Question about Dell 1600n All-In-One Laser Printer
I have dell 1600 multifunctional jam 1/no cartridge
I have on error message: jam 1/no cartridge
  • 1 more comment
  • trigger11 Mar 29, 2008
    Removed all paper but still getting the Jam1/no cartridge error. Please help.
  • Timotheus76 May 12, 2008
    I also get this [JAM 1] or [NO CARTRIDGE] message. Tried to clean, but no papers are jammed! After 10 starts, sometimes, this erros does not appear...
    Has someone any ideas about that? Sensors?
    Thanks a lot,
    TImo, Germany
  • Anonymous Feb 13, 2009
    Same error code, no loose paper or pieces of paper evident, either around the cartridge or behind back door. Could this possibly be the sensor mounted in the fuser assembly?
  • 3 Answers
I have been having the same problem. I almost gave up on this printer. After careful analysis I noticed that if I pulled up on the cartridge while it was inserted and held it up (I took the door off and depressed the door closed button w/ a screwdriver) the printer would work fine.
I shimmed the front of the cartridge w/ a piece of rubber or folded up paper. There appears to be something in the back that doesn't make full contact if you do not do this. Now it works fine.
I haven't had any feed problems, but I kept my shim to the front right and made sure it doesn't go too deep.
Posted on Mar 24, 2009
I also have been having the jam1 no cartridge error on a dell 1600n, i think the tell tale symptom of this specific problem is when starting the printer is says warming up and then toner 0%, even with a brand new cartridge. I tried shaking the printer upside down (read on other posts) to check for stuck objects, i tried manually feeding a cardstock folder in and out, but it didn't seem to be any jam or foreign object. I had a eerie feeling it had something to do with the connection with the toner on the right side, i even tied to straighten the connection as they seemed to be not uniform, finally i found this post and folded over a small piece of cardboard and "wedged" it in the right side under the toner cartridge about the size of a postage stamp and 3 thick. TA DA!!! it FINALLY reconizes cartridge and says toner 100%!!!! YEA!!! thanks. This forum is a lifesaver!
Posted on Dec 16, 2009
  • herarmsrwick
    herarmsrwick Jun 20, 2012
    i used the rubber worked fine thanks =)
    Scholar:
  • 105 Answers
Paper is misfeeding after it has been pulled out of the cartridge. Remove toner cartridge, check for loose pieces of paper. Turn printer around and open rear door. Remove any stuck pieces. Remove paper tray and put back in. Error should clear if no sensors are malfunctioning.
Posted on Mar 27, 2008
Refilled my ink cartridges on hp 309g gets error message
Yes it does work on HP C309g-m if you place a cartridge one by one as follow:
1- open the cover
2- replace an original hp cartridge by the compatble non hp cartridge
3-unplug the printer
4- close the cover
5-plug printer back on
6- press ok to all messages
7-repeat from step 1 to 6 above for each new non hp cartridge
Et Voila.
Many Thanks
Oct 09, 2012 | HP Photosmart Premium C309g multifunction...
Printer TX550W has message "A printer error has occurred. Turn off and then on. See your documentation".
Hi, this error message usually caused by jammed papers or foreign objects inside your printer. To resolve this issue, please try the following steps.
1. Turn off the printer.2. Open the scanner unit.3. Check for any jammed papers or foreign objects then remove it.4. Check the ink cartridges and lids if push down fully.5. Close the scanner unit.6. Turn on the printer.
If the same error reappears, try the following.
1. Turn off the printer.2. Open the scanner unit.3. Remove all the ink cartridges.4. Turn on the printer >> your printer will display install ink cartridges.5. Install all the ink cartridges, make sure it clicks into place and also the lids should be push down fully.5. Close the scanner unit.6. Press the Start or OK button to charge the cartridges.
If the issue persists, your unit will require service. Please contact Epson so they can check if your printer is still under warranty or ask them for the nearest service center in your area.
Nov 23, 2011 | Epson Stylus Multifunction Inkjet Printer/...
What is error #2200
The 2200 error message indicates a scanner stall or jam. The steps below will help you to resolve the issue and clear the error message.
Printer Reset
1 Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
Did the error message return?
Yes: Continue to step 2.
No: Attempt a test scan. If the error message does not reappear, the error is resolved.
2 Power off the AIO and remove the power supply from the back of the unit. Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
Yes: contact Dell.
No: Continue to step 3.
3 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Insert the color cartridge, close the top cover, reinsert the power supply, and power on the AIO.
Yes: Repeat step 3 with another color cartridge. If the printer fails again, continue to step 4.
No: Repeat step 3 and install the black/photo cartridge. If both cartridges are installed, attempt a test scan. If the error message does not reappear, the error is resolved.
4 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove the color cartridge and insert the black/photo cartridge. Then close the top cover, reinsert the power supply, and power the AIO on.
Yes: Repeat step 4 with another black/photo cartridge. If the printer fails again, contact Dell.
No: Install the color cartridge. If the printer fails, contact Dell. If the error message does not appear with both cartridges installed, attempt a test scan. If the error message does not reappear, the error is resolved.
Mar 23, 2010 | Dell 962 Photo All-In-One InkJet Printer
My HP M1319f fax machine diplays a "No Print Cartridge" error.
I have checked for paper jam, remove the paper and cartridge was recognized.
Mar 02, 2010 | HP Laserjet M1319F Laser Multifunction...
Error code 0502 hardware error on dell printer
i once fixed the hardware message by putting the tape back on the back of the cartridge...then fixed the perpetual paper jam message...
Feb 19, 2010 | Dell 922 All-In-One InkJet Printer
Canon error 5100 cartrige jumped
I think you are seeing "ERROR 5100: Cartridge Jammed", right?. Here is the most likely solution to this issue with your printer. The following procedure comes directly form Canon
ERROR LCD: CARTRIDGE JAMMED
1. Press ON/OFF switch to reset the multifunction device 2. Removing obstructions, foreign objects and paper jams MP750 / MP780 3. Reseat MP750 / MP780 print head 4. The MP780 may require repair
Feb 08, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Grey arm is in place. cannot find any paper anywher that is a jam
this can happen if any of the contact points on the cartridge are even remotely scratched or if the cartridge is "low" even if it doesnt say its low
Please Rate Me
May 28, 2009 | Dell 1600n All-In-One Laser Printer
Dell 942 carrier jam
This morning I replaced the cartridges in the Dell 942 printer, they jammed to the left which made a loud grinding noise and the cartridge jam error came on.
I solved the problem by turning the printer on with the top up which moved the cartridges to the right a little so I could reach back, push one down a little manually which freed them to move over to the middle.
Feb 28, 2008 | Dell 942 All-In-One InkJet Printer
Error Message "Unable to init 46"
error 46: waistink absorber needs replacing. you must have run quite a lot of manual cleaning cycles in case your mfc is about 1 year old....
Feb 26, 2008 | Brother MultiFunction Center MFC-440CN...
Dell 1600n All-In-One Laser Printer Logo
1,528 people viewed this question
Top Dell Office Equipment & Supplies Experts
David Patricia James
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
