Question about Canon PowerShot A1100 IS Digital Camera
Camera turns on and appears to function, but wiil
Camera turns on and appears to function (zoom, menu, replay, etc.), but wiil not take a picture when button is depressed. Batteries are new. Briefly exposed to some moisture, but allowed to dry-out with batteries & SD card removed in 90 degree dry weather (dew point ~25).
  • zano4860 Sep 28, 2009
    Camera is brand new. Contacts are clean & bright. Batteries are new. Could I have cooked a circuit?
    President:
  • 2,761 Answers
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your camera may have a problem that requires professional repair.
Posted on Sep 27, 2009
  • Bill Buchsbaum
    Bill Buchsbaum Oct 21, 2009
    Didn't realize that it was brand new. Not good news, but the moisture likely damaged some of the VERY sensitive circuitry in your camera.
IXUS 70 with black screen!
Did you accidentally press the lower-left DISP button on the back of your camera? This manually turns the screen on and off to save battery power. You would then use the optical viewfinder in its place. Try pressing the DISP button once to see if the screen turns back on.
Jun 20, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
Panasonic DMC FZ50 digital camera
when you are replaying your pictures you use the front turning switch, not the manual focus ring.
Hope I helped, please rate my answer if you like it.
Vladimir
Sep 28, 2008 | Panasonic Lumix DMC-FZ50K Digital Camera
Will not select menu
go to SETUP menu (Page 20 in my instruction book) and set ZOOM RESUME to OFF. Then it will open up at widest setting all the time.
Aug 15, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Camera froze up w/ no button function
hello, these units have a very fine zoom switch and can get damaged by a drop or fine sand. the zoom switch sits under the actual button. if you turn the camera on in camera mode and the display is showing the zoom on screen display then you know it is the switch.
May 21, 2008 | Panasonic Lumix DMC-FX7 Digital Camera
A spot appears in same location on every picture
take the lens out and blow air inside the camera and on the inside part of the lens.
Jan 10, 2008 | Nikon D40x Digital Camera
Shutter button +++
Hi your camera having problem inside , you may visit fixia authorized repair shop near you , just enter zip and then go , can find down right side.
Jan 08, 2008 | Canon PowerShot A520 Digital Camera
Turns on, but won't work
Can someone give me a solution to this problem please
Dec 12, 2007 | Panasonic Lumix DMC-FX3 Digital Camera
Camera problem
Hey, i have had the same problem for over a year. My camera also wasn't briefly showing me the pictures i took right after taking the picture like it used to. Last night i found the "Quick View" function was turned off in the menu (up arrow) of the camera, so i turned it back on. Today i tried the zoom function (i haven't tried it in a year) and IT WORKED!! So i think they are linked somehow.
So try going to your menu (up arrow) then scroll down until it goes to the next page of the menu. Select "Quick View" and turn it on. Then your zoom might work. It worked for me, but i don't know if mine is an isolated incedent.
Try it and see.
Xavi
Nov 19, 2007 | Optimus DS-5080 Digital Camera
Cant take any pictures
the Shutter or some assicated components is shattered. This may be a repair situation at Nikon- but if you have had the camera for some time I suspect you will be buying another camera.
Aug 13, 2006 | Nikon CoolPix S2 Digital Camera
Canon PowerShot A1100 IS Digital Camera Logo
165 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
