector. Make sure it's properly set for your area (115V or 220V). Do the lights dim off/on? If so, than that is usually the problem. If not, then you might have a faulty turntable drive issue, which means something is wrong on the main board (located underneath the turntable platter).
You can open her up and see if there are any burnt resistors or anything unusual on the board. Take a look at R213 and also Q2 and Q3 to see if they are burnt.
If you really can't figure it out, give us a call here, and we can talk you through some other things to look for - 1.877.357.7677 - ext 1 - we are authorized Technics, and are experts with the 1200MKX series.
- DJPROLAB
Posted on Feb 24, 2008
    Problem Solver:
  • 7 Answers
I would suggest you verify you motor is sound, the platter is not rubbing. Is it direct drive or belt drive? You could go as far as check that your ac to your house is stable and the ac to dc rectifier/transformer/whatever it is called is good. When you say tables are new...as never used or made within the last 6 months?
More details on the tables would help.
Posted on Dec 18, 2007
I have 2 technic sl1200s and the right table has noise coming out of the speaker when i moved the tonearm. when music plays, it sounds like the treble and volume of the right speaker is weaker help...
If your left technics sounds good, maybe the problem is the cartridge. Try to interchange the cartridges, right table cartridge by the left one, and listen. If now the bad sound comes from the left table, it´s time to get a new cartridge or stylus. If the problem continues there is something else to look for. Hope this will help. Flavio/Brazil.
Sep 17, 2010 | Technics SL-1210 Turntable
Techics sl-1210s m3 turntable spins back on itself
You have a fault on the quartz-lock speed control electronics. It may be a simple fix, it may be not.
It will require specialist investigation. A Technics dealer should be able to advise you, and arrange shipping back to Technics for repair if you decide that is the best thing to do.
Jan 15, 2009 | Technics SL-1210M5G Turntable
Song playing backward but table going foward with serato.
hi... swap the left and right rca cable.the one who said it works good on the deck but on the screen goes back ward....see what hapen..u
Dec 09, 2008 | Panasonic Technics SL-1200MK2 Turntable
Playing songs backwards wit serato scrach live
I got it partially fixed. The black wire from the tone arm was broken so that been solder back on place nd the rca also the song is playing foward on channel 1 only, thats a start! New problem accuring now! Can't use that table to scarch now caus every time i do so the song goes foward only??? No back and forth in the sound??? I'll get a new tone arm and it should get everything better!
Technic's 1210M5G problem with the pitch slowing
Sounds like your pitch control is about to go bad. I would suggest replacing it. The part can be purchased HERE.
- TERMiNAL OPTiC
www.DJPROLAB.com
Feb 25, 2008 | Technics SL-1210M5G Turntable
Warped record sound?!?!?!
Go to the following reply to your original post:
http://www.fixya.com/support/t303119-technic_sl_1210m5g_problem
Feb 02, 2008 | Technics SL-1210 Turntable
1210M5G- warped sound on most records.
I answered here:
Technics SL-1210 Turntable Logo
534 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
