Question about Sony Playstation 3 (PS3) Console
I can't connect to the internet
I cannot internet, im tryin to access my wireless internet and my PS3 just wont get me an IP address. How can I get my IP address to access my wireless internet?
Thank you.
    Problem Solver:
  • 5 Answers
Make sure that when u go to internet connection settings to hit the scan icon and then it will show a list of wireless networks that are in range. Then click yours and click no for security. Hope this works
Posted on Dec 18, 2007
I have wireless internet how do I get a ip address connect my ps3
The IP address is provided by the wireless router when you perform the connection process. You will need to locate your wireless network on the PS3, select it, and when prompted for the security key/code, enter it to gain a connection. Once the connection is established, the PS3 will have an IP address.
Oct 12, 2016 | Sony Playstation 3 (PS3) Console
Ps3 wont connect to wireless
Reset your router, then give your PS3 a static IP address and go into your router interface, find the DMZ feature and put in the IP address that you gave the PS3, just make sure the IP you give it is within the DHCP pool of IP addresses.
The PS3 will now be sat outside the routers firewall giving you FULL access to internet content and gaming online.
Now test connection settings and you will notice you will now have an open connection to the internet.
Thanks
Sep 02, 2009 | Sony PlayStation® 3 (60 GB) Console
Why won't my ps3 connect to my wireless router? An IP address is needed which it will not find, only on wired connection will it connect!?
Disconnect the LAN cable from the PS3.
The PS3 needs to be configured as follows :-
Select Network Settings - Easy - Wireless - Scan, select your wireless router, select your SSID, if it isn't displayed the type it in, select security settings, enter your router's encryption settings
Your router will issue an IP address to the PS3 and you will able to access the Internet wirelessly.
Jul 26, 2009 | Computers & Internet
When i do a connection test on my ps3, my ip address is successful, my internet connection is successful but my playstation network has failed. what does this mean? im not very into the playstation as i...
IT MIGHT BE THE PROBLE OF THE CONNECTION. SOMETIMES USERNAME OR PASSWORD WRONG. AS I AM ALSO USING WIRELESS CONNECTION TO CONNECT Y PS3 IT HAS ALWAYS BEEN SUCCESSFUL.
Jul 11, 2009 | Sony Playstation 3 (PS3) Console
Ps3 error code 80711008 and wpa
OK for your WPA you can check the security key by accessing the router http://192.168.1.1 .. password is by default "admin" and username is blank...go to the "wireless" tab and check the ssid...under "wireless security" check the security key...if you have "wep" check the numbers in "key 1"....
now make sure that you connect to your own ssid and type the correct key...
and you are right , you need wlan to connect to the internet wirelessly...however , first make sure that you have internet working through the router..if not you will have to configure the router and for that you a computer connected to the router...
As for your IP address simple use this site http://www.ip-adress.com/ should be everything you need
May 30, 2009 | Sony Playstation 3 (PS3) Console
Internet connection fails on ps3
im really only experienced with xbox but your best bet is to call sony for help.
Jan 31, 2009 | NetGear RangeMax WPN824 Wireless Router...
DNS error
try this at DNS # 4.2.2.2 and 4.2.2.1
Oct 18, 2008 | Sony Playstation 3 (PS3) Console
Internet Connection
On the X-Cross Media Bar, (the menu that comes up when you turn on the PS3) under "settings", go to "Network Settings".
then go to "Internet Connection Settings". select "yes".
go to "custom", "Wireless", "Scan".
If your network is not listed, move your PS3 closer to the Wireless Access point.
Select your Network and enter your password (if it needs one).
select "automatic" for everything.
select "Test Connection".
the "Obtain IP Adress" and "Internet Connection" should say "Succeeded".
If not, contact your system or network administrator or a teacher that knows a lot about computers.
Aug 17, 2008 | Sony Playstation 3 (PS3) Console
My playstation 3 wont connect to the internet
Hey,
Im having the same problem....It keeps saying that cannot find IP address...I have read that, it could be that im using bell sympatico and its DSL. Supposibly you need PPPoE.....How do I find that?
Feb 03, 2008 | Sony Playstation 3 (PS3) Console
My ps3 will not connect to my wireless internet
Try setting a static ip address on the PS3:-
First you need to find a Windows wired or wireless device already connected to the network in order to find out the required settings
Windows XP
1. Click start --> (sometimes settings) --> Control Panel --> Network Connections
2. Double click on the active connection which will say connected underneath
3. Click Support
4. Click Details
5. Now the IP Address, Subnet Mask, Default Gateway, Primary DNS and Alternate DNS which are displayed should be noted.
Windows Vista
1. Click Start --> Control Panel --> Network and Sharing Center
2. Click on "View Status" to the right of your connection
4. Click Details
Set these values under "manual settings" in the PS3 but add 1 to the last number for the IP Address as this has to be unique on your network
Jan 04, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
