Question about Sport & Outdoor - Others
My pump is running but the water is flowing slowly into the basket, never filling up. I have cleaned everything and its still not flowing right. the gauge is not moving and stays on 0. barely any suction. i dont know what else to do.this is a pool pump
  • irishdebweis Sep 27, 2009
    still not working. i tried the water hose in the skimmer and still did not work
    Pentair whisperflo pump runs, sounds good, wont prime no pressure, hardly any suction. Anyone???
  • 1,068 Answers
Your line is plugged up! the one coming from the basket to the pump.
you cleaned all the filters out and back washed the system?
Posted on Sep 27, 2009
  • 1 more comment
  • michael schultz
    michael schultz Sep 27, 2009
    you have to blow air through it with an air compressor to see if it builds pressure and if it does then it is plugged.
  • michael schultz
    work with me here we need so more info and if you have tried these suggestion.
  • michael schultz
    michael schultz Sep 28, 2009
    did you figure out the pump/ just wondering i haven't heard back from you?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. When a pump is not primed, the motor is running, but no water is being pumped through it. If a pump runs unprimed for a length of time, it can do serious damage to the pump components.
It is normal for a pump to take up to a minute or two to prime up. In some extreme cases, it might take up to five minutes to prime a pump. If it does not prime up within that time, then something is probably wrong.
When attempting to prime a pump, make sure that the pump pot is full of water and that the lid is securely attached. Make sure also that the lid o-ring is sealing properly. A light coat of silicone lube is a good idea. If the lid o-ring is hard, flat or damaged, it should be replaced.
If the pump shows no signs of priming up on its own, it may be necessary to force water from the skimmer into the pump to encourage the pump to prime. This is sometimes needed if the pump is situated more than a foot above the water level.
The best way to do this is by using a "drain jet" in the skimmer
1. Hook the drain jet up to a garden hose and insert it into the skimmer line that leads to the pump. Shut off or plug all the other intakes (main drains, skimmers). This will force water into the pump.
2. Turn on the water and let it force water up into the pump trap. When the water has filled the trap, turn the pump on.
3. As the pump starts to prime, open up one of the other intakes partially in order to keep from starving the pump. This will allow the pump to fully prime. As the pump primes, open the other intakes gradually, allowing the pump to pull out any trapped air.
4. When the pump is fully primed, turn off the drain jet and remove it. Be careful that you do not allow the drain jet to be sucked into the skimmer line.
Also check for--
1. Check filter pressure gauge, filter may need cleaning.
2. Check for clogged plumbing lines around the pool pump.
3. Check for worn or damaged impeller in the pool pump.
4. Check for low voltage.
If the pump will not prime, even using a drain jet, then check the pump components for blockage or breakage.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
How do i prime this swimming pool pump?
The normal procedure would be to unscrew the top of the inlet basket and fill that with water until it flow out down the inlet pipe, then replace the top cover. Make sure the skimmer box basket is clean, the pool water level is high, or put a fast running hose in the skimmer box to make sure the primed pump does not have to pull the water up from too low at the inlet.
If it will not pull the pool water in when started, then -
- there is a leak or blockage somewhere on the inlet side
- the pump impeller is damaged
- the filter is clogged too much and causing back pressure
- the pump power and pipe sizing are mismatched
Oct 08, 2014 | Pool & Spa
Low flow rate
You probably have debris clogged in the impeller. The pump has to be opened to clean or repair the impeller.
Apr 12, 2013 | Hayward C550 Swimming Pool Filter System...
No water flowing through pump
check top seal if ok check intake union see if loose or see if debris in impeller
Jun 16, 2012 | Pentair 15 Hp Superflo Swimming Pool Pump
I have a 1hp sta-rite above ground pool pump. The pump model number is MPRA6E-147L The pump is about 4 years old, and during our summers it runs about 12 hours a day (May through September) and during...
It sounds like there was a lack of water to the reservoir, which is, I assume the inlet reservoir with the basket strainer in it.
