Question about Panasonic DMR-ES10 DVD Recorder
Accidently formatted a DVD instead of finalize Panasonic DVD recorder.
  • Panasonic Expert
  • 244 Answers
Sorry but you will have wiped the disc of all recordings
Posted on Sep 27, 2009
HOW TO FINALIZE THE DVD CASSETE AND CONNECT TO T.V SET?
Finalising a disc enables the disc to be played on any other compatible machine. By doing this it changes the disc format so that you can no longer record to it turning it into a Play Only disc. On your Panasonic DVD Recorder you can record to many (if not all depending on the model) of the following DVD Disc formats to the limit of their capacity over multiple occasions. The disc in question can be played back and recorded to on the DVD Recorder during this time but until it is finalised it will not work on any other machine.
DVD Formats: DVD-R, DVD-RW, DVD-RAM, DVD+R, DVD+RW.
How do I Finalise my disc?
  1. When you have finished the initial recording stop the disc and press the ~FUNCTIONS~button.
  2. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "To Others" and press~ENTER~.
  3. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad Scroll down to "DISC MANAGEMENT" and press ~ENTER~.
  4. When the disc management screen opens you need to use the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad to scroll down to "FINALIZE" and press ~ENTER~.
  5. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "YES" and press~ENTER~.
  6. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "START" to begin finalizing the disc, please note by pressing start here you will no longer be able to record or edit the disc being finalized.
Finalizing may take up to 15 minutes.
Do not disconnect the mains power in this time. A message appears when finalizing is finished, press the enter button when this appears. It will now play on other compatible machines.
Apr 23, 2010 | Panasonic SDR-H40 HDD Camcorder
I accidently formated my panasonic VDR-D210 DVD using the DVD recorder menu. Can I unformat the DVD and recover my video?
When you reformat again using the proper disk, you should be ok with formatting. Whether or not you can recover the video is yet to be seen. Regards, Joe
Dec 07, 2009 | Panasonic VDR-M95 DVD Camcorder
Limited viewing
It sounds like the recorder will only record the dvd+ format, which does NOT need finalizing to play in other machines. ( you can record a dvd- , play it back on the machine you recorded it on, but need to finalize it to play on other machines)
The other units may only accept dvd-.(dvd- being the same format as you would buy or rent a film on)
One option, record the dvd on a dvd+rw (if possible) then copy to a dvd-r using your computer. The average use of a dvd+ is 1000 recordings.
There are many free disc burning suites available to download. Just google "free disc burning software" and take your pick.
I use 1 called "magix goya base" for copying disc to disc and "NTI" for burning to HDD and then to disc, if you only have use of 1 drive.
Sep 04, 2009 | RCA DRC8295 DVD Recorder/VCR Combo
Fanalize in Panasonic DVD Recorder failed
Hi,you need to have the laser replaced in the unit.
Aug 24, 2009 | Televison & Video
Finalizing
that's because u r in HDD mode. Change drive select to "dvd" , then "functions" will show: "disc setting" to include, disc name, pick menu, select first play, and Finalize.
Jul 17, 2008 | Panasonic DMR-E85H DVD Recorder
Why won't the DVD play on my computer? Help, please?
Put it back in the recorder you made it with and make sure it is finalized. Also make sure your DVD drive in your computer is compatable with that format.
Jun 12, 2008 | Panasonic DMR-E85H DVD Recorder
VHS record to DVD
Insert the VHS and rewind or fast forward to the point you want to begin copying from.
Insert the disc you plan to use and format it if necessary. It will usually prompt you if it is necessary to do so.
Put the television on the channel or input needed to view the recorder on-screen.
Select the DVD drive and set the record mode you prefer - XP, SP, LP or EP.
There are two things you can do:
1. Press and hold the dubbing/copying button on the recorder itself in the direction of the DVD for 3 seconds. If you are using a DVD-R/RW or +R you will receive a message stating to press Play to record without finalizing or press Record to record and finalize. If you are using +RW or -RAM, these cannot be finalized - therefore this message will not display.
2. You can access the Functions menu and go to Copy, then select the copy direction VHS to DCD and select Start Copying.
Apr 01, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Finalizing DVDs of a previous burner
Neither will work. you will have to try a computer.
Oct 28, 2007 | Philips Magnavox MWR10D6 DVD Recorder
Panasonic recorded dvds? what's up?
http://service.us.panasonic.com/OperMan/findmanual.aspx?model=DMRES40V
Try the Manual. It has a finalizing section. This is the link above.. Pat
Aug 02, 2007 | Panasonic DMR-ES40V DVD-Video Recorder
Panasonic DMR-ES10 DVD Recorder Logo
79 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
