Question about LG DLE2512W Electric Dryer
My LG dryer DLE 2512W ran for 3 hours
My DLE 2512W ran for 3 hours while I ran errands. My clothes we're almost smoking. When the door is closed- it runs and will not stop. None of the button controls work. I cleaned sensors, unplugged unit. Any more suggestions?
  • 1,531 Answers
Replace the main control board
Posted on Sep 27, 2009
LG DLE 2512W Electric dryer
There was no comment of the fault that was seen on your machine and so would request your observation.
Oct 18, 2011 | LG DLE2512W Electric Dryer
LG Dryer Model # DLE 2050 W is not drying. It is getting hot but clothes remain wet even after 2- 1 hour cycles. The information panel is blinking with a message that says "FLOW SENSE". The...
If your
dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about
Dryer Maintenance
heatman101
Feb 14, 2011 | LG Dryers
My dryer DLE 2514W does not dry the clothes enought, we have to put it on for a second time to get them all dry. Seems to be alot of heat but doesnt dry the clothes
disconnect vent hose and run a load of clothes, if they are dry then the vent hose is restricted/clogged. if for some reason it is doing the same then take dryer apart and clean from lint screen back, I am almost certain that it is the vent tube.
Dec 23, 2010 | LG DLE2514 Electric Dryer
My LG DLE 5977 S Dryer doesn't dry the clothes completely. I have to restart it multiple times to get a load to completely dry.
Check to see if there is a kink in your vent hose in backj.
Go outside to verify
Clean filter with dishwashing liquid and brush
Run water on filter first to verify it doesn't go through
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
Sep 11, 2010 | LG DLE5977 Electric Dryer
Severe noise - drum is jammed and won't turn - LG DLE-5977 dryer
A piece of clothing is probably caught in the blower wheel.
Remove lint filter.
Use flashlight to look into filter housing to the lower left.
You may be able to retrive the item if you can see it.
Try rotating the drum in both directions while looking.
Jan 07, 2010 | LG DLE5977 Stainless Steel Electric Dryer
I have a DLE 7177WM LG electric dryer is sound
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve you noise problem.
Good Luck,
I hope this helps
Oct 14, 2009 | LG DLE7177 Dryer
LG Tromm DLE Dryer never dries my clothes when the cycle is done
ok there,first the clothes must come out off your washer well spun,or dryer will work extra hard/long.next you dry a load with out ducting to elimanate your house venting[you wont hurt a thing]most off the time thats it![house]if still bad and you know your dryer is cleaned out then its an electrical problem.will go ther after you check the above.God bless.please help with my ratings if i have be helpful,tom
Jan 02, 2009 | LG WM2688HWM TROMM SteamWasher
Dryer door pops open. leaves burn marks on clothes.
check to see if you have bent door hinges first, do this by opening the door all the way down and see if it is level with the floor. if it goes past level then the hinges are bent.
guess someone may have fell on the door or used it as a step.
if so, then you can take a hand towel and roll it up, then put it at the bottom of the door and close the door gently to "bend" the hinges back into place. this will aloow the door to stay closed and should also take care of the "burn" marks on your clothes.
i would guess the unit was overheating from the door not closing right allowing air to enter around the door. that will cause the unit to overheat and leave marks on your clothes.
Dec 28, 2008 | Kenmore 63942 Dryer
Dryer Tronm DLE 2514
If its new u should have a warranty still on it.. most have a Leat a year... Gas isnt anything to be messing around with.. Find out about u warranty or call a repair man.
Aug 12, 2007 | LG DLE2514 Electric Dryer
LG DLE2512W Electric Dryer Logo
241 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