1. Is your water level in the pool high enough to keep the reservoir full?
2. There is an o-ring or gasket on the reservoir cover, is it there and lubricated so there is no air leakage?
3. Put a garden hose into the open reservoir to see if the pump moves this water out.
Do all of this with the filter set to just go back to the pool so you can see the results.
Try this and comment back.
Good Luck,
Gary
Dec 11, 2010 | Sta Rite Pool & Spa
I am contacting you as I am a bit desperate for help. Please advise as to what should be done with regard to the Savio Skimmer Filter SS0000. At around 5pm when feeding the fish, I noted the skimmer...
This means that the filter or leaf basket is blocked. When the pump is off, the water levels will look fine, but when the pump pulls water through, even a partial blockage of the filter or basket limits flow so the level falls and eventually the pump 'sucks air'. Remove and thoroughly clean the leaf basket and filter. Good luck!
Aug 12, 2010 | Garden
My pump is not drawing water from the pool, dissambeled pump and it is clean and free of obstructions. removed pump from motor and inpeller is spinning when plugged in and the defuser seems to be ok...
Ok I''m assuming the pump is mounted higher than the water level in the pool. This means it needs to be primed. If everything is air tight, it should be self priming. Check to be sure your piping is open from the skimmer to the pump and not clogged. You can put a garden hose into the suction line of the pump and feel for flow coming up out of the bottom of the skimmer. If that is ok, then fill the pump strainer basket with water. Be sure filter is selected to filter. Make sure that the basket cover is tight to the cover gasket. After filling basket with water, quickly close the cover and start pump. If it still doesn't work, fill the basket again with water and check for any leaks. If the mechanical seal is leaking, it will not self prime. I'm not sure what type of pump you have, but Hayward has complete manuals for their pumps on www.haywardnet.com. Most pumps work about the same. GOOD LUCK!
Aug 02, 2010 | Pool & Spa
I have a Jacuzzi AO Smith 1.0hp pump for an inground pool - my husband turned off everything to clean the basket in the pump and now we cannot get it going again. We filled up the pump to prime it, put the...
Ok I assume the pump is running? Check the lid again to be sure the "O" ring gasket is in place. If it leaks, it will draw in air, and won't flow full flow. Also check the lid for cracks. If you have seperate valves on your skimmer and main drain, I ususally close the skimmer valve and open the main drain valve fully. Once the pump is pumping full, I usually open the skimer fully, and only open the main drain about 40%. Another tip would be to close these valves on the suction side when you clean the basket,and do it rather quickly, and you won't have as much trouble loosing your prime.
Jul 07, 2010 | Jacuzzi Pool & Spa
I live in a limestone area and the flow through my Senseo coffee maker is slowly reducing. How should I descale it?
Believe it or not, vinegar is a blessing for cleaning nearly anything out of your coffee maker.
Fill your water reservoir 1/4th full with vinegar, then fill it the rest of the way up with water.
Run the coffee maker, then let it sit for about 10 minutes. Pour the mixture back in to the reservoir and run it again. Let it sit another 10 minutes.
Dump the mixture and use plain water this time. Let it sit for another 10 minutes. Dump the water, then repeat with clean plain water.
Wash the filter basket and pot with hot soapy water. If the vinegar smell is still present, just run it again with plain clean water.
Oct 10, 2009 | Philips Senseo HD-7810 Coffee Maker
My pool pump won't prime
If the pump is above the pool water level the it is unlikly that the tank will fill completely with valves open (which is ok).Most pumps are self priming and will pick up a prime with water level below suction inlet on strainer. Try starting on main drain again and slowly open skimmer line. Did you remove water from skimmer line and winterize(if in cold weather climate)during closing?.I know this sounds stupid, but make sure water level in pool is well into skimmer. If air situation remains after scspriggs' and these thoughts then prepare for a pressure test on skimmer line to determine location of leakage.
Apr 21, 2009 | Hayward 3/4hp Super Pump Inground Pool...
Sport & Outdoor - Others Logo
66 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
