Question about Brother MFC 210C All-In-One InkJet Printer
The printer will photocopy but not print from the computer. It was working correctly but now stopped.Could power bumps affect it?
My canon MP287 cant print.black when photocopy. The paper also started to jam so it cant print. what will I do?
When there is a paper jamb make sure the whole piece of paper is removed because any tiny pieces of paper that are left behind will cause further paper jambs.
If the paper does not feed through the printer correctly then the rubber rollers are dirty/sticky. Clean the rollers with methylated spirits to stop the paper from sticking to the rollers.
Mar 02, 2013 | Office Equipment & Supplies
When photocopying, leftside print missing/text
it is only happned when you takes only photocopy ? or Printing... The same will be affect while printing and copying may be the problem related to Laser Supply unit, open the LSU and clean the LSU mirror with a cotton waste. Your issues must be solve....
before that pls. check your cartridge unit...
Apr 24, 2010 | Samsung SCX 4200 All-In-One Laser Printer
Prints photocopies fine but pages of text have lines missing
Run a nozzle check to see if all inks printing out correctly.
Apr 11, 2010 | Epson Stylus DX6050 All-In-One InkJet...
Printer/scanner/photocopier. scanner not working. Any ideas?
Are you scanning to your computer? If you are getting an error during the transfer to your computer, check your firewall. I had a scanner (mine is a Panasonic) problem with the transfer to my computer. I corrected it by printing the properties of the scanner and found out the port number that the scanner used and opened the port in the firewall. Hope it helps.
May 04, 2009 | Office Equipment & Supplies
Lines rule across my print out paper at photocopying mode
Make sure you don't have a scratch on the glass of the scanner. If you have a mark, or scratch that matches the line ruled on your print, then there is your problem.
It;s also possible the scanner is jerking as it goes across the bed, which is causing the line. Is the line solid, dashed, bold, thin or just kinda there?
Mar 14, 2009 | HP DeskJet F380 All-In-One Printer
Epson Stylus CX6600 does not print
Suggest you try resetting the waste ink counter on this printer to see if it will then allow it to print again.
  1. You will see big button on your printer like power on (this is on the left
  2. side), black & white photocopy, color photocopy, and then the stop button (these are on the right side).
  3. first turn off your printer
  4. push the b/w + color + stop buttons together and hold
  5. push the power on button and hold (so you'll now be holding down 4 buttons together)
  6. Don't release all the buttons until you see the light indicator is blinking and then a message display on the lcd
  7. release all the buttons
  8. push the color button (once)
  9. turn off the printer
  10. turn it on again
IF this works you will then need to fit an external waste ink tank as soon as possible to ensure you don't end up with a major headache (ie: ink swimming pool!) under your printer.
Instructions for completing the modification are available if you google your printer model and "waste ink".
Jan 17, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Photocopier prints red
You might be running low on black ink and it's not an item when you print from your computer because the settings you are calling for are different. The computer asks you if you want to print normal...to best, etc.
Apr 25, 2008 | Dell 924 All-in-One InkJet Printer
Epson DX 4000 printer
Thats interesting, check for obstruction inside the printer and try to do a selftest in which it will print a nozzle check pattern, chances are there is a faulty wiring that is why its not accepting commands when copying something. try to turn off printer and unnplug it from power supply then plug it back on a different socket or power outlet,
try copying again.
Apr 12, 2008 | Epson Stylus DX4200 All-In-One InkJet...
Brother MFC 210C All-In-One InkJet Printer Logo
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
