Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Where do I open the set to replace the lamp - Philips 60PP9202 60" Rear Projection HDTV-Ready Television
  • 647 Answers
This is a CRT projection TV and does not have a bulb -it has three picture tubes (red, green and blue)
Posted on Sep 27, 2009
My mitsubishi flashes a red light what does that mean
Red light is usually lamp indicator---may be time to replace the lamp--they have a 2000 hour life span except for generic ones which last half that long----when was lamp last replaced? also the set does have a self check:
After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Oct 30, 2012 | Mitsubishi WD-60737 60 in. HDTV
Replacing Light bulb w/housing
Lamp is replaced by customer in most cases---look to owner manual---in general if lamp up front (I think yours is by the model number indicated) the front plate beneath the screen gets removed (have set unplugged) and a lamp door is marked---it opens when screw/s securing it are removed.
Inside are two more screws---with them removed grasp the handle for the cartridge with the lamp and pull it out.
Be sure to get a Mitsubishi lamp and not a generic "bulb" which would require you to take the housing apart---generic bulbs have a much shorter life.
carefully slide the replacement in so the two pins on the rear connect correctly into the socket in the set where they go.
there are video instructions for many sets on You Tube.
Jun 01, 2012 | Mitsubishi WD-57732 Projection Television
Timer is lock replace bulb
This set has all kinds of problems--
try the self check:
Mitsubishi TVtroubleshooting
Here's something that might also be useful. After you turn on the set, and getthe regular red blinky lights, hold down the Device and Menu buttons togetherfor about 5 seconds.
33 = Air filtercover is open.
44 = DVI cablebetween FMT and Engine disconnected
Jun 01, 2012 | Televison & Video
No screen and clicking sound
This set and the one before it (50lc13) had so many problems the latter was recalled and all were exchanged.
Someone would have to open set and check power supply first--set is not real easy to work on.
The recall involved issues where the sets were eating lamps up alive--very short lamp life---solution at first was to rebuild/replace the Ballast which drives the lamp.
Average life should be 2 years or 2,000 hours on that lamp.
May 25, 2012 | Panasonic PT-50LC14 50" Rear Projection...
Replace lamp
unplug unit.
undo screw on lamp cover and open.
remove 2 screws and pull out the lamp.
install new lamp and do in reverse.
reset lamp timer
press menu, go to setting, and press the select button.
select lamp age
click yes to 'lamp replace monitor reset'
OK is displayed, select yes
then select no
quit
Mar 03, 2011 | Sanyo PLC XP21N Multimedia Projector
Pt-52lcx66 not very bright set on highest bright setting and in vivid mode
It is most likely your lamp. The lamps have around a 3-5 year lifespan depending on how often you watch the TV. You can check for this yourself by opening the lamp door and removing the lamp to check for a cloud around the bulb or stem of the lamp. There are step by step directions for lamp replacement in your user's manual. They made it so it is consumer accessible and should not take more than 15 minutes to replace.
If you see any imperfections on the lamp then the lamp should be replaced to get a picture as bright as the day you bought it.
Nov 13, 2009 | Panasonic PT-52LCX65 44" HDTV
I need to replace my 42 in Sony WEGA HDTV Projection lamp KDF-42E2000
Lamp code XL-2400 is Sony part number F93087500 and it is available on http://www.partstore.com/. You may also decide to purchase the less expensive Philips Lighting lamp part number F93087500RL. Either will work for your television set.
Jul 19, 2009 | Sony Office Equipment & Supplies
Mitsubishi WD-62525 DLP has no picture
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
Feb 03, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Lamp light blinks after lamp replacement
I have the service manual and it shows two door switches Dr 1 is in the back of the set on rt bottom below the temp. sensor. Dr 2 is at the front panel where you open it to replace the lamp. If one of these switches are open, it would show a lamp problem. If you have a Muiltimeter and can get to the switches see if one of them is open. Hope this is helpful.
Nov 09, 2007 | Hitachi 50V715 50" Rear Projection...
Replacing LCD Lamp
The lamp may not be the defective part as the ballast board has been known to cause problems with this model - Part#6913v00002c You didn't mention how long you have used the set, and I believe the lamp should last at least 4000 hours. The lamp is usually replaced by opening a door by taking out one or two screws in the back or side of the set.
Dec 29, 2006 | Zenith E44W46LCD 44" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
129 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
