Question about HP Compaq Presario V2000 Notebook
Help Please. I'm not to bright when it comes to computers or laptops. But need to know how to lighten the screen on a Gateway laptop, it's to dark to see. Can you help. Thanks Becky
    Novelist:
  • 188 Answers
Is it so dim that the screen cannot be read with shining a flashlight into it? if so this is a hardware failure not a brightness setting. let me know if it is.
If it is just somewhat dim but readable, there is probably a hotkey. Gateway laptops are all different.
Google search for your particular model and specifications. you will get the gateway support page for your notebook.
for example if you have an mx6550 enter this at google.com
mx6550 specifications
Posted on Dec 18, 2007
How do i get my screen to lighten up it to dark
Have you tried using the F2 button?
Else go to system settings > displays, there you can adjust brightness as well.
Also you can switch off the auto brightness there. 25262036-egkukr40z00e2y5uxj02hrxw-1-0.png
Oct 30, 2014 | Apple Computers & Internet
Screen to dark
There should be brightness controls on the keyboard (looks like a sun). Do you have these? Sometimes you need to press a Fn key to access them
Dec 22, 2012 | Compaq Presario CQ62-215DX Laptop
Hp530 screen real dark can see little how to
If it's due to the display settings on your computer, please do this-
Keep on holding down the function key(Fn - probably second key from bottom left) on the laptop and then press F10 key till you get the screen to become brighter.
Please let me know if it works, otherwise, we will have to gothrough a series of steps to resolve it.
Dec 27, 2009 | HP 530 Notebook
I need to lighten my screen
this is not a computer problem you have to press the buttons on your monitor that is a menu when the menu comes up change the brightness
Nov 14, 2009 | Averatec 7171000100 Keyboard
Was cleaning dell laptop screen and it went dark, is there a switch To lighten it back up?
Look on the function keys for a delicate blue description ... press the fN key and the brightness increase key.
I doubt you accidently unplugged the screen ... but dont discount that totally.
Good luck to you
a
Oct 12, 2009 | HP Pavilion zd8000 Notebook
MONITOR VERY DARK
Try using the FN key and the up arrow at the same time while tapping the up arrow, also make sure that if you have vista, you are not in "power saver mode". if there is no light at all coming from your screen, you may have a bad display bulb, this could also be a faulty invertor, but you would have noticed a constant flicker.
Sep 07, 2009 | Gateway Computers & Internet
My laptop will, once in a while (every couple months), have3 "issues" with its brightness/contrast. If I leave the brightness alone, it will turn most of the screen red. If I lighten the brightness AND the...
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 14, 2009 | Gateway M320X Notebook
I have gateway model MT3418 What key with FN do I press to lighten or darken screen?
To change the lcd brightness, press Fn key and the up and down arrow key's at the lower right of the keyboard.
Apr 15, 2009 | Gateway MX6453 Notebook
VERY DARK SCREEN
looks like your gonna need a new screen ( MAYBE )
may just be a loose or broken wire.
before it gets any worse take it to a small repair shop they'll charge you less then a major outlet.
Most will tell you on the spot at no cost if you need a new screen or not.
and yes the screen can be expensive
please rate me
Feb 01, 2009 | Dell Inspiron XPS M140 Notebook
Acer Aspire 5630 screen brightness adjustment...
How do I adjust my brightness or contrast on my laptop? See our brightness definition for a visual example. Finally, most laptops only enable users to adjust their brightness of their screen.
Click on the above Link, Good Luck, Please dont for get to Vote.Thank you.
Dec 15, 2007 | Acer Aspire 5100 Notebook
HP Compaq Presario V2000 Notebook Logo
132 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
