Question about Electrical Supplies
Starter problem on a suzuki SE4000 genset.
My starter pinion is broken. Suzuki has listed this part as N.L.A.It is a Nippondenso starter.Numbers on the tag are 31100-87400 ,12v,ccw rotation veiwed from drive end.The pinion has 9 teeth. Kohler uses N.D. starters on their engines,could they have a usable starter drive?
4 Suggested Answers
  • 154 Answers
SOURCE: I have a suzuki SE4000
you can find one on www.instuction-manuals.co.uk/category/MISC.htm
Posted on Jun 14, 2009
  • 243 Answers
SOURCE: I have a Kohler 12RES, 12.5kw genset. Less than a
check connections on speedsensor or take down rpms must be a screw or bolt on de fuelpump
Posted on Feb 10, 2010
  • 905 Answers
SOURCE: 1975, 7.5 Kohler marine genset, runs only with the reset depresed
Can't search for a manual without model, type, serial, etc numbers...
A few things to take a look at:
1) Oil level / pressure sending unit. This is normally bypassed as long as the start switch is pressed. When engine starts, and switch is released, engine will die if sending unit is defective, or you are low on oil.
2) Exhaust temperature sensors. Older units were notorious for burning these up.
3) Cooling Water Temperature sensor. These cause trouble often, but mostly due to water pump impeller being eaten away by galvanic action and not able to pump water as effecively. End result is water temp higher than normal, which trips the switch, which kills the engine.
4) Alternator (generator) output not as it should. If output doesn't rise to proper level within a few seconds of engine start, the engine will be shut down.
5) Choke not working as it should
6) Bad fuel, bad fuel pump, clogged fuel filter.
Posted on Jun 12, 2010
I have a 2007 gsxr and i have went through and checked everything it wont turn over i took the starter off bench tested it it works i took stator cover off and turned engine by hand
Hi, Timothy and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
6. FOB battery low or dead.
7. Faulty ignition switch.
8. Faulty starter button.
9. Faulty kickstand or clutch pull in switch/sensor.
10. Security alarm needs a reset.
11. Starter control circuit, relay, or solenoid faulty.
12. Main fuse or circuit breaker may be blown or faulty.
13. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
14. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a wonderful day.
Bike won turn over
Help Troubleshooting 2003 GSXR 600 Won turn over
Suzuki GSXR electrical issues starter relay won start PROBLEM SOLVED
Suzuki GSX R750 Service Manual
OEM parts for Suzuki
http://mybikemanuals.com/suzuki/suzuki-gsx-owners-manuals
Feb 28, 2017 | 2007 Suzuki GSX-R 600
86 suzuki savage 650 new battery new starter new solenoid but wont start
Hi, Vera and the usual suspects are:
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Faulty ignition switch.
6. Faulty starter button.
7. Faulty kickstand or clutch pull in switch/sensor.
8. Security alarm needs a reset.
9. Starter control circuit, relay, or solenoid faulty.
10. Main fuse or circuit breaker may be blown or faulty.
11. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Thread Suzuki Savage won start Help Newbie
SUZUKI LS650P Manual
Suzuki LS650 Savage 1986 2004 Workshop Repair Service Manual Download...
Jul 17, 2016 | Suzuki Motorcycles
2000 Suzuki 600 GSX-R
Hi, Robert and the usual suspects are:
2000 suzuki gsxr 600 wont turn over
http://www.suzukigsxr.cz/docs/Suzuki_GSX-R_600_K4+K5.pdf
Jul 02, 2016 | 2000 Suzuki GSX-R 600
I got a 1995 250 4x4 Suzuki quadrunner starter spin but engine want rotate
pull the starter
there is either a problem with the solenoid connecting the terminals inside before engaging the pinion gear (plunger disconnected from lever that moves the pinion gear forward
OR
the over run clutch of the pinion gear has failed and is not locking the gear in the drive position
Mar 05, 2016 | Suzuki Motorcycles
1996 suzuki king quad lt-f4wd
Hi, Ryan and the usual suspects are:
3. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Security alarm needs a reset.
6. Starter control circuit, relay, or solenoid faulty.
7. Faulty starter button.
8. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue, please visit the websites below. Good luck and have nice a day.
Tearing apart my 1997 Suzuki King Quad 300 LTF4WD
http://atvconnection.com/forums/archive/index.php/f-14-p-8.html Suzuki KingQuad 280 QuadRunner LT 4WD LT F4WDX 250 Manual
Jan 01, 2016 | Suzuki Motorcycles
No power when key is turned on gages do there thing when key is turned off if wiggle key in on position get lite for a sec
Hi Charles and the usual suspects are:
1. Ignition switch not in the "ON" position.
2. Engine run switch in the "OFF" position.
3. Discharged battery, loose, corroded or broken battery cables, especially the "NEGATIVE" cable at both ends (solenoid chatters).
7. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
2002 Suzuki Motorcycle Service Repair Workshop Manuals
Oct 13, 2015 | Suzuki Motorcycles
MY STARTER WILL NOT DISENGAGE ON 2005 SUZUKI BOULEVARD C90
This is not an uncommon problem with starter pinion gears. Some times when the starter is replaced the shim between the starter and the flywheel is left out or the wrong shim is used. If the starter has not been replaced and the issue is not with a wrong shim, I would try to lubricate the pinion gear ( WD40, etc.) and tap it gently with a rubber mallet , and see if it retracts. You may get lucky and the gear will retract, but in the long run, you should consider replacing the starter with a new one.
Jun 19, 2014 | 2005 Suzuki Boulevard C90T
Suzuki Vitara 2007
The battery terminal connections is loose or corroded.
Battery faulty or discharged, if the cable are clean and tight on the battery turn the key to the ON position and switch the headlights or windshield wipers. If they won't run then the battery is discharged.
Broken, loose or disconnected wires in the starting circuit.
Starter motor pinion jammed in flywheel ring gear.
Starter solenoid faulty, Starter motor faulty, Ignition switch faulty.
Nov 23, 2013 | Suzuki Cars & Trucks
I have ordered a service manual for my older model Suzuki DT16 outboard motor, where is the water discharge located, I don't see any water coming out ?
I've got a 1981 DT16 with a broken starter pinion. Did you solve your problem? Mine is for sale with very low hours.
Jun 21, 2009 | Sport & Outdoor - Others
Electrical Supplies Logo
176 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
