Question about Mitsubishi WS-55809 55" Rear Projection Television
The colors are separating and it has the appearance of a 3-D picture. What is the solution? It appears that the blue and red are separating and we see a double image, especially on the items in the background.
  • Mitsubishi Master
  • 5,138 Answers
Replace your convergence ICs they are big black ICs will have part number on them STK394-250 example# Go by the numer on your STKs Call Mats for parts and supplys for repair 1-800-628-1118
Posted on Sep 27, 2009
My screen has little dots appearing sometimes red sometimes blues behind the picture i just replaced the lamp bulb as i thought it would cure the problem
the projection tube needs to be adjust for color alignment, each tube (red, green, blue) must be aligned so you there would be no color smear appear on screen. if it is aligned try to set up the color balance, hue etc.
Feb 06, 2011 | Samsung Televison & Video
Panasonic pt43lc14 no red color. picture is good. cannot get anything to look normal color after trying to adjust color/tint/picture etc. Have alot of blues and yellow, and brown. seems like no red.
It appears that your light engine is broken, I have the same problem. Have you recently changed the bulb with a non-panasonic part bought on the internet. I did this and think thats what caused the problem. I believe the new bulb burn at a higher temp thus causing damage to the Light engine filters
Jan 04, 2010 | Panasonic PT-43LC14 43" Rear Projection...
Red and blue ghosting,
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 12, 2009 | LG RU-52SZ51D 52" Rear Projection...
Philips 23PF9966/37 color problem!
Most likely you can adjust it in the Service Alignment Mode (SAM).
Press 062596 followed by the STATUS button (upper left). Navigate to "White Tone", press the right key to enter and select "Normal" mode. Set the colors:
Red = 135, Green = 128, Blue = 133.
The "Cool" and "Warm" menus are deltas from the "Normal" settings:
COOL: R -3, G -1, B 5
WARM: R 2, G -3, B -13
Press the "MENU" button to return to the main menu, then the "Power" button to turn the TV off.
Jun 15, 2009 | Philips 26PF9966 26 in. LCD Television
Distorted Color and geometry of Picture
replace stk 392-110 ( or stk 392-150 same number) , check resistor 2.2 ohms for open or burn beside STK IC's
Apr 13, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Map sensor pin arrangement dodge cavan 2003
Hello, here is a picture of the connector and wiring.
85cdf8a.gif MANIFOLD ABSOLUTE PRESSURE SENSOR (GAS) - BLACK 3 WAY CAV CIRCUIT FUNCTION 1 K1 18VT/BR (3.3L/3.8L) MANIFOLD ABSOLUTE PRESSURE SENSOR SIGNAL 1 K1 18VT/BR (2.4L) MAP SIGNAL 2 K900 18DB/DG SENSOR GROUND 3 F855 18PK/YL 5 VOLT SUPPLY
Pink/Yellow is #3, Blue is #2, and Purple is #1. Your colors may appear slightly different
Oct 06, 2008 | 2003 Dodge Grand Caravan AWD
Distorted picture on RCA LCD TV
it can be replaced with a t0220 stile case dioded 220k ohm go to nte look up and do a search on the rca part #moz-screenshot.jpg 259638 search the web for the part.
Jun 29, 2008 | RCA R52WM24 52" HDTV Projection Television
Convergence and picture problem.
convergence ic's
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Jan 07, 2008 | Sony KP-57WV600 57" Rear Projection...
Images: three colors appears separates in the screen: red, green, blue
do they look like these:
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 05, 2007 | RCA HD52W59 HDTV Projection Television
Mitsubishi WS-55809 55" Rear Projection Television Logo
54 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
