Question about Nintendo Wii Console
My Wii console still runs after I turn it off.
My Wii console still runs after I turn off the unit. Red light is on and the unit is still running. I can unplug the power and it stops spinning. Any suggestions?
    Scholar:
  • 50 Answers
As long as the unit is plugged in, then the red light will still be there, that is just how the console works.
If you mean that it is spinning the disc, then I can't help you. If it really annoys you take out the disc after your done, and then it shouldn't spin. Unless I'm missing something that you need to specify, that's the only thing I can think of.
Posted on Sep 27, 2009
I have a wii fit board, when you power it up, it
Had the same problem. It's a sync problem.
First, best to double check you have fresh batteries.
Next, turn the board upside down and remove the cover from the battery compartment.
Open the small hatch cover on the front of your console unit.
Now start wii fit from the disk menu item.
Next, press the small red button inside the balance board battery compartment. The blue lights will blink for approx 3=5 sec.
While they are blinking, press the red button on the console (in the hatch compartment).
This should re-sync your board and the light stays lit.
Good luck.
Apr 07, 2010 | Nintendo CTA Digital WI-BBP Wii Fit...
I am attempting to adjust my wii remote sensitivity. The minus button will not work. it is currently set at 5...when I press the plus button it beeps as if I am adjusting in the positive, however when I...
Here are few Home remedies that should help you fix the issue.If you still face any problems then it is an internal issue with your remote and you will have to contact the nintendo support.
  1. Clean the Wii remote pointer lens. Use a soft cloth to remove any sticky substances. Wii remote jackets, stickers or other objects should not block the remote pointer lens, as it will cause characters to move erratically, disappear or remain off-center.
  2. Operate the Wii remote between three to eight feet away from the sensor. Otherwise, it will not perform properly.
  3. Note that infra-red lights from candles, toys, appliances, fireplaces and even sunlight may effect how the Wii remote performs. Try to remove or reduce infra-red interference from these sources when possible.
  4. Turn off or move wireless devices located near the Wii console. You may be experiencing radio frequency interference from other wireless devices.
  5. Check to see if anything is blocking the sensor. Clear objects away from the sensor and console to enable the remote to send a clear signal to the Wii system.
  6. Center the sensor bar directly below or above your television. Having the sensor off-center may cause the Wii remote to perform poorly.
Re-sync the Wii remote to the Wii system:
  1. Completely turn off the Wii system. Remove the batteries from the remote. Turn the power off on the Wii console. Unplug the unit from the wall. Wait five seconds and then replug the unit into the wall.
  2. Push the power button to turn on the Wii console. After the health and safety screen appears, open the small door on the front of the Wii console. Locate the red SYNC button. Push down on the SYNC button for fifteen seconds. This resets all previous SYNCS on the Wii system.
  3. Re-sync the Wii remote. Locate the red button on the remote control under the battery cover. Push and release this red button. The Wii remote should respond with blinking blue lights.
  4. Push and release the red SYNC button on the Wii console. Place the batteries back in the remote. When the remote is successfully re-synced, the LED light will remain lit.
  5. Repeat the re-syncing process with all other Wii remotes on this system.
Thank You
Oct 19, 2009 | Nintendo Wii Console
When I turn my Wii off it continues to run and stay hot, even when there is no game inside.
i don't know if i'm just repeating what you already know, but here's some advice if you don't know what i'm about to say.
1. hold in the on/off button for 5 seconds or more until it turns red
2. just unplug it (beware that simply unplugging a electrical unit such as a computer or gaming system like the wii, could over time severely damage the machine)
May 02, 2009 | Nintendo Wii Console
Wii will not turn on... no red light
Sounds like the unit may have experienced over voltage, there is a fuse on the board however I would take the easy route and test a new power brick to see if this solves the issue. Thank you
Feb 15, 2009 | Nintendo Wii Console
My wii will turn on but will not turn off it will also have nothing on the tv screen when u turn it on
Hold the power button on the front of the unit for about ten seconds. The light will turn red. Turn back on again.
Jan 13, 2009 | Nintendo Wii Console
Synching wii fit causes wii console to no longer power up
1, Turn off and unplug your wii console for a few minutes
2,Turn the power back on and when you see the the safety screen open the small flap on the front of the wii console. Inside you will find the red sync button. Press and hold the red button down for 15 seconds.
* Then remove the battery cover from the wii remote, inside you will see another red button.
* Press and release the red button, the blue lights on the remote will start blinking.
* Quickly press and release the red sync button on the wii console.
* The remote will stop blinking and it should now be synced.
then try syncing your wii fit bored
Dec 28, 2008 | Nintendo Wii Console
Wii fit
Have had this problem before with wii sports. What I did was turn off the wii console and unplug from the power, leave for a few seconds then turn it back on when the health & safety screen comes up
  1. Turn the Wii console power OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds. After a few seconds have elapsed, plug the cord back into the wall outlet.
  2. Turn the power of the Wii console ON. When you see the Health and Safety screen, open the small flap on the front of the Wii console to find a red button labeled "SYNC." Press and hold the SYNC Button down for 15 seconds. This will clear all the syncs on the Wii, allowing you to get a clean start to begin the process described below.
  3. After holding the SYNC Button on the Wii console down for at least 15 seconds, you can now "re-sync" your Wii Remotes:
  4. With the first Wii Remote you wish to sync, remove the battery cover on the back of the Wii Remote to find a small red button just below the batteries.
  5. Press and release the small red button just below the batteries on the Wii Remote; the blue lights on the front of the Wii Remote will blink.
  6. Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console (picture).
  7. When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
Jun 23, 2008 | Nintendo Wii Console
Wii standby light
To be precise, you can turn this option off from the Wii System settings -> Wii Connect 24 -> standby connection -> off
When this setting is swiched to off, your console shuts down entirely and there is a RED light on the power button. There will be no need to turn off the console pressing the power button.
Jun 10, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
35 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
